Old 07-11-2014, 01:50 PM   #617
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by blkmagikca View Post
I wixed up my mords
Blk- You have me rolling on the floor ...... I wix mords sometimes, too !
Old 07-21-2014, 09:52 PM   #618
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I'm at JC getting new axles, 16" wheels and Michelin LTX(E) tires installed. At the same time they are repairing the damage caused by the blowout 2 months ago of a GYM. I had them install Dill TPMS sensors and Centromatics. Should have it all finished sometime tomorrow.
My question relates to the Dill TPMS sensors. Right now JC has (temporarily) marked my tires to show which sensor was used (A through E). However, these marking are most likely going to disappear the first time the trailer is towed in wet weather. I am considering using an etching pen to discretely mark the letter corresponding to the sensor on the rim just beside the valve stem. Has anybody done something different to ensure a permanent marking, and if so, what did you do?
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 07-21-2014, 10:35 PM   #619
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Quick question for you: Now that you've moved to 16" wheels, did you also have to get a different mount for the spare tire so the new larger wheel will fit in there?
Regarding our TPMS, ours are valve-stem mounted, so I just keep very careful track of them whenever someone services the tires. Otherwise, I know where they are because I programmed the TPMS receiver. If they were mounted inside the tires, I would ensure the rims were marked in some useful way before allowing anybody to remove any of the wheels, perhaps the same way they did at the mother ship.
Oh, and it's good to know they are willing and able to install TPMS sensors and centramatics when they switch you over!
Old 07-21-2014, 10:38 PM   #620
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Have you taken any pictures of the axle replacement work? If so, I'd like for you to post them. Also, are they replacing the original axles? What is the weight rating of the new axles?
Regarding the TPMS, I'd try a sharpie first. I'd also make a little chart and slip it in your owner's manual under the tire section similar to the following:
TP Sensor/Tire Suffix
A 12345
B 12346
C 12347
D 12348
E 12349
Recommended Tire Inflation: XX PSI
Recommended Lug Nut Torque: XXX Lb. Ft.
That way you could renew the sharpie mark as required. I think that if you ever had a sidewall delamination or anything similar, an etching pencil might invalidate the warranty, if any. Also, many tread wear warranties are void on towed vehicles as a point of information.
Steve Bryant is offline   Reply With Quote
Old 07-21-2014, 10:43 PM   #621
de NO1PC
JimAspinwall's Avatar
2004 30' Classic
1988 29' Excella
Campbell , California
The important part is the relationship/pairing of a specific sensor with a display position on the monitor. Mark the sensor with a paint pen and something that makes sense to you relative to the readings and keep them located accordingly.
Ultimately I am slightly less concerned about WHICH sensor shows a fault than that there IS a fault - which warrants an all-tire check of pressure and temp.
To that I have equipped the "McGiver kit" with a spare laser temp sensor and tire pressure gauges.
When it's time to road-stop and check, EVERYTHING gets checked, at least until I get comfortable with and trust all the pieces, and even at that, never trust safety to assumptions.
I have a used small 12v commercial grade compressor I'm likely to upgrade if it can't make 80# quick enough. I am actually more concerned about over pressure (to 85#+) and temps than under (down to 70-75# anyway) and equalization.
Given that it's tough so far to really know in the driveway how the shady side vs. sunny side are going to behave. In 2-3 months it will be intuitive, until then I trust science and data.
All this because we experienced the massive 3-tire disaster in one weekend on original wheels and cheap older tires, so I'm getting acquainted with the Sendel T03/Michelin upgrade behaviors... but in 40 years, many vehicles and types, I am less concerned about Michelins than what I do not know about 10 y.o Airstream axles and the brakes and bearings.
Whatever my trusted mechanics tell me about lubes for my Duramax or my bearings I am going with... we have at least 10k miles of this wonderful country to explore living riveted and we are going to do it well.
Be safe! (or as one of my friends says: "the price of quality only hurts once" and by experience no better words can be said.)
Enjoy the ride! Best 73!
de Jim, NO1PC
JimAspinwall is offline   Reply With Quote
Old 07-22-2014, 05:59 AM   #622
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
One of the metallic versions of a Sharpie lasts about 2 years on my Pressure Pro sensors. About $2 at any store.
SilverCottage is offline   Reply With Quote
Old 07-22-2014, 06:09 AM   #623
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
My first Dill valve stems were clearly marked by Dill. Second set not marked. I had to figure out position by playing with tire PSI and monitoring, hassle.
Maybe time to call Dill or email and cite this shortcoming. I also think the cabling for the display makes it a dash hog, takes up more space due to bottom power feed on my dash.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-22-2014, 06:43 PM   #624
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The task is completed and we will be heading out tomorrow morning on our new axles, 16" wheels and Michelin LTX225/75R16(E) tires. I did snap a few photos, and I'll upload them as soon as I can. None were taken of the process itself (JC frowns on anyone doing that, as it disrupts the shop, not to mention slows down the work - remember, it's about $116/hr).
The spare carrier was adjusted so that the new wheel and tire fit. As well, the hitch was adjusted, as between the new axles and larger diameter wheels and tires, the Excella rides about 2-1/2 inches higher.
I now need to ensure that I know all times which wheels have which sensors, as the individual sensors are paired with the chip in the receiver/display. Dill labelled the sensors, but they are inside the rim, so some means of permanent marking of the wheel is necessary. Any "sharpie" or ink-based system will not last, so I plan on using a small vibrating etching marker to just etch a small letter on the wheel just beside the valve stem.
VE3JDZ
AIR 12148
Old 07-22-2014, 06:45 PM   #625
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
As an addendum: JC said that the info sheet that comes with the wheels recommends torquing between 125 to 135 ft-lbs. They torqued the wheels at 130 ft-lbs and thatis what they recommend in this case.
VE3JDZ
AIR 12148
Old 07-22-2014, 07:13 PM   #626
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
When I installed the new 16" tire and steel wheel into the spare position, I had to get on the ground and shove the tire more to the rear. I did NOT have to change or bend the upright arms to keep the tire on the frame like I did on my 25FB. Having said that, I would gladly let a younger chap get the spare out on a lousy day because I would have to get under the trailer to get the leverage to remove the spare.
Bummer getting older....
Old 07-27-2014, 10:42 PM   #627
interstateflyer's Avatar
2017 25' International
Los Osos , California
We just took delivery of a 2014 International 23D to replace our 2013 International 19.
We upgraded the 19 with 16" wheels and Michelins shortly after purchasing.
The 23D has 14 inch load range C Marathons with rubber stems. Doesn't Airstream listen to their customers?
I'd like to replace the 14 inch wheels with 15s and Michelin LT M/S. Has anyone done this on a 23D?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 07-28-2014, 06:53 AM   #628
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
This photo was taken outside the service area at JC *before* the hitch was adjusted. You can see just how much higher the new axles and 16-inch tires has raised my trailer. You can also see those nice new wheels. What you can't see are the Centromatics that are slipped on over the wheel studs between the wheels and the hubs.
VE3JDZ
AIR 12148
Old 07-28-2014, 06:57 AM   #629
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The hitch adjustments were to raise the head by 2 inches and to change the head angle so that the torsion bars hung a bit lower, changing the chain length from 7 dropped links to 6 dropped links. Bob, the tech, also checked to see that the cams were also aligned - they were which meant that no adjustment to the cams was necessary.
VE3JDZ
AIR 12148
Old 07-28-2014, 06:58 AM   #630
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
A friend of mine suggested that if you put LT truck tires on a trailer, the tire manufacturer may not pay for damage to a trailer caused by the tires.
I told him that 16" LT truck tires were an option from the factory and a certain trailer came with them standard equipment.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
16" tires, ltx
15" to 16" Wheels/Tires on 2007 Safari Rollertoaster Tires 53 01-23-2011 06:41 AM
Wheels and Tires shepherd57 Argosy Motorhomes 7 08-09-2010 07:14 PM
16" 5 on 5 1/2 wheels - What tires? Benjo Tires 10 02-15-2010 07:41 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
Wheels and Tires Fordstream Tires 4 01-12-2006 09:51 PM
