Old 09-10-2016, 07:14 PM   #1
2014 30' FB FC Bunk
City , Maryland
16 Sendel bolt diameter
I am looking to upgrade to 16's on my 2014 30ft bunk. I have read all the forums but nobody talks about bolt pattern.
Stock rims are 15 x 5 on 5 but I can only find Sendel wheels in 16 x 5 on 5.5.
What am I missing? I am assuming they will fit since everyone seems to be going this route.
Help me understand.
Alumalarkey is offline   Reply With Quote
Old 09-10-2016, 08:41 PM   #2
2013 30' Flying Cloud
Everett , Washington
You may need to count again...They are a six bolt pattern.
I'm not sure what wheels you're looking at, I upgraded to Sendel T03-66655BM on our 2013 30' bunk.
My new wheel specs are size: 16x6; Bolt Circle: 6/5.5; offset: +0; centerbore: 4.25
I got new wheels in May from Discount Tire for $120 each. Also ordered the Michelins LTX MS/2 tires at same time and had them mounted. They were running several really good rebates at the time, so cost was around $1250 (rims and tires) after all the rebates.
Discount tire mounted tires onto rims. I mounted wheels and tires on trailer myself because I'm silly like that...I easily swapped the center cap from old wheels onto new ones. Sold the old ones on Craigslist in about a day.
Also recommend new lug nuts (stock ones are rubbish) and metal valve stems if you're going to use a TPMS. Ask me how I know!
Sorry more than you asked for...
Best,
Jeff
aka: big_big_trip (I don't know how to change my screen name on this forum?!?!)
Searun is offline   Reply With Quote
Old 09-11-2016, 08:05 PM   #3
2014 30' FB FC Bunk
City , Maryland
Sendel bot diameter
Jeff thanks for catching my error and great info. Enjoy your posts on IG.
Pretty much planning on the same but going with the all silver version.
I still am trying to understand how a 5 inch bolt diameter equals a 5.5. This is the engineer in me. 2+2 has to equal 4. I just want to make sure before I purchase everything. We are launching on our FT adventure Oct 19th and I don't have to much room (time) for error.
Thanks again and hope we can cross paths!
Old 09-12-2016, 02:05 AM   #4
2005 19' Safari
GLENDALE , AZ
16" wheel specs for most Airstreams:
Wheel size: 16x6
Bolt Circle: 6x139.7 (same as 6x5.5)
Offset: 0 (zero)
Center Bore: 4.25
Load Rating: 3,200# (min)
Old 09-12-2016, 11:13 AM   #5
2000 30' Excella
Greeneville , Tennessee
Buy Sendel T03-666555. I did.
jimfa440 is offline   Reply With Quote
Old 09-12-2016, 11:19 AM   #6
racoco's Avatar
1976 31' Sovereign
2007 19' Bambi
Midland , Texas
Tires?
So if you're upsizing to 16" Sendel wheels, what tire and size are you moving to?
Coco
1976 Sovereign & 75th Anniv Bambi
TAC TX-3
racoco is offline   Reply With Quote
Old 09-12-2016, 11:20 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
What he said^
The Sendel T03 wheels have been on my trailer for a year as of just before Labor Day.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 09-12-2016, 11:58 AM   #8
2011 27 FB International
Greely , Ontario
Hi Searun,
Saw your post about rims and have to ask, how do you know about metal valve stems? I recently installed TPMS on my rig and one of the tires now has a slow leak. Rims do not have metal stems. Could this be the problem??
Regards,
Norbert Cyr
roadtripr is offline   Reply With Quote
Old 09-12-2016, 07:21 PM   #9
2014 30' FB FC Bunk
City , Maryland
I am planning on going with T03-66655T & LT225/75R16 Michelin defender LTX M/S.
Directly from my owners manual for eveything other than 25ft
Size/Center Size In Inches 15x6 / 5 (NOT 5.5 or am I reading this wrong?)
Lug Pattern 6
Now I know the manual is incorrect regarding other items like the low point drains.
I guess I should just pull the wheel and measure it.
I don't know if a 30 ft classic is the same as a 30ft flying cloud etc.
Old 09-12-2016, 10:47 PM   #10
m.hony's Avatar
2013 30' Classic
The wheels, drums, hubs, bolt pattern would be the same on a 30' Flying Cloud and 30' Classic.
TAC #MS-10
Airforums #70955
Old 09-13-2016, 07:36 AM   #11
I gave up trying to figure it out and just went with what everyone else used...
Something that I also added when doing the wheels and tires were Centramatic Balancers. There are several threads here that discuss. Hard to tell if they've made a difference. I still popped a couple of rivets until I lowered the tire pressure to 70#. No problems since!
Old 09-13-2016, 07:46 AM   #12
Originally Posted by roadtripr View Post
Hi Searun,
Regards,
Norbert Cyr
I discovered that I should have gone with metal stems on the side of a washboard dirt road in De Smet, South Dakota. I simultaneously lost the stems on BOTH tires on the port (driver's) side of the trailer.
I upgraded to metal stems at the small garage in town after getting a ride from a guy... Upgraded STBD (passenger) side in Madison, WI at Discount Tire.
The Discount Tire guy that mounted my tires onto my wheels said metal stems weren't required with a TPMS (and my EEZTire brand TPMS doesn't specify in the manual), I learned the hard way. Feel much better now and haven't had any issues since. Discount Tire in Madison, WI swapped out the STBD side stems for free (I already had them).
Old 09-13-2016, 06:33 PM   #13
2014 30' FB FC Bunk
City , Maryland
Thanks everyone for all of the good info and guidance.
I talked to a tech at colonial today and he confirmed that the owners manual is indeed wrong.
Off to purchase!
Old 12-04-2016, 09:54 PM   #14
2010 30' Classic
Twentynine Palms , California
After listening to Vinnie Lamica in Calif. I am going to get Bridgestone Duelers 235/75/15. It's what he uses on his own AS. Much less expensive then buying wheels and tires.
deserthi is offline   Reply With Quote
Fresh water hose diameter BSalinger Winterizing, Storage, Carports & Covers 19 04-13-2013 01:29 PM
Need Drain Hose Diameter for Penguin ASAP BrockLives Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-04-2011 05:59 PM
7" diameter tail light back plates Rosemary Lights - Interior & Exterior 10 04-15-2011 05:56 PM
Zip Dee Roller and Slat Diameter? Silverfly Awnings 5 04-24-2007 05:53 AM
Adding an electric jack to 2005 Bambi -- what diameter? platbr Jacks, Stabilizers, Lifting and Leveling 1 09-27-2005 03:40 PM
