Old 01-10-2016, 11:09 AM   #1
2011 23' FB Flying Cloud
Boca Raton , Florida
14" vs 15"
I am thinking of switching to 15" tires and wheels. My AS now has ST 215 75R14 mounted on Alcoa wheels.
Is there an issue with clearance when changing to 15's? Any recommendation on new wheels and selling the OEM's?
Thanks.
bobgoldstein is offline   Reply With Quote
Old 01-10-2016, 12:29 PM   #2
field & stream's Avatar
2008 23' Safari SE
2007 Base Camp
Santa Ynez , California
We upgraded to 15" wheels on our 2008 23'. Here are two previous Forum discussions on this question, with lots of good info for you:
http://www.airforums.com/forums/f438...er-116941.html
http://www.airforums.com/forums/f516...fb-111316.html
field & stream is offline   Reply With Quote
Old 01-10-2016, 04:08 PM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Used 15" SenDel T03-56545T wheels to match our Classic 16" wheels in design and used Michelin LTX P 235/75R15 XL tires derated to 1,983 pounds for trailer use. Had to do some metal trimming on curb side front edge of wheel opening as it did not match the street side front wheel well opening on our 2015 23D.
Carry 44 psi pressure. Has larger tire print and softer ride than the ST tires.
Old 01-10-2016, 04:43 PM   #4
2008 23' Safari SE
2007 Base Camp
switz makes a great point about the fit within the wheel wells, and his need to trim one of the wheel wells to get the 15" wheels/tires to fit on his 23D. Our 23' trailer is not the Dinette version, but a discontinued corner bed model with the front L-Lounge and a different body, and we did not have to trim anything and have a great fit.
Someone with a 23 FB can help here with their actual experience on that model.
Old 01-10-2016, 10:09 PM   #5
Mission , Texas
14" vs 15"
Why not look at tire diameter - the original tire diameter and then find the approximate same diameter on a bigger wheel?
I did similarly on a pickup years ago. Wheels 2" larger diameter, tires no longer 78 profile. Fit in the wheelwells perfect, speedometer worked normal AND 3 more miles per gallon.
In reverse, the original size tires on our 75 Overlander had made contact with the wheel wells so when replacing them we got a tire of smaller diameter but higher rating.
nrgtrakr is offline   Reply With Quote
Old 01-11-2016, 12:53 AM   #6
interstateflyer's Avatar
2017 25' International
Los Osos , California
Did exactly the same on our 2014 23D. The trailer feels happier. It stops better, sits higher and Michelins are far superior to the Goodyears.
The trim on the door side wheel well had to be filed to bring the trim clearance from 5/8 to 1 inch. The street side was already close to 1". I don't believe that there would be any lateral movement of the wheels but 1 inch convinced my friends that I wasn't crazy.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
I want "Today's Posts" when I'm "logged in"! 66Overlander Forum Admin, News and Member Account Info 10 06-08-2004 07:32 AM
To "file" or Not to" file" Raptorrider2001 Our Community 3 04-14-2003 08:20 PM
