Old 11-28-2010, 09:07 AM   #1
2010 16' International
kittery , Maine
Which WD for Jeep/16': 600#, 800#, trunnion, round...
Towed my 16' home in October, on ball only, with 4-door Wrangler, took it slow and no problems. Parked for winter but want ready to install a WD hitch now. Airstream dealer recommend Reese 750# system (choices from Reese seem to be 600 and 800) -- so why not the 600# since my 16' is spec'd at 430# tongue weight? (yes unloaded.. but even loaded would TW jump beyond 600?) Sure, nice to have a little tolerance built in, but would 800# be overkill (or even unsafe?)
Trunnion, round, etc... which?
Tow vehicle is 4-door Jeep Wrangler Rubicon Unlimited (4,315# curb weight), rated at 3,500 lbs max towing weight.
Here's three I'm considering:
Reese 66541: 800# adj. high perf trunnion, no sway control
Reese 66153: 800# trunnion bar w/sway
Reese 67509: 800# HD round bar
amm3824 is offline   Reply With Quote
Old 11-28-2010, 09:28 AM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
get the dual-cam sway control.
You might want to consider the lighter bars if you do go with sway control, because that function will work best when the bars have some deflection in them when they're tightened. The stiffer bars won't deflect as much, if at all.
New England Unit Home
come check us out! There'll be a spring rally at Salisbury Beach...~30 minutes away. maybe a good "maiden voyage"...always good to stick close to home on your first time out.
Anyway, we'd love to have you join us.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 11-28-2010, 11:21 AM   #3
1986 31' Sovereign
Miami , Florida
600# more than adequate. As noted, you want some flex to prevent shock from the tow vehicle being transmitted into the trailer. Soft is good.
mike
16', jeep, reese
Spring Bars: Round or Trunnion? Any opinions??? Geoffrey Hitches, Couplers & Balls 15 09-09-2009 09:07 PM
Trunnion style vs Round bar WD Hitch ? Davis Hitches, Couplers & Balls 7 03-29-2008 03:01 PM
Reese round bar or trunnion? erock53 Hitches, Couplers & Balls 21 05-09-2007 10:28 PM
