Old 05-18-2007, 09:06 AM   #1
ljmiii's Avatar
2006 16' International CCD
New York , New York
16' Bambi wheel questions - lug holes? Alcoa?
Someone asked me a question about upgrading their 16' Bambi and I'm missing some answers....
Does anyone out there know the width and lug hole distance on the 14" 5 lug wheels that come with the standard 16' Bambi? Are the stock wheels 14"x7" 5-4.5"s, 14"x8" 5-5.5"s, or something else entirely?
Also, I see that Alcoa makes 15" 5 lug aftermarket aluminum trailer wheels. Has anyone out there had experience with Alcoa wheels? Or know of any other good sources for 15" 5 lug trailer wheels?
thanks in advance,
leo
ljmiii is offline   Reply With Quote
Old 05-21-2007, 03:19 PM   #2
ljmiii's Avatar
New York , New York
The answer came courtesy of Airstream:
Originally Posted by airstream
The wheel is a 14 x 6 on 4.5 centers, 5 lug with no offset. I hope this helps.
Dick Deardurff
Customer Relations
So, if you want to upgrade the tires on your 16' Bambi from 215/75R14 LR Cs to 225/75R15 LR Ds without upgrading your axle you need a 15" wheel that matches the pattern above and has sufficient PSI and rim weight ratings.
I found one in aluminum at Eastern Marine - for details see below.
thanks and enjoy,
leo
Utility & Boat Trailer Tires / Aluminum, Galvanized & Painted Trailer Wheels
15" 5 on 4.5 Lug Aluminum Trailer Wheel
STOCK #: 1350116
Rim Pattern: Modular
Tire Diameter: 15"
Rim Width: 6"
Rim Finish: Polished Aluminum
Rim Weight Rating: 2150 lbs. @ 65 psi
5 lug on 4.5" Bolt Circle, 3-1/8" Center Hole
Price: $99.00
1961 Bambi '16 (Serial #16TDSS1728) Andy R 1961 - 1963 Bambi 28 02-27-2012 10:57 AM
Plastic Wheel Wells Dennis Interior Restoration Forum 14 01-17-2003 12:05 AM
Front wheel drive ?? ALANSD Airstream Motorhome Forums 14 08-25-2002 12:47 PM
Wheel Hub Temperature 74Tradewind Axles 4 07-23-2002 07:26 PM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
