Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 06-01-2004, 11:00 AM   #1
64GT
64GT's Avatar
Profile:
Yikes! Trailer jumped the hitch!
We were returning from our first outing of the year, three blocks from home, went over a dip and the trailer came off the hitch! Luckily I had replaced the old jack or it probably would have snapped. There was a lock on the pin for the hitch and it was still locked. The carabineers on the chains need to be replaced. How did this happen? I've had the trailer for 3 years and we've been over the dip before!!? How could it come off when it was locked on? What do I need to do to insure it never happens again? I'm thinking I need to replace the locking pin mechanism??
Also the jolt destroyed the tie down for the propane tanks. Stressed the metal "teeth" and cracked it on both sides. Metal shop or are replacements available???
64GT is offline   Reply With Quote
Old 06-01-2004, 11:04 AM   #2
robandzoe
robandzoe's Avatar
Profile:  1958 30' Sovereign of the Road
1965 17' Caravel
Plymouth , New York
Images: 26
What size ball
What size ball are you using? Did the safety chains hold? Yikes, is right.
Rob
Rob, Zoe', Stanton, Bryce and Braedon Baker
WDCU 1st VP
Do you Listen to the www.theVAP.com
Plymouth, NY 13832 WBCCI #2820
Courtesy parking W/E Wifi
(607) 334 4960
58 30' Sovereign of the Road:
http://sweetsovereign.blogspot.com
65 17' Caravel
54 22' Safari
1959 Buick Electra
robandzoe is offline   Reply With Quote
Old 06-01-2004, 11:10 AM   #3
64GT
64GT's Avatar
Profile:
Ball size is correct. Safety chains did hold but the force of the sudden stop bend the carabineers and I needed pliers to get them unscrewed. I have a break away switch that would have activated if the chains failed. The only good thing out of this is that it happened on a quiet residential street and not a hiway filled with returning vacationers!
Old 06-01-2004, 11:13 AM   #4
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
Shocking! So did the chains catch it or did it land on the jack? We recently brought our Bambi home 300 miles without safety chains (I will correct that problem before we tow it again) and I was nervous the whole way - even though the previous owner towed it for ten years like that!
Also, do you have carabineers on the chains, or quick-links? I think the quick-links would be much sturdier, and they only take a few seconds to attach when hooking up.
Glad everything's allright!
Stephanie
Our family photo blog
Old 06-01-2004, 11:26 AM   #5
64GT
64GT's Avatar
Profile:
In theory the hitch should have landed on the chains but in actuality it landed on the jack and "skidded" to a stop. I'll look into quick-links since I need to replace anyway. I still don't understand how it could have popped off.
Old 06-01-2004, 11:53 AM   #6
markparker22
Profile:  1984 31' Excella
Santa Barbara , California
Hitch coming loose
If I had to venture a guess, your hitch was not connected properly to the hitch ball. I did this once towing my boat after a long day fishing, tired, and in a hurry to get home. I locked the hitch but it was not all the way down on the ball. After that I learned this safety procedure: When you lock/clamp your hitch to the ball, use your jack to raise the tongue once again. If the the jack raises the tow vehicle and hitch, all is OK. If not the hitch will pop loose!
Mark
1984 31' Excella, mid bath, king size bed
1998 Chevrolet Suburban K2500, 7.4L/454 c.i., 4WD, Pullrite Hitch
AIR No. 2375
"You know... life is just the way it is...."
markparker22 is offline   Reply With Quote
Old 06-01-2004, 12:01 PM   #7
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
this is part of the routine for connecting the spring bars...makes attaching them much easier, and performs an important safety check, as well!
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-01-2004, 12:12 PM   #8
64GT
64GT's Avatar
Profile:
That's a good idea, Mark. I can use it to check to see if there is a problem with the clamp too. I was the one to hitch the trailer up and everything seemed "normal". I've probably hitched it up at least 60 times without a problem. That's why I'm a little freaked out about the whole thing.
Old 06-01-2004, 12:40 PM   #9
Tripp
Profile:
Images: 55
64GT,
Wow, scary! Regarding your propane tank clamp, you can get a suitable replacement from just about any airstream dealer/repair shop. It might not be like the original, but will work. Had to replace the one on my 73. I was able to get an exact match-and it was new.
Good luck!
Tripp
Tripp is offline   Reply With Quote
Old 06-01-2004, 12:50 PM   #10
cosmotini
cosmotini's Avatar
Profile:  2008 27' International CCD FB
Highland , Illinois
Images: 83
Did you cross your chains?
I was told to do that so the tongue would be caught by the X if the hitch would come off.
Dennis
cosmotini is offline   Reply With Quote
Old 06-01-2004, 01:16 PM   #11
85MH325
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
I recently had this happen on a 1978 fiberglass camper I was towing at 65 mph. Fortunately I also had chains, and they kept the rig together until I got it stopped. It was scary indeed at that speed. Thank God it only weighed 1500lbs and my Excursion weighs 7000 lbs, there was no other traffic on the highway nearby, and it stayed on its wheels! I actually saw it jumping around, I never felt it in the Ex. It hopped around behind me, first on one tire then on the other until I got it slowed and stopped. And the trailer brakes didn't work as the pigtail came disconnected at some point during the trailer's post-unhitching antics.
Anyway, the trailer wasn't damaged past scraping the electrical pigtail up and grinding one of the chains off as I stopped. I got it back together and took it to a large RV dealer that was only a couple of miles from where it came apart. A post-mortem evaluation of the hitch coupler showed that the coupler mechanism INSIDE the coupler was worn to the point that it allowed the tongue to jump off the ball. I had to have the old 2" coupler cut off and a new one welded on. I don't know of any way to check this other than jacking the trailer back up after coupling it and seeing if it lifts the back of the tow vehicle.
It wasn't an expensive operation, less than $100 including parts and labor, but I sure felt more comfortable towing it home after that.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Old 06-01-2004, 02:57 PM   #12
Rog0525
5 rivets, 1 loose screw
Rog0525's Avatar
Profile:  1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
lube/replace hitch ball
IMHO most uncouplings of hitch and ball occur because of improper maintenance of the ball. There is a lot of friction on the ball and it is doomed to wear down in size with prolonged usage.
The wear can be minimized by keeping the ball properly lubed, but routine maintenance should include replacing the ball at regular intervals, depending on how often and how long you tow your trailer.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 06-01-2004, 03:40 PM   #13
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Nearly had the same experience moving the 59 overlander from home to office. I thought it was on the ball and locked in when in fact it had not locked. I routinely raise the truck with the trailer attached to check this with the caravel which has an electric hitch. Got lazy with the hand crank but fortunately I got out a double checked to find it floating. The hitch is very light because the trailer is empty in the front but not the rear. A little tricky fixing it on the small hill. Getting electric hitch sooner than I planned.
You would think someone would come up with a better system after all these years for the hitch or the backup safety chains.
Let those who can play, let those who cann't watch....
Over59 is offline   Reply With Quote
Old 06-01-2004, 04:54 PM   #14
Stefrobrts
Stefrobrts's Avatar
I think the Hensley has a good idea with all the hitch parts attached to the trailer so you just have to slide it into the receiver to hook up. However I understand there's a bit more to it than that, and of course I'm sure it has parts that wear out as well.
Stephanie
trailer hitch Happycampers For Sale & Wanted 7 02-09-2004 08:56 PM
Interesting Reese hitch experience... 85MH325 Hitches 25 07-30-2003 05:00 AM
How to choose a shock-absorbing Hitch ? femuse Hitches 4 02-26-2003 08:43 PM
trailer hitch height '68 Sovereign sectionc Axles 7 01-25-2003 08:11 PM
Trailer weights, hitch heights & more... ameeker Airstream Trailer Forums 1 06-25-2002 04:42 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
