Old 03-02-2014, 07:50 AM   #1
VtTim's Avatar
Santa Fe , New Mexico
15 inch rim for 1974 Argosy 22
When I bought my Argosy it had 3 rims that I assume are original and one that is smaller than the others. According to my manual I need 7:00 x 15. That's a 15 inch rim with a 7 inch depth, am I right? Why am I having such a difficult time finding one? I can find 6 and 5 inch depth just fine. Any suggestions?
Thanks.
VtTim is offline   Reply With Quote
Old 03-06-2014, 01:02 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
15 X 7 is a common size.
Not sure what you mean by depth. The 7 is - 7 inches from the outside of the rim to the inside of the rim. If it were mounted on the trailer (with no tire) the rim would be 7" wide looking at it from the front or rear of the trailer.
I would suggest a trailer store. Perhaps like this one. Trailers
>>>>>>>>>>>>>>Action
Old 03-06-2014, 01:09 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Also consider off set. You want zero if the wheels are stock.
Matching the 4 wheel dimensions with the other 3 will more important than anything else. If the other 3 are non-stock dimensions (and alike to each other) at least match the 4th to the other 3.
Or make sure all 4 wheels match the originally equipped dimensions.
15X7 6 hole wheels with zero offset and a 2600 # load capacity.
Given the picture above I would seriously question the integrity of that wheel.
>>>>>>>>>>>>>Action
Old 03-07-2014, 05:10 AM   #4
VtTim's Avatar
I had the wheel inspected and it is sound. Just rusty. I took a wire brush to it and put I a fresh coat of paint. It looks good as new
Old 03-07-2014, 06:54 AM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Wheels can be purchased from Vintage trailer Supply or Out of doors Mart.
Also any GOOD trailer wheel shop should have a 15x7 6 on 5.5 zero offset.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-19-2014, 04:56 PM   #6
JCPOTTERF's Avatar
1963 28' Ambassador
Danielsville , Georgia
The offset is important because it affects how far in or out the tire runs beside the frame and shock mounted between the frame and the rim of the wheel. Too close and the tire will rub the shock.
I tried a new Toyota Tacoma wheel witch fits the lug pattern good and the hub center as well but the offset towards the frame / shock leaves 1 inch clearance and the tire rubbed the shock but i'm looking for one with less offset . i'll let ya'll know if i find one.
JCPOTTERF is offline   Reply With Quote
Old 04-19-2014, 05:32 PM   #7
1981 31' Excella II
New Market , Alabama
You a need 6 bolt 5.5" bolt circle diameter 15" rim.
https://www.etrailer.com/dept-pg-Tir...c-15_Inch.aspx
Perry
Any interest in a US (mid west) Argosy salvage / repair yard? Sprouty All Argosy Trailers 3 08-09-2013 07:35 PM
Looking at 24 ft. Argosy crunch27 Member Introductions 6 06-09-2013 07:46 PM
1972 Argosy Exterior Refinish billymyers56 All Argosy Trailers 47 02-04-2013 09:18 PM
1974 Argosy 26' -- original rim / tire size austinringdi Tires 2 08-04-2011 05:28 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
