Old 11-29-2008, 06:40 AM   #1
down south , South Carolina
WTB - spring bars
I am having trouble finding some light weight spring bars. No local RV shop has any used. Even having trouble finding where I could order some new ones. Need Reese/drawtite round-bar w/flat chain end.
Dieselgrin is offline   Reply With Quote
Old 11-29-2008, 07:43 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Try E Trailer
Trailer hitch, hitches and bike rack (800)298-8924
2004 Excursion 4x4
Old 11-29-2008, 07:47 AM   #3
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Try eBay, they have several for sale.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 11-29-2008, 08:09 AM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Try U HAUL they carry DrawTite and Reese. They can order for ya.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 11-29-2008, 08:13 AM   #5
Gael79's Avatar
1970 31' Sovereign
Lombard , Illinois
Hello,
I'am just wondering what size you are looking for. I noticed you have a 1973 31' Sovereign. I use 750 pound bars on my 1970 31 foot sovereign, and they seem to really do the job well. I was lucky because they were the bars I received when I purched the rest of my receiver used. Found mine on e-bay, but the guy was local.
Regards,
Scott
Scott
I have a picture of my Airstream in my wallet, and I'm sitting on it...
...If that's not love, I don't know what is!
Gael79 is offline   Reply With Quote
Old 11-29-2008, 08:24 AM   #6
Gael79's Avatar
1970 31' Sovereign
Lombard , Illinois
Just to add a quick thought...
My set up are the bars with the flat chains also (not the auto centering stirrup type). My set up, Reese, also has the friction brake that came with the receiver. I have never used the friction brake, because I don't experience any lateral (side-to-side) sway issues (I did physically attach it once, but never adjusted any friction to it). If the road I'm on has several dips in it, I do feel a slight vertical dipping (porposing), but I think that is more the shocks on my truck, than anything to do with the sway bars,
Best of Luck,
Scott
Scott
Old 11-29-2008, 09:29 AM   #7
Best of Luck,
Scott
Scott.
Try riding, as a test, in the absolute rear of your trailer while it's being towed 60 mph or more.
I think your opinion of no sway would change.
Let us all know your thoughts, after the test.
The Reese dual cam is far superior to the friction sway control. It has a brain, the friction does not.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-29-2008, 10:17 AM   #8
Gael79, I'm setting mine up for a Hensley that I picked up on Craig's List. I didn't have any bars with it.
For the size TV I have, Andy recommends 550 - 600 bars to give me a soft tongue. My truck is a 2500 Chevy PU 4x4. I wonder if that still applies to a HA? Any thoughts Andy?
I found 600# bars on etrailer for $130 plus shipping. I'm still looking for a better deal.
Old 11-29-2008, 10:39 AM   #9
Retired.
. , At Large
The 600 pound bars would be good, but I think the lowest rated bars available for the HAHA are 1000#.
You can go through the HAHA user's guide thread here on the forums, or call Jared at Hensley.
BTW, we have the Reese 750# dual-cam for our Sovereign, and 2500 Silverado.
Old 11-29-2008, 12:20 PM   #10
Thanks overlander. I had to exchange the 2" drop for a 6" drop from Hensley. Jared told me that they use reese/drawtite bars. Also talked with them about trying to fit Rock Tamers on the hitch. Suggestion was to grind down weld on plate cover or get extended hitch. I chose grinding.
Spring Bars: Round or Trunnion? Any opinions??? Geoffrey Hitches, Couplers & Balls 15 09-09-2009 09:07 PM
Are your wt. distributing (spring) bars bent? TomW Hitches, Couplers & Balls 22 10-21-2006 05:43 AM
Spring Bars Strong Enough? Navigator Hitches, Couplers & Balls 2 10-05-2004 08:48 PM
weight distributing bars/trunnion bars teutonik Hitches, Couplers & Balls 2 12-04-2003 06:58 AM
