Old 03-27-2011, 08:39 PM   #141
HowieE's Avatar
Princeton , New Jersey
Images: 12
You are correct about the limits of the control arms but the discussion here is the installation of larger diameter tire. I have new axles on my trailer with 16 in. E range tires and the clearance while one of the axle is compressed is not generous.
Another thing to be mindful of is the wheel offset. Airstream uses a zero offset wheel as original equipment. The wheel commonly used to replace them when purchased not from the mother ship has a 1/4 in. offset which is about the limit for fender clearance especially on a tri axle when making a hard turn.
2004 Excursion 4x4
Old 03-27-2011, 08:42 PM   #142
2005 28' Safari
Originally Posted by moosetags View Post
Here is a better photo of the clearance on Lucy.
Brian
What brand are the rims and where did you purchase them?
Paul...
PaulAir is offline   Reply With Quote
Old 03-27-2011, 08:44 PM   #143
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I'm not sure what the brand is. I purchased the 16" wheel/Michelin Tire package at the Airstream Factory in Jackson Center.
Brian
SuEllyn & Brian McCabe
Old 03-27-2011, 08:58 PM   #144
2006 30' Classic
Milton , Florida
Wheel Offset
If you are using Dexter NevRLube wheel bearings, then a zero offset rim will lead to premature wheel bearing failure.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 03-28-2011, 04:40 AM   #145
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Brian
I found both styles of wheels sold at the factory at Tredit. I also priced ordering the wheels from them and buying the tires locally and it wasn't any cheaper than buying them from the Jackson Center and having them shipped. YMMV.
Old 03-28-2011, 02:41 PM   #146
1999 25' Safari
Somewhere , Ohio
FYI, I called Jackson Center (factory) and asked whether there would be enough clearance for us to go from 14" to 16" wheels (changing out axles too), and I was told that all Safaris, irregardless of year, have the same amount of space in the wheel well. I thought someone else might be wondering about this. So, my thinking is that the factory is changing out relatively new Safaris from 15" to 16" wheels, so finding out that they all have the same amount of available wheel well space enlightened us to the fact that we can safely change ours from 14" to 16".
However, someone above mentioned offset on the wheels -- I know nothing about this.
Also, the new axles are 12" rather than 10", does that change the equation?
Thanks.
Deb
Air Cruiser is offline   Reply With Quote
Old 03-28-2011, 03:09 PM   #147
2006 30' Classic
Milton , Florida
Never Post When You Are Tired
The above post should read "If you are using Dexter NevRLube wheel bearings, then a non-zero offset rim will lead to premature wheel bearing failure."
F. A. Meloy
2006 30' Classic
Old 04-12-2011, 02:47 PM   #148
Wayne&Sam's Avatar
Images: 21
I finally installed my new 16" wheels. They fit just fine in the wheel well and the spare also fit the carrier.
ID:	126802   Click image for larger version
Old 04-12-2011, 03:31 PM   #149
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
Data plate
Does anyone know if Mothership is issuing new data plates when they change folks from 15 to 16 at the factory, or if they change data plates when folks upgrade their axles there?
I wonder if JC would do that or not, or perhaps there may be some federal law that prevents them from doing that unless the modified/upgraded units undergo testing?
I upgraded mine to 16s a few years ago, have the axles next on the list, and would like to upgrade the data plate on the carrying capacity and tire PSI recommendations to match...
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 04-12-2011, 03:45 PM   #150
1985 31' Excella
Fresno , Texas
Thats a close fit to the trim molding.
Until you have a blowout or tread separation and rip the wheel well molding out along with the belly wrap.
Wsmith is offline   Reply With Quote
Old 04-12-2011, 04:19 PM   #151
Wayne&Sam's Avatar
Images: 21
Well the difference between 15" and 16" won't change the destruction.
Old 04-12-2011, 04:35 PM   #152
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
That happens all the time with the 15" also. A half inch on both sides of center don't make a difference.
newroswell is offline   Reply With Quote
Old 04-12-2011, 04:43 PM   #153
moosetags's Avatar
I think that 15 inchers are just about as likely to cause body damage as 16 inchers if there is a catastrophic tire failure. The only difference is that catastrophic tire failure is probably quite a bit more likely with the 15 inch ST trailer tires.
Brian
Old 04-13-2011, 01:53 AM   #154
2005 19' Safari
GLENDALE , AZ
I second Moosetags' opinion. The tread coming completely off a 15-in Marathon did a pretty good job of tearing up the trim on our wheel well. And, while I suspect tread separation on a 16-inch tire would do about the same damage, I think it's extremely less likely to happen with the Michelin XPS Ribs we are now running.
Just a guess, but with both OEM Marathons and one of two Maxxis 15-inch ST tires failing from tread separation, all less than two years old and with less than 10,000 miles on them, that's a 75% failure rate, which translates to a 25% chance that these ST tires WON'T fail. Without any data on the XPS Ribs at all, that's a pretty low bar to clear; and I suspect that about any major brand LT tire could beat a 25% reliability rating.
I don't recall ever reading about any XPS Rib failures on this forum, at all (maybe a slow flat from a nail?).
16" tires, ltx
15" to 16" Wheels/Tires on 2007 Safari Rollertoaster Tires 53 01-23-2011 06:41 AM
Wheels and Tires shepherd57 Argosy Motorhomes 7 08-09-2010 07:14 PM
16" 5 on 5 1/2 wheels - What tires? Benjo Tires 10 02-15-2010 07:41 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
Wheels and Tires Fordstream Tires 4 01-12-2006 09:51 PM
