Old 10-23-2010, 03:41 PM   #43
HowieE's Avatar
Princeton , New Jersey
Images: 12
Try the one above it. That is the 6 bolt version. As for the Off Set that works out just fine. There is clearance on the inside and at the fender.
I have had these now for 3 or 4 years and suggested this wheel to several others and no negative comments to date.
The E rated tires don't even show ware yet as apposed to the old STs that either blew or worn down in 2 or 3 years on average.
2004 Excursion 4x4
Old 10-23-2010, 05:29 PM   #44
2008 25' Classic
Sometimes it's Heaven , USA
Go do the thing at JC... Bob or Jim will likely replace your wheels and tires and the Michelin MS LTX is a good tire... I do think that you should stick with "0" offset... It might not be a major problem to do something else, but why tempt a potential bearing problem. In my case I have a brother who is an Huge wholesale and retail tire dealer and I have a bit of an edge on choices and prices ( not free by any measure) and tech advice by multiple brands and their dealer service techs... I'm sure you could get this done by a really good REPUTABLE tire dealer in FLA....BUT,I like the service people at Airstream and if you have never been there -- Well -- Go to Hobo's for B'fst next door.....You can add it to Lucy's adventures...
Countrysong
COUNTRYSONG is offline   Reply With Quote
Old 10-24-2010, 12:25 PM   #45
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Originally Posted by Inland RV Center, In View Post
Many cities have good tire and wheel shops.
Get those replaced, balance the tire and wheel, add Centramatics and your done.
Just make sure that the back side of the wheels have at least 10 inch flat surface.
Andy,
I'm not clear on what you mean about the 10" of flat surface on the new wheels. Is this to accommodate the Centramatics? I have been looking at their website. It's not saying anything about special wheels.
Brian
SuEllyn & Brian McCabe
Old 10-24-2010, 05:59 PM   #46
Originally Posted by moosetags View Post
Andy,
Brian
Centramatic has never been in the RV end of the business, until we started it.
Just had their sales manager and field manager visit our office.
The special model that they make is the plan what we went to them.
However, it requires 10 inches of flat area on the back side of the wheel, so that when you bolt the wheel to the hub, with the Centramatic in between those two parts, you don't alter it's shape in any way.
Probably tomorrow, I should post a drawing in our web site, which would be self explanitary.
Centramatic will not have anything on their web site relating to the above comments, as they want us to handle it.
Old 10-24-2010, 07:30 PM   #47
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Brian, I got the 16" wheels at JC and picked up the Michelin's at Discount Tire in Dayton. JC balanced the tires on the new wheels and put them on the trailers. I've had Centramatics for a couple of years now. I bought them from Inland, bit the size for 15" and 16" wheels has been available for a while and you can find them on the Centramatics website though it's kind of hard to figure out which one you need.
The tires have been on the trailer for almost 20,000 miles and are wearing evenly so I guess they were balanced ok.
Gene
Old 10-24-2010, 10:31 PM   #48
moosetags's Avatar
Andy,
What size/model Centramatics do I need to order for the 16" wheels that I will get from Jackson Center?
Brian
Old 10-24-2010, 10:35 PM   #49
moosetags's Avatar
Gene
Thanx for the info, Gene. I take it that you use the same size Centramatics on both the 15" and the 16" wheels on the Airstream.
Brian
Old 10-24-2010, 10:43 PM   #50
Master of Universe
Gene's Avatar
Yes, they fit on 3 different size wheels including 15" and 16".
Gene
Old 10-25-2010, 12:35 AM   #51
Andy,
On your web site you show a #13150 Centramatic for 15" wheels. Is this also for 16"?
Barry
pattonsr is offline   Reply With Quote
Old 10-25-2010, 12:40 AM   #52
I spoke to someone at JC regarding 16" wheels. He said the wheel and tire were mounted when they got them. He couldn't tell me who made the wheels or the pattern.
If Tredit provided the wheels, their T03 wheel sure looks like a Sendel T03 wheel. Does anyone know the choices JC offers, if any, in 16" wheels?
Old 10-25-2010, 04:51 AM   #53
Master of Universe
Gene's Avatar
The ones I got there do not have spokes, but have holes spaced around them. The Internationals come with that style according to the Airstream website. They are easier to clean and we think they look better. I was also told the wheels only came with tires mounted too, and then they only came with Goodyear Wranglers. I explained Michelins were better tires. Eventually we worked it out so I could have Michelins. This was at the end of October last year.
I don't know which Michelin Airstream offers. It'll be either one of the LTX line or a Rib. We got the LTX since it would wear out around 5 years and because the Rib is a commercial truck tire meant to be recapped eventually.
Gene
Old 10-25-2010, 07:18 AM   #54
Andy,
Brian
Brian.
Part # 13150.
Old 10-25-2010, 07:21 AM   #55
Originally Posted by pattonsr View Post
Andy,
Barry
Barry.
Yes.
Old 10-25-2010, 11:56 AM   #56
Zigidachs's Avatar
2011 30' Classic
Ridgefield , Washington
We balanced our tires with the commercial "sand" added with the initial inflation. 100' pulling down the road and the tires are "balanced". No weights. :-)
Zigidachs is offline   Reply With Quote
16" tires, ltx
15" to 16" Wheels/Tires on 2007 Safari Rollertoaster Tires 53 01-23-2011 06:41 AM
Wheels and Tires shepherd57 Argosy Motorhomes 7 08-09-2010 07:14 PM
16" 5 on 5 1/2 wheels - What tires? Benjo Tires 10 02-15-2010 07:41 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
Wheels and Tires Fordstream Tires 4 01-12-2006 09:51 PM
