Old 01-02-2014, 11:45 PM   #169
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Actually this was a local drive from a town about 20 miles away. I flew over two days before to Indianapolis and then drove the next day to Ohio. The unit goes to Arizona for delivery and the tires and wheels are in my storage unit there.
Old 01-03-2014, 12:25 PM   #170
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Switz
I understand that you are upgrading to disc brakes. What actuator, caliper and rotors are Airstream using?
Dan
Old 01-04-2014, 07:29 AM   #171
switz's Avatar
2014 31' Classic
Images: 8
For some reason, they require me to return with the TV to retrofit the disk brakes.
The Control actuator has the Dexter brand on it and is part of the Dexter disk brake conversion kit I have seen on the Dexter website. The factory would like to install the controller in an outside access storage cabinet in the trailer. The brake fluid filler opening is on the top of the cylinder, which might make filling it a challenge in a tight space.
I am contemplating repurposing the original battery box for that job as a different box is contemplated for the four or more life-line 300-amp hour batteries that will be part of the solar system.
Old 01-11-2014, 03:33 PM   #172
2004 28' Classic
austin , Texas
For the Sendel wheels - are the T02, T03 and T05 all OK?
We have a 2004, 28ft Classic, that needs new tires, and we are going to go to the 16" wheels and the Michelin LTX M/S2 tires. I have studied the forums, and am feeling more confident about how to go about this (I have learned more about tires than I ever wanted to know!) - but before I order the wheels, I want to be sure I am getting something that works.
I see that many have installed the TO3 that is in the lobby at JC. But others have chosen the T02, and one forum member put on the T05s, which come with a center cap. I can't find anything that says one of these is better than the other in terms of its functionality. Is there any reason to choose one over the other, besides looks? Here is what I have figured out:
The prices aren't very different.
All three are labeled #66655, and meet the following specs:
16x6
Bolt circle 6 x 139.7 (same as 6 x 5.5)
Zero offset
Center bore 4.25
The only difference I can identify, other than looks, is that the T02 and T05 have a load rating of 3200, whereas the T03 is listed at 3580. It would seem that the lower rating is ample for our trailer however (GVWR 8600) and the Michelin tires we are going to buy. Is that right?
As long as I am asking, here is what else I am planning on ordering, based on hours of reading on the forum (I am grateful to so many for sharing) - please tell me if I have gotten something wrong.
We found a locally owned tire shop that will order the Michelins and install them on the trailer, balanced, with metal stems, for less than the Costco price for just the tires and mounting on the rims! Best of all, the shop is right down the road from where we store the trailer and they weren't flumoxed at all by the request to put them on the trailer.
We will get new stainless lug nuts and install Centramatics.
I think I am going to order the TST tire pressure monitoring system, with the external sensors. I am assuming we can install that ourselves.
At this point, we are going to keep our existing 15 inch spare. I know there is a lot of debate with regard to the wisdom of that....but for now that is our decision.
Is there anything else I need to think about?
Thanks again for your help.
Ntex is offline   Reply With Quote
Old 01-11-2014, 06:19 PM   #173
switz's Avatar
2014 31' Classic
Images: 8
The factory recommended lug nut torque value is 125 to 130 foot pounds for the SenDel T03-66655T wheels.
Be there when the conversion is done to ensure they do not put floor jacks under the axles which can bend them. I carry/use a 3 ton combination bottle jack and jack stand and lifted our 2013 25FB International Serenity on the frame member between the two tires when I swapped out the GYM for 15" Michelins one pair (side) at a time..
http://www.toolsmithonline.com/produ...ack-Stand.html
Old 01-12-2014, 07:13 AM   #174
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I just did what you are contemplating a couple of months ago. I had a local tire shop order 16" wheels and michelin tires for our 2005 Classic 30.
They couldn't provided Sendel wheels, but I don't suppose there is anything magic about Sendel. The wheels I got have identical dimensions and are rated 3200# and they are a design I quite like.
I had the wheels/tires balanced, and had metal stems fitted.
I already had the Centramatics and an external TPMS when using my 15" wheels and am using them now with the 16" wheels.
I was a little concerned about how they might jack the trailer and so I was present at the time and I raised one wheel at a time for them using Lynx leveling blocks under the adjacent wheel - that is how I generally remove a wheel.
I'm sure everything will go fine for you!
Brian.
PS - I did originally ask them to order stainless lug nuts for me, but I checked with a magnet when I got home (I ordered a couple of spares.) I'm pretty sure they are just chromed steel!
They are still a lot better than the ones I had that had loose metal covers on them. I will see how they stand up and if they rust I'll buy stainless. At least they only charged me $2 each for them, I imagine stainless are quite a bit more!
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-12-2014, 12:18 PM   #175
2004 28' Classic
austin , Texas
Thanks for the encouragement. As a woman who in the beginning knew nothing about all of this, with a husband who was too busy to do the rather frustrating searching through all the relevant threads, I really appreciate all the input. I will try to be sure the tire shop raises the trailer up correctly. Others mentioned being sure to use the "jack points" and I am guessing the manual might indicate where those are, but with the method explained above, no jacking is required? We have only owned the trailer since last spring, and haven't yet traveled much, so have not had to change a tire. I see some others have a Camco ramp that looks handy.
I am ordering the wheels and taking them to the tire shop...so I am going with the Sendels because it sounds like most people have been happy with their quality. Switz, I understand your torque number comes from JC, but I read one thread that indicated the correct torque was 100, and another that referenced 110. So that is confusing, as is the question of optimal tire pressure. I am persuaded that overinflation isn't good for the trailer, under-inflation isn't safe, that the 80 psi listed for the tire is probably too high, and that the exact sweet spot probably requires weighing the loaded trailer. What a mess...I have no firm conclusions on that yet. Can I just say that I didn't know owning and enjoying an Airstream would require so much technical know how. Sometimes I wonder if a lot of people do OK without it. Ignorance is bliss and all of that.
Old 01-12-2014, 12:26 PM   #176
switz's Avatar
2014 31' Classic
Images: 8
To make things almost idiot proof in terms of changing a tire or having someone else change a tire, this tire ramp concept can allow one tire to lift the side of the trailer for a quick change of the flat tire. It won't work too well if both tires are flat.
Amazon.com: Trailer Aid Tandem Tire Changing Ramp: Automotive
They are also available in black.
One must back very slowly onto the ramp as not much distance is covered from touching the ramp to going to far on the ramp and falling off the far side.
Old 02-03-2014, 12:08 AM   #177
2005 19' Safari
GLENDALE , AZ
Bridgestone Duravis R250 -- Anybody have these?
Just noticed that Costco now stocks Bridgestone Duravis R250 tires in 225/75x16, LR-E. Construction is similar to Michelin XPS Ribs in that they have an all-steel casing (sidewalls) with summer, highway tread pattern; and they are made in the USA. At around $208 each, plus $15 installation and disposal fee, they are about $60 less per tire than XPS Ribs.
See details, at this link:
Costco.com - Shop for Tires
Just curious, does anyone have these? If reviews are as good as the XPS Ribs, I might try a pair of R250's when our Ribs age out in a couple of years.
Note: Summer tread design and rubber composition may not be suitable for those who tow regularly in snow country. However, this tread design is great in the desert southwest, due to extreme summer heat.
Old 02-03-2014, 06:26 AM   #178
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
It is my choice for when I get around to upgrading tires/wheels on mine. The tread design is ideal from the standpoint of trailer service ("closed shoulder") as in-place pivots are what are terribly hard -- and unavoidable - for trailer service tires.
Granted, an open shoulder design may offer better braking in wet conditions. There are always trade-offs. But trailer anti-lock is now offered by the aftermarket (TUSON) with disc brakes which puts this "problem" where it is best corrected.
BRIDGESTONE and MICHELIN are the best tires available (in the correct model lines) in my opinion, for trailers and trucks for on-road service. That we may not run the miles posible in the time available is the real expense (high cpm), but for some of us the TT is home, not just recreational. For all of us the TT is expensive by relative measures so this seems not such a penalty considering the importance of reliable performance. Factored into the total time and distances made during ownership the additional cpm is then minor.
Old 02-03-2014, 09:17 PM   #179
1969 31' Sovereign
Jefferson , Colorado
Excellent knowledge of the subject and excellent questions.
grjanny is offline   Reply With Quote
Old 02-03-2014, 10:22 PM   #180
2008 31' Classic
Lake Charles , Louisiana
I installed my 16 inch Sendel wheel and BF Goodrich tires and am very happy with the quality and appearance. Clearance is good and now I have satisfaction of not being boarderline on tire capacity. I was happy with my Michelin LTX tires but now feel more comfortable with the 16's. Now I need to sell my original 15 inch factory wheels which have a set of Michelin LTX M/S 235's with little mileage.
Steve & Mary is offline   Reply With Quote
Old 03-07-2014, 11:54 AM   #181
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Use Jacking Pt on frame, don't raise one wheel
Using a ramp or lego leveling blocks is not okay by the axle mfr.
The Dexter Axle company provides an excellent field tech to some large RV rallies. Both of the past two Februaries he has done our brake service for me on my 25' International. I did it several times, am comfortable doing it, and am really happy to let someone else to it now and then.
He is most emphatic on the issue of supporting the trailer on one wheel while working on bearings or other work -- Do NOT support the trailer's entire side on one axle, it is not made for that and can harm that axle.
We attach the trailer to the TV and jack the trailer at the jacking point on the frame a foot or two aft of the rear wheel. It's marked with an aluminum square 2" X 2". Except for an emergency tire change on dirt at side of highway, the recommended lift is easy to do with a bottle jack rated at least two tons.
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 03-08-2014, 07:30 AM   #182
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Originally Posted by HeavyAssault View Post
I know what a TPMS is, just why use a TPMS?? Just for the ease of knowing the pressure without needed to physically check??
For the Centramatic balancers I know what they are/how they are used. Why not just get the wheels/tires balanced like your TV??
I ask these questions as I see plenty of posts about the subjects yet don't see where the benefits come into play.
Airstream (and SOB) owners are pretty much "gadget" oriented people. Especially us old geezers, who have way too much time on their hands.
One thing I've noticed on the forums, is that regardless of the question asked, there are usually opinions on either side of the arguement, some of them valid, and others out in left field. For what ever it's worth, I usually take the advice of the one that's closest to what I was going to do in the first place, and that is usually the correct route.
As for Centramatic balancers, I guess they're OK, but I don't think I would spend the money on them.
As for TPMS, if you've ever had a flat, and not known it, you'll see the value of the TPMS pretty quick. It will at least give you notice that you have a low tire, before it "comes from apart", and tears up the wheel well of your AS.
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
