Old 06-22-2014, 02:26 PM   #1
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
15 inch wheels
I currently have 15-inch aluminum wheels on my AS. I am having the axles replaced at JC and have decided to go to 16-inch wheels. If there is anyone interested in acquiring my five 15-inch wheels with ST225-75R15(E) tires (all current date codes), please let me know. Depending on whether I find a buyer now (my service appointment is July 21 at JC) or later will determine whether I do the wheel upgrade in July or November.
Please PM me if interested.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 06-22-2014, 03:27 PM   #2
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Would you happen to have a photo of the rims and how many miles are on the tires?
tsunami is offline   Reply With Quote
Old 06-23-2014, 06:36 AM   #3
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I'll photograph the wheels and post the photos later today.
As for the tires, all of which are ST225-75R15(E): 1 General Tire (0 miles purchased last month as my spare), 2 Towmax (purchased at JC Nov 2013), 1 GYM (purchased at JC July 2013) and 1 (Westlake, purchased October 2011 - had been my spare until last month). Tires are rated Load Range E, max cold pressure rated 80 psi, and I run them at 65 psi.
There are 5 rims, but only 4 hub covers, as these fit into the rim before the wheel is mounted, hence no need for a spare hub cover. Rims and hub covers are aluminum.
I travel about 12-15,000 miles a year with the trailer (TV runs 22,000 miles per year).
VE3JDZ
AIR 12148
Old 06-23-2014, 02:44 PM   #4
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The wheels could use a polishing (I know). Here is the photo - all 5 wheels are like this one - in good condition with no damage. Four have the center hub cover, which slips into the center hole before you mount the wheel.
VE3JDZ
AIR 12148
Old 06-23-2014, 05:05 PM   #5
rideair's Avatar
I'm insterested in the wheels, I'll PM you to get the details.
Paul Waddell
rideair is offline   Reply With Quote
Old 01-15-2015, 12:22 PM   #6
Bauxter's Avatar
1973 31' Sovereign
Columbus , Ohio
I have a 31' and frequently see wheels for 25's and 27's in the classifieds. How can I tell if those wheels are safe on a 31' from a weight standpoint?
Bauxter is offline   Reply With Quote
Old 01-15-2015, 01:26 PM   #7
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
If it's your vintage 31' listed in your profile, and you're buying 15" wheels from a recent wide-body trailer, odds are they have plenty of load-carrying capacity. The wheel's load-carrying capacity should be marked on it, the seller can provide you with that info.
David
Why 16 inch wheels? Lumatic Wheels, Hubs & Bearings 31 11-12-2013 10:30 AM
14 inch or not to 14 inch wheels.. busboy 1961 - 1963 Bambi 0 08-25-2013 09:19 PM
16 inch wheel 7 inch width? Wiremanranch Wheels, Hubs & Bearings 2 03-24-2013 05:16 PM
Upgrade to 16 inch Wheels and Tires ddruker 1999 Safari 3 03-04-2013 04:18 PM
Will Centramatics fit on these OEM 15-inch wheels? Phoenix Wheels, Hubs & Bearings 24 12-19-2010 03:49 PM
