Old 03-17-2013, 09:20 PM   #1
2010 27' FB Classic
N/A , Texas
16" spare tire vs OEM spare tire rack
I've been on the fence about changing from 15" to 16" wheels and tires but now I have decided to do it. I'll will buy the wheels now and the tires when a nice sale hits.
There is only one question left in my mind about the swap and that is, will the new 16" spare tire and wheel fit in the OEM tire rack on a newer trailer, as is, or is there a modification that needs to be done?
"Thereís two kinds of people, them goiní somewhere and them goiní nowhere. Andís that whatís true". -Ben Rumson
Old 03-17-2013, 09:26 PM   #2
SteveH's Avatar
Common Sense , Texas
I switched to 16's, but kept the 15" spare. It's a spare, and will work for that.
Regards,
Steve
Old 03-17-2013, 09:29 PM   #3
2010 27' FB Classic
N/A , Texas
Thanks Steve but I want to change out all 5 and just wondering if the 16" will fit the rack before I commit to the swap.
Old 03-17-2013, 10:13 PM   #4
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Figure the new tire diameter is 1" larger than the old diameter. You can put your old one in the rack and see if there is room for a 1" larger diameter tire.
So Long!
Bob Thompson is offline   Reply With Quote
Old 03-17-2013, 10:42 PM   #5
2010 27' FB Classic
N/A , Texas
Bob,
Don't know why I didn't think of that.
Old 03-17-2013, 10:45 PM   #6
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I moved to all 16" wheels and it was necessary to bend the rack slightly to accommodate the larger wheel/tire combination. This was NOT a big deal. It's nice to know that if one of my Michelin LT's does go flat there's a "sister" tire aboard to replace it...
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 03-18-2013, 06:43 AM   #7
Alumitater's Avatar
2007 25' Safari
Spanish Fort , Alabama
spare tire rack
We made the switch last year to the Michelin 16's and have been very satisfied. No pressure loss coupled with Michelin's reputation (as opposed to the reputation of Marathon tires) make for a nice ride. We did replace all five tires and the 16 fit our spare tire rack....a bit snug, but it fit with no modification. Make the switch when you can, you will thank yourself in the long run. Ours came from the factory when they had the winter 10% off sale. Cheers!
Tom and Robin
2007 Safari 25' FB Twin
"If you have to go through a minefield....follow somebody"
Alumitater is offline   Reply With Quote
Old 03-18-2013, 06:55 AM   #8
2008 25' Classic
Sometimes it's Heaven , USA
Mine made it in the rack with a16" Michelin XPS Rib and a Sendel wheel that matches the ones on the ground.... It was snug as I recall, but with the RIBS I don't plan on putting it in there very often... The Michelin tires are a lot heavier than the Junk Goodyear ST 15" Tires...
COUNTRYSONG is offline   Reply With Quote
Old 03-18-2013, 07:04 AM   #9
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We also went to five 16" wheels/tires almost three years ago. The new spare fit in Lucy's OEM under-tongue rack without any modification.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 03-18-2013, 12:18 PM   #10
2010 27' FB Classic
N/A , Texas
I appreciate all the good info.
Now to just pick out the style I want and order.
Old 03-18-2013, 01:10 PM   #11
SteveH's Avatar
Bluto, Just one word of caution....When I was looking for wheels, I found lots of truck wheels available in the size I wanted with the correct bolt pattern, but none of them had the required 0 offset, so watch for that spec.
Regards,
Steve
Old 03-18-2013, 01:12 PM   #12
2013 28' International
Bozeman , Montana
I'm having Airstream install the 16" wheel/tire package on my yet to be built 28 International. On the build sheet I received from Airstream it states as part of that upgrade to modify the spare tire carrier. I assume just little tweaking or bending out of the carrier is all that is needed.
HeadWest is offline   Reply With Quote
Old 03-18-2013, 01:49 PM   #13
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I replaced all 5 - 16" spare too. In MY spare rack, the bigger tire wouldn't fit until I bent the two upward prongs out slightly (I used the hanger hole of a 20" breaker bar to do the deed, although a 5 lb. sledge hammer might have worked too).
Paula
Old 03-19-2013, 11:00 AM   #14
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Kentucky
True. Mine were also done at Jackson Center and they simply had to open up the carrier a wee bit. That's all.
2019 Ford F250 XLT Premium 6.2/4.30 FX4 CCLB
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 04-18-2013, 03:49 PM   #15
2010 27' FB Classic
N/A , Texas
My 16" wheels are finally ordered and on their way. Thanks everyone for your comments.
Old 04-25-2013, 09:05 PM   #16
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
I did the 16" replacement and also got a steel rim and a "cheaper than a Michelin" spare, don't even remember the name but it was the same diameter as my new Michelins. The new 16" spare fit, snugly, but fit without a problem. I also did the Centramatics and am on my first 2,000 mile trip with my new 16" Michelins. Smoothest trip I have ever made with my AS. I think my mileage even went up a little.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 04-26-2013, 10:11 AM   #17
2010 27' FB Classic
N/A , Texas
I like your idea of using a less expensive tire on the spare. If a person doesn't plan to use the spare in rotation with the rest of the tires it makes $$ sense do it that way.
So far my 15"s are wearing true and I don't see the need to rotate the spare when I switch to the 16's. I may follow your lead and save some $ right out of the gate. Hope your observation about the fuel mileage is correct, that would definatly be a plus, no matter what the amount of increase.
Did you happen to read the recent thread about the Centramatics and the Dexter Neverlube bearings? If not, it might be worth it to look it up and decide about using the Centeramitics or not, if you have the Dexter Neverlubes on your trailer.
A warning in the Blue Beret started the discussion. If your trailer has regular bearings sounds like your good to go and no concerns in that regard.
Old 04-27-2013, 07:00 AM   #18
pappy19's Avatar
I do have regular bearings and all were re-packed along with one set of brakes replaced. I did see that article in the "Blue", but I really wonder about that. Most of the large vehicles using Centramatics have non-greasable bearings and there is no evidence or reports regarding the use of Centramatics causing damage. I just wonder how many Dexter Neverlube bearings were actually damaged due to Cantramatics or maybe poor installation of the bearing itself. When I repacked my bearings, 3 of the 4 seals from whomever did the last work, pinched the seals so they were not holding the grease. It was lucky I checked them. I would just like to see the "proof" if I did have the Dexter bearings, or maybe I would just switch them out to standard greasable bearings.
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
Old 04-27-2013, 11:07 AM   #19
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
When I converted from the GYM ST tires to the Michelin LTX (P) 235/75R15 XL, I used a 21" crescent wrench handle to bend the two tire edge rods on the tire support outwards slightly and the larger tire then fit easily on the tire carrier.
Old 04-29-2013, 02:08 PM   #20
albert's Avatar
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Tulum , Mexico
Send a message via AIM to albert Send a message via Yahoo to albert
Hi, did you install the Centramatics yourself? I am hoping to install the preset tires and wheels on my 1970 Ambassador MYSELF and want to know how the Centramatics install. The video on their website DOESNT help.
Thanks!
albert is offline   Reply With Quote
