Old 12-30-2010, 10:42 AM   #1
2016 26' Flying Cloud
2011 25' FB Flying Cloud
reno , Nevada
Which Hitch to buy?
I have purchased a 2004 25' Safari last month. I'm towing it with a 2011 Tundra 4.6. I have to purchase a hitch and not sure the right way to go.
I'm tending to lean toward the Reese SC hitch 600# vs the EAZ-Lift adjustable weight dist hitch. With the EAZ-Lift I will also need to purchase a sway bar. With the Reese, its all in one. I understand that the Reese makes less nosie also.
Any help would be appreciated...looking forward to getting on the road.
jomondnv is offline   Reply With Quote
Old 12-30-2010, 11:00 AM   #2
Wayward's Avatar
Cary , North Carolina
I went with what the Airstream dealer recommended. Reese Strait-Line, Trunnion Bar, with Dual Cam
I've no complaints about it and find it extremely stable in all conditions, pulling with the 1/2 ton and the 3/4 ton truck.
Pretty easy and fast to hitch and unhitch once you get used to it. WD bars do double duty as sway control. Not too expensive. Nothing to adjust once set up. It does "creek and groan" sometimes in very tight parking maneuvers as the bars slide on the cams.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 12-30-2010, 11:47 AM   #3
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
experienced?
Alot depends on the experience you have towing too. You should be reading all of the threads on hitches.
We highly recommend the ProPride. A little more money but well worth its extra cost. Easy to hook up and absolutely great!
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 12-30-2010, 12:04 PM   #4
aftermath's Avatar
Spokane , Washington
Between your two choices, I would go with the one that has the anti sway built in.
Now, to muddy the waters, have you considered the Equalizer? I like mine and when dialed in properly it makes very little noise. Way back when I got my first trailer the idea of using a pry bar to snap the chains in place just didn't appeal to me so I got an Equalizer. My Airstream came with the same hitch so I didn't have to try anything else. I have a similar set up to yours and my trailer behaves very nicely behind my Tundra.
Reese makes a very good hitch and many here like them. I don't think you can go wrong with either choice, Reese or Equalizer. If you have lots of money to spend, get a Hensley or a Pro Pride.
Like they say, just my $.02 worth.
aftermath is offline   Reply With Quote
Old 12-30-2010, 02:49 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I am towing a 25' with a Reese straight line and 800 lb bars. I like it a lot. With the Tundra that ought to be a good combo.
Old 12-30-2010, 03:03 PM   #6
JFScheck's Avatar
Rockville , Maryland
Images: 33
ProPride - why spend all that money on an Airstream and tow vehicle (let alone your families safety) and short change the connection between the tow vehicle and trailer?
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 12-31-2010, 06:43 AM   #7
Wayward's Avatar
None of the above hitches, nor most of the commercial available hitch setups, should be characterized as a risk to family safety when towing a 25' Airstream with a 1/2 or 3/4 ton pickup.
It is all about understanding the limitations of one's rig and driving accordingly.
Towing a 25' with a mid size SUV, might easily warrant investing 3x the money for the slight edge a Propride offers. I guess, by extrapolation of the "family safety" curve, one should dispense with these WD/AntiSway contraptions altogether and buy a seriously "safe" TV:
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 12-31-2010, 06:58 AM   #8
aftermath's Avatar
What Wayward said.
Personally, it rankles me a bit to read the message from those with PP and HA hitches that I somehow don't care about the safety of my family or others on the road. The insinuation that Reese and Equalizer hitches are hazardous (or at least, not safe) is a bit over the top.
If you have the money and you want to purchase a PP, then by all means, do so. Please keep the other comments to yourself.
Old 12-31-2010, 07:53 AM   #9
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
We have a 2005 Safari 25FB, named Lucy. We have camped in Lucy for 780 nights and have towed her 70,000 miles in all types of terrain and road conditions. We use a Hensley Arrow to tow Lucy. Yes, it is an expensive hitch system. I think that it is well worth the investment. I have never had the first anxious moment while towing Lucy in any conditions. Severe cross winds and passing semi trucks are absolutely meaningless. My Suburban 2500 tow vehicle is more susceptible to these conditions when NOT towing Lucy.
I have a big investment in Lucy and her tow vehicles. We use her a lot. When it comes to towing Lucy on the highway, I have a narrow comfort zone. Any trailer sway whatsoever is unacceptable.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 12-31-2010, 08:18 AM   #10
Dwight's Avatar
1999 34' Excella
Joshua , Texas
We started out using a Reese Dual Cam and then 10 years ago switched to a Hensley Arrow and it was worth the money as far as towing goes. We are on our 2nd Airstream and 2nd Hensley Arrow. If the ProPride had been a choice when we bought our current Hensley Arrow I may have gone that route.....the quality and customer service in recent years with Hensley have dropped a little in my opinion.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 12-31-2010, 09:55 AM   #11
JFScheck's Avatar
Images: 33
I have towed many different trailers, with many different weights and cargo, with numerous vehicles over my lifetime (from multi-horse 5th wheel trailers, race car trailers, some pretty big boats, all types of RV & Toy Haulers, even large aircraft when I was a young Naval pup)....
I have towed across our great country many times with my 10 month old "Airstream" this year (24,000 miles) through all types of weather (to include those crazier than normal gusts last year heading into Denver from Nebraska) - I have a "rock solid" feel at all times transversing up and over and back down all of the mountain ranges of North America and across the country via our freeways and small two lane roads.
Recently I have helped two fellow Airstreamers hook up their new trailers to their tow vehicles and give them some tips....
One was an Airstreamer who purchased a 23' International from a dealer in Irvine, CA and was using a Suburban 1/2 ton as his tow vehicle and "Reese" hitch - the other was a fellow Airstreamer who purchased a 25' Safari and was using a 2008 Dodge\Ram 1500 with a "Equalizer" hitch in Comanche, Texas.
After towing both vehicles with my friends and passing along some tips I picked up (many from seasoned folks on this forum), I was not comfortable with our final settings when towing their trailers. Now granted I am very comfortable with my tow package and how it performs... - Both times I asked them to tow my 25FB Classic Airstream with a TDI Touareg and ProPride hitch.
They both immediately recognized the differences in handling (especially in pre-staged "emergency lane changes" and slalom drills) braking, stability, air waves from various other vehicles, etc.
At my strong suggestion after I drove their tow rigs and then they drove mine - they both purchased upgraded hitches based on the "ProPride-Hensley" design - and are very happy - in fact amazed at the difference.
If you are happy with your tow package that's fine, but do a search on this board and you will find many people who were "happy" but are now "happier" with the upgraded hitches.
If you are sick of hearing folks express the benefits of the more expensive hitches then just move right along - for me I will continue to ask people to investigate any means to provide a safer, more enjoyable towing experience as well as pass along any information that I believe would be beneficial to my fellow Airstreamers.
**I Love U.S.A.**
Old 12-31-2010, 10:33 AM   #12
aftermath's Avatar
Truce?
If you are sick of hearing folks express the benefits of the more expensive hitches then just move right along - for me I will continue to ask people to investigate any means to provide a safer, more enjoyable towing experience.
Not wanting to make tons of enemies, let me tell you that I am relatively new to this board. In my other life with an SOB, I frequented a different board that was brutal at times. Some there came right out and said things like, "if you travel with your refrigerator on you are risking the lives of your wife and children!" Statements like this are hard to just take and then "move right along." Then there were the Prodigy brake controllers who said the same stuff, the 3/4 ton diesel drivers and, as always, the weight police.
Here is my point. The PP probably is a better hitch and would be advisable in many conditions. I have driven a lot of miles as well with my 25 ft. FB pulled by my 2008 Tundra over the North Cascade highway, the Siskiyous in Northern California and the Cascades in both Oregon and Washington. I have driven in very high winds in the plains of Eastern Washington and Oregon and the Columbia Gorge on both freeways and two lane highways all of which included interaction between 18 wheelers. I NEVER felt at risk nor have I ever experienced any sway or undue trailer actions. Driving my set up is and always has been an enjoyable experience.
I can not speak for others but for me, I do not feel that I am putting anyone at risk on the highways. If I had a 30 footer, I might not feel the same way. If I drove a smaller sized SUV with a unibody construction, I might go the way of a PP. But, I don't have either of these so this is where I am. The HA and PP are better hitches from all that I have read. If my setup was squirrelly on the road, I would be the first in line.
I am glad that you are happy with your choice of hitch. It is better, I am OK with that. I am also OK with those who say you need a big diesel to pull your Bambi. These statements are the ones that I can read and "then just move along." But when folks say that my decisions are putting the safety of my family at risk, it is harder for me to do so. I hope you understand this fine point.
Best wishes, and Safe Travels.
Old 12-31-2010, 10:33 AM   #13
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Exclamation You have the ability to avoid ranklement
Since we are on the subject of censoring others comments:
Perhaps you should ignore them if you don't agree or counter them with some reasonable argument other than it makes you feel bad.
After reading the definition of rankle, I think that is something you might want to avoid. If a particular member (including me)continues to rankle you with his comments, the forum has a tool that allows you to ignore all post from a particular member. That way the rest of us can read uncensored posts.
Ken
Old 12-31-2010, 10:58 AM   #14
Wayward's Avatar
I think pulling a 25' Airstream with a Touareg is pretty cool and that it can be perfectly safe and fun. However, if you do a search on that here, you will find many people who consider it unsafe to pull a 25' Classic with anything less that a 3/4 ton truck, let alone a lightweight SUV.
I may venture to say everyone here has made tradeoffs and compromises in setting up our rigs, including yours.
No one wants to hear that one of the many factors considered in setting up our rigs puts our family at risk.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
