02-26-2013, 04:39 PM
#401
2008 30' Classic S/O
Dearborn
, Michigan
Originally Posted by steverino
Question to those of you who have upgraded their late-model Airstream's 15" wheels to the 16" Sendel T03's -
Did you have to replace lug nuts and/or hub caps, or did you just re-use the ones that came off the 15" wheels?
thanks -
Steve
I reused the hub caps, fit perfectly, and look good to boot.
I jettisoned the OEM 'capped' lug nuts. They tended to deform under the lug wrench. Replaced with solid.
02-26-2013, 04:41 PM
#402
Dearborn
, Michigan
Originally Posted by ddruker
I just ordered Sendel T05's - T05-66655SM and Michelin LTX M/S 2's - LT 225/75 R16 E1. Will post pictures once I get them installed on the trailer. I like the machined insert in the T05 a lot better than the standard chrome hub cover on other wheels.
slick. I'd love to see pix of those installed.
02-27-2013, 06:44 AM
#403
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies...
, "...'Stream'n the Dream" thru the USA
Nice combo!
HI Dan,
Looks like a sweet combo! You'll like the performance of the Michelins. Nice pic of you and the kids - looks like the top of Half Dome, no?
Cheers,
Art
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
02-27-2013, 06:53 AM
#404
1977 31' Sovereign
1985 25' Sovereign
16" Michelins XPS Upgrade...
Originally Posted by Air Cruiser
We have a 1999 Safari which came with 14" wheels, and we went to 16" wheels/tires (5 of them including spare), we also changed out the axles at the same time and upgraded the brakes to 12" from the previous 10". As I stated on post #146 (I believe), I called the factory to check on amount of wheel well space, and was told all Safaris have the same size wheel well space. Since we had been told the factory was changing up to 16" on Safaris for individuals, we decided we could too. We went with the Michelin XPS, and have not regretted it -- the peace of mind is worth the cost.
Deb
Deb,
We've logged over 5,000 miles on our 16" wheel, tire, ceramic balancers, brakes, and axles upgrade since last September. You are right about the Michelins - you won't regret having made the upgrade, we sure haven't. Those tires really give us peace of mind as we're rolling down the road.
Be safe, cheers ,
Art
Art - W0ABX
'85 Sovereign 25'er
02-27-2013, 07:59 AM
#405
2022 Atlas
Homosassa
I ordered new solid lug nuts with locking lug nut for the new combo. I didn't like the original style lug nuts.
02-28-2013, 08:49 AM
#406
Master of Universe
2008 25' Safari FB SE
Grand Junction
We replaced the OEM lug nuts a while back with solid ones. When I was changing a tire years ago I wondered why the lug nut wouldn't tighten properly. The torque wrench said everything was ok, but the nut would wiggle. Then I found out the chrome was just a cap on the real nut underneath and they got loose and can sometimes fall off. I'd never heard of such a lug nut. How cheap does Airstream get with the parts they buy?
Gene
Gene
02-28-2013, 09:40 AM
#407
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
I'm still using the Lucy's OEM lug nuts and hub caps. You are correct; the lug nuts are kind of junky. Sometimes I have to wonder about Airstream when the put cheapo lug nuts on a big dollar trailer.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
02-28-2013, 04:42 PM
#408
1999 27' Safari
Palo Alto
I bought new solid lug nuts on Amazon - I was kind of frustrated they came in 10 packs when I needed 24 - I ended up buying a set of four locks to make it an even 24 - and the four locks cost almost as much as the 10 standard nuts.
I just ordered four new 16 inch Michelin LTX M/S 2's to mate up with the Sendel T05 wheels that are on the way to me. The best deal on the Michelins I found was $850 installed at Discount Tire, which is called America's Tire here in California. The same tires were just over $1,000 installed at Costco and over $1,500 at Les Schaub.
- Dan
1999 27' Airstream Safari + 2011 Mercedes GL 350 Turbo-diesel + 2021 Ford F150 Platinum Hybrid w/ 7,200 Watt Pro Power
02-28-2013, 07:12 PM
#409
2002 30' Classic S/O
Garden Valley
, Idaho
Amen on the stock AS lug nuts, they are a real POS. When I had my 3 blow outs on the road, I finally had to take a pair of Vise-grips to peel off the nut cover and expose the cheap little metric nut. It was a real PITA since the socket I had wasn't deep enough to grab it. For $20, I replaced every one with solid SS lug nuts made in USA. Now I ask you, is AS that stupid not to use solid lug nuts?
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
02-28-2013, 10:23 PM
#410
1999 27' Safari
Palo Alto
Woohoo! The UPS man brought me four new 16 inch Sendel T05 wheels tonight.
Below are pictures of the unboxing.
The wheels come with a fabric protector to protect the finish, kind of like a giant surgeons cap you would see in a hospital.
The wheels have a nice polished finish. I was scared my rather tall lug nuts would not fit under the hubcap, but it looks like I will be ok...
Here is the underside of the wheel. Various certifications and capacities are stamped into the casting.
And last, here is the wheel with the insert installed. Sendel includes a tool to remove the insert, which is press fit into place and seems quite snug.
Expect I will get them installed this weekend...
- Dan
03-01-2013, 08:20 AM
#411
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
They are gorgeous, Dan! I used a Sendel on my trailer when I did the upsize to 16" wheels/tires last year. After 6,000 miles with this setup I feel really good about the change. Plan to begin de-winterizing SilverLeaf in two weeks for some early Spring camping. I did put her up on jacks over the past 8 weeks. (Did a December trip to FL which was awesome...and reduced the number of non-use months!)
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
03-01-2013, 09:00 AM
#412
2008 27' Safari FB SE
Pfafftown
, North Carolina
Lug Nuts
Where did you find the stainless steel USA made lug nuts for $20? I've been looking at the McGard 64010 lug nuts on Amazon. They are $12.99 for a set of 4. I've got 4 wheels so I'll have to buy 24 nuts.
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2022 Ford F350 King Ranch, 6.7 Diesel, 4X4 (Big Red)
WBCCI 3823 - Unit 12 | AIR 48265
03-01-2013, 03:57 PM
#413
2004 30' Classic Slideout
Fenton
, Missouri
thanks -
Steve
I bought my wheels fro Tredit and had them supply the center caps, lug nuts, and wheel stems.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
03-01-2013, 05:46 PM
#414
2012 25' Flying Cloud
Battle Lake
thanks -
Steve
Ordered the Sendel T02 16" wheels because they are the same style as my original Flying Cloud wheels, no paint highlights. They came with new hub caps. We took them to Discount Tire for mounting with their new solid lug nuts, metal valve stems, and Michelin tires.
doug k
03-02-2013, 05:34 AM
#415
2015 27' Flying Cloud
2011 30' International
mooresburg
, Tennessee
Did you get the option of metal valve stems?
03-02-2013, 06:44 AM
#416
Garden Valley
, Idaho
This is a situation where Ebay is not your best source. I took one of my 2 piece lug nuts and went to a couple of local tire shops and found one that had all SS lug nuts made in USA for .60 each. I ordered 24 and had them the next day. That was when I still had my stock 15" setup. When I switched to the 16" Lt's, I continued to use them. On my first trip with the new T03 rims, I stopped at 30 miles to tighten and again at 100 miles, after that I check once in a while but they are staying tight. Another thing I purchased was a battery powered Sears impact wrench and lug nut socket set. Worth every penny.
Pap
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
03-02-2013, 09:25 AM
#417
2017 23' International
Ridgefield
Metal valve stems are important especially if you use tire pressure monitors.
03-03-2013, 10:44 AM
#418
1999 27' Safari
Palo Alto
- Dan
03-04-2013, 06:59 AM
#419
1977 31' Sovereign
1985 25' Sovereign
Those new wheels really "make" the rig... Congrats, Dan!
Art
03-04-2013, 09:50 AM
#420
1999 27' Safari
Palo Alto
Thanks Art.
It's double win - a lot safer / less disaster prone and they also look a lot better.
It was not fun to deal with tread separation on my old wheel / tire combo in the middle of Idaho last summer - had to limp to Idaho Falls at 30 miles an hour - for almost three hours - stressing out the whole time that the tire was going to completely blow, dealing with being passed by tractor trailers blaring their horns at me and blowing by at 65, etc.
- Dan
