Old 06-03-2011, 04:58 PM   #1
1976 Argosy 24
West Allis , Wisconsin
Who makes this hitch?
This hitch came from a 1996 Dodge Ram D2500, 4x4. I know Dodge used these hitches for many years. All the stickers on it are gone. I'm using it as an exact replacement to the one already mounted on the truck which is currently damaged and needs to be removed. I'm looking for parts for the hitch, the electrical box part, I need a new one welded on, the 7 pin connector mounts to it. Please see attached photos of the hitch for I.D. Any help would be appreciated. Hitch appears to be OEM from the factory or dealer. Electrical connections just plug right in no modification required.
ID:	131435   Click image for larger version
ID:	131437   Click image for larger version
btophek is offline   Reply With Quote
Old 06-03-2011, 06:10 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The trailer connector on mine is in the bumper, I think it started that way in '02. Why can't you pick up a mounting plate from your local RV dealer, and attach it to the receiver with a couple of self-tapping screws?
Old 06-03-2011, 06:53 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Any decent shop should be able to fab up the box for you without too much trouble. I would be surprised if the box was available by itself.
Aaron
WBCCI #XXXX AIR #2495
Hitch Ball for a Reese flyingcloud Hitches, Couplers & Balls 16 05-29-2011 10:28 AM
Hitch height Khulse Hitches, Couplers & Balls 1 02-26-2011 05:19 PM
Which Hitch to buy? jomondnv Hitches, Couplers & Balls 19 01-01-2011 08:22 AM
