Old 09-22-2010, 05:09 PM   #15
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by Bluto View Post
For those of you that have done the switch to 16 inch rims and tires, have you had any problem stowing the spare 16 inch in the rack under the trailer?
I too have considered and almost bought into the 16 inch rim and tire. I think it's a good idea, but I wouldn't want to create another problem by having to stow the spare in the bed of the truck.
I can verify with confidence that the 16" wheel/tire combo fits comfortably on the factory spare tire carrier for a 1968 Airstream.
Your new model should also be compatible. The 68 had plenty of space.
Uwe
www.area63productions.com
Old 09-22-2010, 07:20 PM   #16
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by moosetags View Post
Thanx a bunch. I'm getting getting a whole lot of good information.
Brian
Brian,
I think you need Z rated tires
I have been using the marathons for 80,000 miles. I cought one with a bubble in the sidewall before a trip. I wore the rest out.
Michelle TAC MT-0
Sarah, Snowball
Old 09-22-2010, 07:48 PM   #17
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Originally Posted by thecatsandi View Post
Brian,
Michelle,
I went to the Goodyear website and could not find any info on a z rated Marathon. Do you have any further info or leads?
Brian
SuEllyn & Brian McCabe
Old 09-22-2010, 08:21 PM   #18
Keymar , Maryland
Michelle,
Brian
It was a joke.... Z rated tire have the highest abaility to shed heat. Heat is the usual suspect in tire seperation. There are others like workmanship and punctures from road hazards.
Michelle TAC MT-0
Sarah, Snowball
Old 09-22-2010, 09:49 PM   #19
2010 27' FB Classic
N/A , Texas
Thanks, that puts that question to bed.
Old 09-22-2010, 10:31 PM   #20
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Bluto, the question just got out of bed. A 1968 tire carrier must be larger than a 2008. The 15" fits snuggly, the 16" won't unless you bend back each of the side pieces that hold the tire in. So it can be done, but…
It is difficult to get the tire out and I'm sure it's no enjoyable task getting it back in. I threw it into the pickup bed. Easier to check air pressure too, and takes a little weight off the tongue. You may not want to put the tire in the Suburban. So, the tire carrier can be adapted.
I have read on the Forum that some trailers don't have the necessary clearance to go to 16". Measure carefully and often. If the wheel cutout isn't big enough, it appears it can be solved. We feel safer using the 16" Michelins and that means a lot. And we very rarely have to add air to the Michelins; we had to do so with the Marathons every several days. Lucy will like the ride.
Any good tire shop can make the changeover. I'd check with Airstream to get the exact wheel specs for your trailer. Sometimes you can find that info on their website if you look long enough. The offset is important and you have to make sure the wheel dealer knows what their doing. At least one Forum member was sold the wrong offset. It's 0˚ for ours, but yours may be different.
Gene
Old 09-23-2010, 06:14 AM   #21
SteveH's Avatar
Common Sense , Texas
I've been told by Airstream "Old Timers" that a person can limp in a few miles at slow speed with only one tire/wheel on a side in an emergency.
If this is in fact true, why would a 15" spare not work with a set of 16" wheels/tires? I mean, a spare is not normally used for long, and it would solve any storage issues with the 16" spare.
Regards,
Steve
Old 09-23-2010, 07:16 AM   #22
moosetags's Avatar
I was under the impression (maybe wrongfully so) that when you go to 16" wheels and LT tires that you use 225/70's vs the 75 height that you use with the 15's. This would make the overall tire heights within an inch of each other. Is this not correct"
Brian
Old 09-23-2010, 07:54 AM   #23
Master of Universe
Gene's Avatar
My tires are an inch more in diameter, raising the trailer 1/2". We use the spare to rotate with the other tires. Thus the set of 5 should last 20% longer than a set of 4. I don't know what happens when you have smaller tire on—does it change how the axle works, carry less weight thus putting more on the other tire on the same side? When you have only one tire on one side, the remaining one is carrying twice the weight, so you can't go very far that way.
Gene
Old 09-23-2010, 08:05 AM   #24
SteveH's Avatar
Originally Posted by CrawfordGene View Post
My tires are an inch more in diameter, raising the trailer 1/2". We use the spare to rotate with the other tires. Thus the set of 5 should last 20% longer than a set of 4. I don't know what happens when you have smaller tire onódoes it change how the axle works, carry less weight thus putting more on the other tire on the same side? When you have only one tire on one side, the remaining one is carrying twice the weight, so you can't go very far that way.
Gene
Gene,
I believe you are right on all counts, but keep in mind, most people I know, myself included, take the best of the four tires of the trailer at tire replacement time, and use it as a spare. It usually never touches the ground again, but is there for use in an emergency. Most trailer tires are replaced because of age, not mileage (a few of us long distance travelers excepted).
Yes, one tire would be carrying all the weight if used by itself, and that secario is only recommended as I said, "for a few miles in an emergency". My use of a spare is just that, an emergency.
Regards,
Steve
Old 10-07-2010, 10:36 AM   #25
moosetags's Avatar
After Lucy's last tire problem (tread separation) up in Maine, and waiting five days for a new ST tire to be shipped in, we have decided to make the switch.
I saw an ad in the October issue of BLUE BERET where Airstream is advertising 16" wheels with both Goodyear and Michelin LT's. I called Jackson Center this morning and priced the two options. I spoke to Chris Burch in the Service Department and got a quote for 5 new 16" tire/wheel combinations. The quote for the 5 Michelins was $1,893.31 including mounting, balancing, and sales tax. The tires are Michelin M/S LTX LT225/75 R16, Load Range E. The wheels included in the package are styled aluminum 16" wheels. The Goodyears are only slightly less at $1,811.45 for the 5 tire/wheel package.
We have about decided to do it and go with the Michelins. We just use Lucy way too much to be plagued with constant tire problems.
Brian
Old 10-07-2010, 01:27 PM   #26
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Time to re-tire
Brian,
I have 20,000 miles on my 16" Mitch LTX's.
They are wearing very well and the tread looks like new.
I mounted them on 16" stock steel rims, I picked them up at Discount Tire, this way I have service around the country.
I paid around $1,300.00 for five with steel rims.
I am also using Centramatics.
ArtStream is offline   Reply With Quote
Old 10-07-2010, 02:44 PM   #27
2010 27' FB Classic
N/A , Texas
Brian
I was doing some comparisons and number crunching. When calling around I found out that Michelin has a $70. mail in rebate for 4 or more tires. It's good till Oct. 16th, if this help you. You could probably just get the form on line.
Also checked here at Discount tire for the same 5 Michelins you are getting at A/S and they are $1146.68 out the door includes tax, balance and metal high pressure valve stems. That's minus the rims, so rims are costing about $150 each at A/S.
I have been considering the switch too and will be at JC in the near future. I'm still on the fence as my rims and tires are new.
If I only had a buyer for the 15's. Hmmmm.
Old 10-07-2010, 07:11 PM   #28
Master of Universe
Gene's Avatar
Bluto's price quote on the Michelins sounds about right. I think you can get wheels for less than $150 each. The Discount Tire website should have wheel prices too. The LTX tires are the same ones we have. I'm sure you'll be happy with them. Mooses love them too.
Gene
16" tires, ltx
15" to 16" Wheels/Tires on 2007 Safari Rollertoaster Tires 53 01-23-2011 06:41 AM
Wheels and Tires shepherd57 Argosy Motorhomes 7 08-09-2010 07:14 PM
16" 5 on 5 1/2 wheels - What tires? Benjo Tires 10 02-15-2010 07:41 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
Wheels and Tires Fordstream Tires 4 01-12-2006 09:51 PM
