Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 11-17-2003, 11:28 PM   #1
Navigator
Profile:
Which Weight Distribution Hitch to buy?
I'm confused. I see ads in this forum that advocate hitches that cost over $400.00. Sams Club has a weight distribution hitch (chain tensioner) rated for a tongue weight of 1000 lbs. for $89.00!! What am I missing?
Dick
Navigator is offline   Reply With Quote
Old 11-18-2003, 05:20 AM   #2
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
You obviously haven't checked out the Hensley Arrow hitch yet either www.nosway.com Hitches vary in quality and features. I would reccomend going with a recognized brand name, like Hensley, Reese, Drawtite/ Putnam, Equalizer. They have all been in business for many years and stand behind their product. I am not saying the one at Sam's Club is bad, but I would want to make sure I have some type of support after the sale on something as critical as a hitch. If you are towing a 6500# AS down the road my safety as well as your own is worth something. I pesonally have used the Reese and the Equalizer and like both of them. Currently I am using the Equalizer.
Aaron
Old 11-18-2003, 08:12 AM   #3
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Re: Which Weight Distribution Hitch to buy?
Dick
Is that the A-Car universal?
I have one on a Blazer. It does the job but the WD draw bars will not fit in it. I only pull a 3k trailer with it on just a standard draw bar.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 11-18-2003, 09:56 AM   #4
Leipper
Profile:
A hitch serves several purposes.
The most basic provides just a coupling point or a strong mount for a trailer ball.
A step up is a hitch that spreads out vertical loads - a load leveling hitch - so your steering wheels don't come up off the ground when you hook up the trailer.
Then you get into hitches that control horizontal forces - sway control hitches.
The cheapest sway control is usually a braking bar mounted to one side of the trailer ball. These cost about $100
The Dual Cam or Equal-i-zer are next. The Dual Cam can be added to many load leveling hitches for about $200. The Equal-i-zer is a complete hitch for about $400. There are also some other brands, such as Blue Ox, that fit in about here.
The next step up moves the pivot point forward to help control sway forces. The Pullrite at about $2000 uses a frame rail and rigging to move the pivot to near the rear axle. The Hensley ($3000) uses a connecting geometry to move the pivot far forward for small angles.
When you start getting to trailer weights that are more than the tow vehicle or lengths that are longer than the tow vehicle, hitches that improve handling by providing better control of both vertical and horizontal forces become very nice to have. But how far you go depends upon you personal preferences.
Bryan
Leipper is offline   Reply With Quote
Old 11-18-2003, 12:24 PM   #5
ke4pk
ke4pk's Avatar
Profile:
Images: 8
Smile
I use a Reese 1000# equalizer hitch . The trailer is a 1988 Excella 1000, 32", with a gross of 8300#.
I tow with a 1999 Chevrolet Z-71 K-1500 pickup and the weight distribution is within 60# of being exactly equal between front and rear axles on the truck.
Whatever you choose, take the rig to a truck stop with certified scales and check the setup. This will tell you how well you are set up as you will get the total weight and the weight by axles.
The cost for this is usually less than $10.
ke4pk is offline   Reply With Quote
Old 11-18-2003, 04:31 PM   #6
Navigator
Profile:
Wish to thank wahoonc, 59 Toaster, Leipper, and kep4k for your valued input. Think I'll go with a tried and proven American made brand hitch; although my big block Suburban pulled the trailer from MN to DE without weight distribution, and it went like a dream. With the complete rehab in the works, the added weight might very well require a better set-up. Thanks again for your support.
Dick
Old 11-19-2003, 07:46 AM   #7
linc54
Profile:  Dallas , Texas
The Hensley hitch is expensive, but in this case, you get what you pay for. It works as advertised, and comes with a 30-day send-it-back guarantee of satisfaction.
linc54 is offline   Reply With Quote
Old 11-19-2003, 08:56 AM   #8
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
Yes it is a good hitch but it cost more than my AS did! If I were towing a brand new or much newer unit I probably would have the Hensley. FWIW
Aaron
how works a weight distribution hitch remcolent Hitches 5 11-10-2003 07:24 PM
Recommendation on weight distribution hitch davidlaxson Hitches 30 08-31-2003 10:38 PM
Weight Distribution Question Randy Johnson Hitches 63 07-21-2003 11:57 AM
Weight Distribution newae On The Road... 9 07-18-2003 11:08 PM
Education on Sway & Weight Distribution John Our Community 7 01-28-2003 03:48 PM
test
