Old 03-24-2013, 02:11 AM   #1
2007 30' Classic S/O
Kenton , Ohio
16 inch wheel 7 inch width?
Has anyone used a 7 inch width wheel for their 16" upgrade? I was thinking about putting some eagle wheels on but they are 7 inch width.
Wiremanranch is offline   Reply With Quote
Old 03-24-2013, 09:20 AM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
You need to find out the minimum wheel width for the tire size you are contemplating as well as the offset of the wheel so things do not rub the trailer frame or skin around the wheel well.
Old 03-24-2013, 05:16 PM   #3
Kenton , Ohio
I have been looking very hard at the wheel mfg's. They are all made in China.Sendel; HiSpec. Wheel size: 16 x 6; 6 hole 5.5 bolt pitch; 0 offset. Tire's are Michelin LTX MS/2 225 75 16. I looked up Eagle Wheel they would work with the tire. Just checking to see if anyone is using Eagle Wheels.
