03-05-2013, 07:40 AM
#421
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies...
, "...'Stream'n the Dream" thru the USA
I feel your pain, Dan! We went through the same episode last summer in Florida running Chinese GY Marathons... Dodged the bullet. Cheers,
Art
03-18-2013, 07:23 AM
#423
1977 31' Sovereign
1985 25' Sovereign
Sweet! Nice looking set, Steverino... Be safe.
Art
03-18-2013, 07:26 AM
#424
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Those are really sharp looking wheels!
Brain
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
03-18-2013, 09:13 AM
#425
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Very nice; our old GYMs needed air, so we just had to get the 16" wheels ... and they threw in an EB ... LOL.
03-19-2013, 09:13 AM
#426
1977 31' Sovereign
1985 25' Sovereign
Love it when that happens!
Good one! That EB should go well with that new air! Hehehe...
03-19-2013, 08:01 PM
#427
2018 30' Classic
Ivins
, Utah
That's the way to do it! straight from the source!
03-20-2013, 07:21 AM
#428
2007 27' Safari FB SE
LONDON
, ON
Just wondering what air pressure people are using with the new tires.
03-20-2013, 08:59 AM
#429
2013 27' FB Classic
Clermont
I run 80lbs
Tom & Lori
2013 27 FB Classic Limited
2019 Ford F250 King Ranch 6.7L Diesel
WBCCI 03288 TAC PA-17
03-20-2013, 11:56 AM
#430
Moderator dude
1966 26' Overlander
Phoenix
Max
>>>>>>Action
03-20-2013, 07:22 PM
#431
Master of Universe
2008 25' Safari FB SE
Grand Junction
There is considerable disagreement about air pressure. Some run 80 lbs. in Load Range E tires—that is the maximum cold pressure for those tires. One member's rationale is that is makes the sidewalls stronger and on a trailer that is extra important.
I was running 68 for a while, but I found the tires were wearing as if there were a little too little air in them, so I upped it to 72. Seems fine now.
Some run 65 (max for a Load Range D tire) and some run even less because they want a soft ride. But too low means overheating of the tire and that leads to tire failure. How low is too low? That is not known to me, but if you check the weight for each tire and the tables for that particular tire, you may find out.
Gene
Gene
03-20-2013, 09:04 PM
#432
Santa Rosa Beach
I have been running 72 psi in Lucy's Michelin 16's since I got them nearly 40,000 miles ago. It seems to work well. The trailer is still in one piece, and the tires are showing virtually no wear.
Brian
03-20-2013, 09:07 PM
#433
2004 30' Classic Slideout
Fenton
, Missouri
I'm running 80.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
03-20-2013, 09:49 PM
#434
2012 25' Flying Cloud
Battle Lake
I've run 80 in the Michelin 16", but will drop to 72 for a softer ride as we tend to load the trailer lightly, and seldom travel in hot weather.
My concern after the last long trip is the worsening condition of roadways in the country, which are also a major reason for using the Andersen hitch and a rear coil spring Ram 1500 truck.
doug k
03-20-2013, 09:57 PM
#435
1991 34' Limited
Wichita
, Kansas
I think that 80 PSI is quite a bit high. Take a look at the pressure chart that Michelin provides for RV tire use found here Michelin North America RV Load & Inflation Tables.
The chart states that you should weigh each end of the axle and use the higher of the two weights for the recommended tire inflation pressure for that axle. Let's say that you have 225/75R16 Load Range E tires with a two axle trailer that weighs 7,200 pounds. Let's just be a little conservative and say that all of the 7,200 pounds is carried by the trailer axles, none by the tow vehicle. OK, to make this example straightforward, we'll assume that the weight is equally distributed on all four wheels or 1,800 pounds per wheel. According to the chart, we should inflate the tires to between 45 and 50 PSI, cold (Single Wheel on each end of the axle). So, 80 PSI is too much and will give the trailer a rougher ride plus over time the center of the tread will wear more than the outsides due to this over-inflation.
Steve
03-21-2013, 03:05 AM
#436
hang up and drive
2010 30' Classic
Carlisle
, Pennsylvania
I average around 70 psi, never less than 65-68, never higher than 75. After 10k, not much appreciable wear, and a smooth ride.
Point of order though, I do keep my spare at max pressure (80 psi), as it is ALWAYS easier to remove air on the side of the road to match the other three tires than to add it. Gives me a margin with which I'm comfortable.
Kyle
2023 Ford F350 Lariat 7.3/4.30 FX4 CCLB
2010 Classic Limited 30
ProPride P3-1400
03-21-2013, 03:23 AM
#437
1976 31' Sovereign
Springfield
, South Carolina
My Chicom tires call for 80lbs and that is what I have been running. I have about 5500 miles on them with no visible wear. When I changed to the 5200 lb axles I measured tread depth with a caliper with depth probe and the wear between the front and rear tires is about .015 to .025 difference but then again the bottom of the grooves don't have a flat spot for the probe to contact. Visually I can detect no difference.
Over the winter she has been parked on 2X10 boards under a shed with tires completely covered. It won't be long before we take a short trip of a couple hundred miles for the upcoming season.
03-21-2013, 06:21 AM
#438
Corona
Excessive tire pressure just adds to the pounding of the trailer.
Just imagine fork lift tires.
At 80 PSI, those tires certainly DO NOT provide a soft ride for the trailer, that must be offered, OR ELSE.
There is far more to consider beside tire wear.
03-21-2013, 06:43 AM
#439
LONDON
, ON
Thanks all for the variety of replies. I'll probably keep them at 70-72 on our 2007 27FB with the 16" LTX tires.
03-21-2013, 07:23 AM
#440
2013 28' International
Bozeman
, Montana
Hi Andy, any recommendations on how to determine tire pressure that won't beat the trailer to pieces nor lead to tire failures? I have a new 28 International being built nest month with the 16" wheel/Michelin tire package. I'm sure the sticker from the factory will say 80PSI like others have reported. At 80, it can't be a smooth ride.
