Old 11-04-2014, 09:15 AM   #771
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
On the other hand if you want to feel better about worrying about it, read this:
Wheel run-off accidents - Kentucky Injury Attorneys
Ken
Old 11-04-2014, 09:16 AM   #772
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Yup. Maybe a call to the AS Service Centre is in order.
Originally Posted by Alphonse View Post
I'd like to know if the lug bolts on an Eddie Bauer are the same as the rest. I assume they are but a "look see" into that might shed a little light on the torque specs.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 11-04-2014, 10:09 AM   #773
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Based upon my past experience, I have decided to go with 115 ft. lbs. measured with the same Craftsman torque wrench that I have had for years. I have also decided to stick with the 72 psi that I used on Old Lucy.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 11-04-2014, 10:45 AM   #774
Ag&Au's Avatar
Brian
That sounds to me like the smartest solution. You know that works.
I'm not so sure about that 72 Psi, however.
I think 73.7 would better.
Ken
Old 11-04-2014, 01:39 PM   #775
moosetags's Avatar
Maybe not engraved in stone, but close.
Brian
Old 11-04-2014, 02:17 PM   #776
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
But not a green label spec'ing Nitrogen only. Saw that on an 18 whlr today.
Just making really small jokes, we need to grin once in a while.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 11-04-2014, 03:36 PM   #777
Ag&Au's Avatar
Brian
That's cool. You should market those here. I think I need one for the inside of the door that says, "Do NOT go out this door without your keys"
I haven't locked myself out yet, but I know it is only a matter of time.
Ken
Old 11-04-2014, 05:18 PM   #778
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Brian
What a great idea! I always worry about someone reading the placard (for the GYM D's at 65 PSI) when in for service but that could be a great solution....
Old 11-04-2014, 08:14 PM   #779
moosetags's Avatar
I made the little signs mainly to remind myself of the specs when I check the torque and tire pressure. I even made one for the Hensley to remind me of the torque for the U bolts. Now I won't have to look it up every time I want to check the bolts.
Brian
Old 11-04-2014, 08:19 PM   #780
Brian
Human brains are great, but check lists make them even better, and certainly less forgetful.
Old 11-04-2014, 10:49 PM   #781
de NO1PC
JimAspinwall's Avatar
2004 30' Classic
1988 29' Excella
Campbell , California
Post #760 - pic data differs
In the picture of the Eddie Bauer wheels in text it says 5 lug though the pic and the wheel model is obviously 6-lug.
Aside from that...
"Max Torque: 125-130 ft. lbs"
Airstream originally said 110-120#. Not a max, not a min, a range.
Combine that with generic recommendations for bolt size:
Lug Size FT/LBS Torque
1/2" 90-120
9/16" 120-140
5/8" 140-160
All that said, I'm comfortable with 120# and check regularly. Less chance of popping off a stressed lug stud.
Sendel also says 80# pressure. It took me a few weeks to get the tires to settle in (bead, valves, TPM sensors, etc.) to 75-77# (at 75-80 deg) with some head room for heat. 70 and below gets pretty mushy.
Just a humble, no-anxiety comfort zone.
Enjoy the ride! Best 73!
de Jim, NO1PC
JimAspinwall is offline   Reply With Quote
Old 11-06-2014, 07:33 AM   #782
2014 30' International
DFW Airport , Texas
At 75 psi you are assuming that you are loaded at least 600#s below the GW for the trailer and at least 300#s L/R and F/R?
Vlamgat is offline   Reply With Quote
Old 11-06-2014, 08:23 AM   #783
theOrca's Avatar
Oak Harbor , Washington
It is of some interest that Sendel has evidently updated the ratings of it's TW-02 wheels (TW-T02-66655T 16x6 Aluminum T02 Trailer Wheel 6 Lug, 3200 lb). The inside stampings on the wheel still say the load rating is 3200 pounds, but the pressure stamp is 100 psi not the 80 psi that the web site states.
I just got my wheels yesterday. I did find solid stainless steel Acorn style lug nuts on the web and have Andy's axles waiting at the local Les Schaub store. Next Tuesday the switch gets made!
Bye the way, I am going to be the test case for Toyo Tires. I just did not want to do a 100 mile round trip just to have the Michelin name. Our local fire trucks and ambulances all use Toyo tires. NO problems at all over the last 5 years. I have to admit that if Toyo were made in China, I would have made the 100 mile trip to avoid them. But at least this model of Toyo tires are made in Japan. The Japanese are still way ahead of everybody when it comes to attention-to-detail in manufacturing! 10 ply and a great tread design. Within a couple of years we shall see if I made the right decision.
theOrca is offline   Reply With Quote
Old 11-09-2014, 10:19 AM   #784
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
First of all, Ken the # symbol for pound has been around for as long as I can remember, and though I am old, I can still remember what happened 50 years ago (yesterday is a little more difficult). The pound sign is also the number sign. We need more symbols so they don't have to double up. I also a new symbol to replace @ because when I try to write it is just looks like a bunch of circles.
Another memory test: Our '08's manual says 120 # (lbs.—which means libras or livres or something like that in Spanish or French because they used to have money in pounds too). But I found on the Airstream website that the wheels were changed early in the '08 model run—probably early summer of '07—and the new magic # was 110 #. When I changed to Michelins and 16" wheels around '09, I stayed with 110. I got that number from somewhere and it probably was from Airstream because I got the wheels at Jackson Center. We've traveled with 110 lbs. torque on the 16" wheels for probably 40,000 miles and they are still ok.
And now a new question—If steel wheels need less torque than aluminum, why? I think aluminum is softer than steel, but I don't think that would make a difference. If it did, maybe that explains higher torque for aluminum because you compress the wheel more when tightening and thus have to tighten more to get the same lug nut tightness.
Gene
Gene
16" tires, ltx
15" to 16" Wheels/Tires on 2007 Safari Rollertoaster Tires 53 01-23-2011 06:41 AM
Wheels and Tires shepherd57 Argosy Motorhomes 7 08-09-2010 07:14 PM
16" 5 on 5 1/2 wheels - What tires? Benjo Tires 10 02-15-2010 07:41 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
Wheels and Tires Fordstream Tires 4 01-12-2006 09:51 PM
