Old 11-27-2014, 09:39 AM   #827
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by CapriRacer View Post
Yes, that is what I am saying.
Because:
1) That is MY recommendation
2) The confusion would not be eliminated because there would now be 2 charts with different loads on them.
No, that 10% is NOT part of my recommendation. It is a separate issue - the standard way of dealing with P type tires used in LT and trailer service.
To put it distinctly, the load carrying capacity of a P type tire has to be reduced by 10% to get the load carrying capacity when the tire is used on Pickups, vans, and trailers - and then another 15% reduction per my recommendation.
Not exactly.
When I was in college, I had a professor who said "Overdesign, underutilize". What he meant was that products need to be overdesigned to accommodate those things we engineers don't know about when we design stuff - and when those products are used, they should be used at a lower level to also accommodate those things we don't know about the intended usage.
What reducing the published load from the tables by 15% does is part of the "underutilize" part of the equation.
Thanks for taking the time to explain the origin and the reason for those numbers. It make it much easier to arrive at an informed decision.
The one thing that is obvious from this thread is: There is no way to be absolutely safe from tire failure. If if the engineers do their job and the user is diligent in his selection, a malfunction in a manufacturing or chemical plant, can still produce a substandard tire. As illustrated by the Michelin and other recalls, the user is the ultimate tester. Even if we could make tire manufacturing 100% reliable, there is still the issue of road hazard.
The take away for me is to exercise maimum diligence in selecting your running and towing gear and inspect it often and hope your inspections reveal faults before they cause failure. Keep all this in mind and then find a thought process that allows you to still enjoy the drive,
Ken
Old 11-27-2014, 12:28 PM   #828
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Seeing that Airstream shipped our 2014 Airstream 31' Classic with four 15" Goodyear Marathons (ST225/75R15D ) rated 2,540 pounds at 65 psi each (four tires equals 10,160 pounds capacity) and the GVW is 10,000 pounds, they do not appear to be following the safety margin concept very closely.
In our specific case, our tongue weight is about 1,345 pounds which would mean the tires could be carrying 8,635 pounds at GVW. The four 15" Michelin LTX (P) 235/75R15 XL tires are derated to 7,940 pounds (side wall load rating would be 8,732 pounds). They would be of inadequate load capacity at GVW.
One tends to overlook the weight loading when parked, but the tires, axles and tongue jack are supporting the GVW then. So the correct tire size helps....
Maybe that is why Airstream is putting the SenDel T03-66655T wheels and Michelin LT225/75R16/E LTX M/S2 tires on the 2015 Classics as standard tires. Four tires are rated 10,720 pounds at 80 psi.
Old 11-27-2014, 05:29 PM   #829
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
While the tongue weight will take some load, I would suggest price is a factor in this example.
>>>>Action
Old 11-27-2014, 05:44 PM   #830
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Airstream is very, very slowly converting to Michelins with 16" wheels. When I discussed Michelins with them at least 5 years ago, they were starting to offer them as a barely disclosed option. They did have a display with 16" wheels and tires at the office then. I think they offered a Goodyear LT tire and maybe also Michelin. I ended up trading OEM wheels with them, picking up 16" Michelin LTX tires at Discount Tire in Dayton, and having Airstream install it all. The OEM 15" wheels looked bad as the coating was failing and I got new wheels at a substantial discount. The tire distributer had a one year warranty and wouldn't cover it as I was over the one year.
Over time, Airstream has made the Michelin 16" LTX tires more and more available as either an option or on specific models. Michelins cost about 2 times more than Marathons and larger wheels must cost a little more. But the Goodyear LT option is gone and they have, at least in this instance, listened to customer about Michelins.
Though Michelin had a recall, they didn't stall or try to limit it—they did it on their own and it must be costing a mint. Unfortunately we were out of the recall period as I was hoping for all new tires.
And yes, you have to make the decision yourself based on all available knowledge, trying to sort through the crap to figure out the best thing to do. That is something we have to do with everything, every day. I wish there were easy answers and better research. RV research on many things is weak or nonexistent as there's little money in it.
I am getting close to 5 years on the Michelins and they have lots of tread left. Many here have recommend tires should be replaced at 5 years because of aging (by that standard, I should have been replaced generations ago). Michelin has been quoted as saying 10 years so long as they are regularly inspected. It has been said elsewhere on this Forum that Michelin says 7 years, but I couldn't find anything definite on their website. The 10 year quote comes from Edmunds' website. Regardless of how old they are, regular inspections are a good idea. I don't know where the 5 year rule comes from—it may be "conventional wisdom", thus repeated so often it is believed to be true. I get 65-75,000 miles on Michelins on motor vehicles and that is often more than 5 years, though not by much. Because there are no drive wheels on a trailer, I expect them to last for even more miles.
Gene
Gene
Old 11-27-2014, 06:56 PM   #831
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
That has been about my experience, Gene. Old Lucy had her 16" Michelins for four years. We put 60,000 miles on these tires. They showed no discernible tread wear.
We have already gotten the Michelins on New Lucy. The tires and wheels cost us $1,600. We were able to sell New Lucy's OEM tires and wheels for $600. Therefore, the upgrade cost us a total $1,000.
I would think that Airstream could offer a Michelin option for $1,000 or less.
Brian
SuEllyn & Brian McCabe
Old 11-27-2014, 09:17 PM   #832
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
16" wheels/LT tires
Tires that do not spend regular time on the road deteriorate more quickly. Exercise redistributes oils within the rubber. This is the problem with trailer tires and why standard manufacturer recommendations may not apply.
Going with premium tires doesn't change TT replacement schedule greatly given differences for local and individual owner conditions.
I'd check Tireman9's blog and ask advice. Whether a Michelin dealer knows exactly what to look for during a dismount would be key.
Michelins have been known to look fine on outside and not on the interior. This happened to the five year old ones on my truck (2007-2012) with only 80k on them. Three out of four failed on a trip back from San Antonio. I was practically given a new set. Had 4/32's total wear and was looking to take them well past the 120k mark that the original set had delivered.
Reading around I believe this was a problem over a few years that has since been rectified.
Three to five years is the usual recommendation due to service. Were I making a few short trips in cooler weather I'd inspect and go on. But extended touring would be something else again.
Old 11-28-2014, 06:14 AM   #833
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by BoldAdventure View Post
What if the tire engineers already did that in the design process and have factored in 15% already? Now we're at 30%?.....
Then tires wouldn't be failing and you wouldn't worry about it.
.....This is just based on a personal preference as the 15% seems to be an arbitrary number you came up with correct?.......
No.
When the Ford/Firestone thing was active (winter of 2000/2001), the company I worked for examined all the tire failures they had on record and discovered that most of the tire failures were coming from SUV's and pickup trucks - where there was no reserve tire capacity (unused tire capacity).
Cars, on the other hand, had very few failures. They also generally had about a 15% reserve. What was even more interesting was that SOME SUV's had a 15% reserve capacity and those tires behaved like the ones on cars
So the company I worked for recommended to all the car manufacturers that it was doing business with that all vehicles have a 15% reserve tire capacity - and most followed through, in particular, Ford. (I have to assume, other tire manufacturers did the same sort of analysis and came to the same conclusions as there didn't seem to be any pushback from the OEMs.)
The result was a drop in the rate of tire failures (although it was hard to sort this out as there were changes on the tires taking place at the same time)
So, No, the number is not arbitrary. It is based on personal experience.
CapriRacer is offline   Reply With Quote
Old 11-28-2014, 06:52 AM   #834
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Ok, great to know then.
So the Michelin LTX M/S2 in 225/75R16 rated at 2680 lbs. with 80 psi.
Derated 10% for Trailering = 2420 lbs. and with a safe margin of 15% = 2057 lbs.
2057 lbs. x 4 tires = 8228 lbs rating.
Which means trailers with 10,000 GVWR running these would be way over a safety margin based on above advice. ??
Unless the math is 15% & 10% from the original rating. At which it becomes 2010 lbs rating x 4 tires = 8040 lbs.
Either way, this all works out for my trailer math wise. But for others????
But this completely kills it on the 15's.
Michelin LTX M/S2 in 235/75R15 at 50 psi. rated at 2183 lbs.
Derated 10% for trailering = 1964 lbs.
Derated 15% safety = 1669 lbs
1669 x 4 tires = 6676lbs rating.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-28-2014, 07:59 AM   #835
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
The 10% derating factor is only applied to p-metric tires, and it is an NHTSA and/or MVSS requirement, not just a rule of thumb.
Also, unless I am mistaken, the load limit applies to the weight the tires are carrying, not the GVWR, so subtract off the actual tongue weight.
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 11-28-2014, 08:13 AM   #836
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Not exactly. The 16s are LT not P tires. No derating required so you're getting over 10700# capacity - then with the 15% safety margin you have over 9100# available.
Next, that's capacity for your weighed trailer. Your max GVWR is just that - a max. When you're on the scales, you'll see what your trailer axles actually see loaded for camping. For example, my GVWR is over 7000# but loaded for camping, the scales show 5800# on the trailer. While it would be great to get each wheel weight individually, I'm happy knowing the 4 tires are sharing 5800#.
If your GVWR is 10,000, your actual towing weight could be 7500ish (weighing it is the only way to know for sure). That's the capacity you need to worry about. Anything under 9100# would work for you with those 16s.
Old 11-28-2014, 09:54 AM   #837
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
16" wheels/LT tires
Ok, so how about these General Grabber HTS tires for 15" wheels? They seem to have a higher rating than the Michelin 15" tires, which according to the Michelin site are rated for only 1985 pounds. The 109T rated General Grabber HTS in 235/75R15 XL is rated at 2271 pounds with max inflation pressure of 51 pounds. If that's a good tire, it would seem a better choice than the lower-rated Michelin...unless I am misunderstanding, which is entirely possible.
Oh, and the General is a "low rolling resistance" tire, which sounds like it might be helpful for better MPG when towing.
http://www.michelinman.com/tire-sele...ails#techspecs
http://www.generaltire.com/tires/lig...bber-hts#Specs
Thoughts?
Rocinante is our 2014 International Signature 27FB
Old 11-28-2014, 10:10 AM   #838
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
To be thorough trailer tire load need also take into account, when parked, the additional weight of supplies and people aboard. There are those who travel without fresh water, for example.
Old 11-28-2014, 10:20 AM   #839
Nomadic , USA
I read him wrong on the derating 10%, thought he was applying it to LT tires too. I know the rating is what it's actually carrying, not GVW, but I'm using it as a measure. I know I could use P tires right now, but maybe not when we go full time.
slowmover I've owned General Tires on several vehicles. I like them, good tire. Can't speak to putting them on Airstreams.
Old 11-28-2014, 10:58 AM   #840
Ag&Au's Avatar
I would have to think about this concept for a while before I accepted it. Tires are rated for moving at their max rated speed and the associated flexing, scuffing and heating involved. When sitting still in a campground or wherever, none of those dynamics are occurring, and a certain amount of the weight is being born by the tongue jack. So my instincts tell me what happens when parked is not a factor. (within reason of course).
If I am misinterpreting what you said, then "never mind" .
Ken
16" tires, ltx
15" to 16" Wheels/Tires on 2007 Safari Rollertoaster Tires 53 01-23-2011 06:41 AM
Wheels and Tires shepherd57 Argosy Motorhomes 7 08-09-2010 07:14 PM
16" 5 on 5 1/2 wheels - What tires? Benjo Tires 10 02-15-2010 07:41 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
Wheels and Tires Fordstream Tires 4 01-12-2006 09:51 PM
