Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 07-02-2008, 04:34 PM   #1
kfrere's Avatar
2008 31' Classic
Lenoir City , Tennessee
Which hitch for Excursion?
It has been recommended to me that I choose between a Reese Deluxe Trunnion Style Weight Distribution Hitch and a Hensley Arrow. I've been doing some research, but was told by a dealer of the Reese that neither the Reese nor the Hensley can be used on my 2005 Ford Diesel Excursion. That I need to contact Ford for a recommendation. This comment surprises me.
I will be pulling a 31' Classic.
If you pull with an Excursion what do you use?
thank you!
kfrere
knoxville, TN
kfrere is offline   Reply With Quote
Old 07-02-2008, 04:41 PM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
As long as the vehicle has the correct class receiver, I would not understand why you could not use any hitch you wanted to. I am a GM man and have no experience with the Fords.
If you can spare the bucks go with the Hensley.
If you want to save some bucks, look at the Equal-i-zer hitch. I had a Reese hitch with a Reese friction sway control on an SOB and did not like it. When we got the Airstream we went to the the Equal-i-zer and I love it. It is easy to hook up and disconnect and works great.
I am sure others will chime in on the issue too.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 07-02-2008, 04:44 PM   #3
ProPride Industries, Inc.
Sean Woodruff's Avatar
Holly , MI
thank you!
kfrere
knoxville, TN
I was the vice president of the orange company for 10 years and never heard THAT one before. It will work GREAT with that combo. Of course, it isn't the hitch I would recommend anymore...
ProPride Hitch
"The Most Advanced Generation in Trailer Sway Elimination"
Holly, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 07-02-2008, 04:50 PM   #4
Retired.
. , At Large
About the only reason I could think of not to recommend the Orange Hitch would be if the Excursion had Air Ride, and Auto Leveling.
Old 07-02-2008, 04:59 PM   #5
Holly , MI
It can still be used. The only reason I can think of is that there is a black hitch that offers upgrades and equivalent performance for less money.
ProPride Hitch
Holly, MI
Tu ne cede malis
Old 07-02-2008, 05:17 PM   #6
Vintage Kin
Fort Worth , Texas
There is some pretty good info on setting up the Excursion on RV.Net : RV.Net - The Leading RV Community, Club, RV Travel and Information Source for Recreational Vehicle Camping (azflycaster[?]) in re the suspension, etc; things related to making that TV a better one.
Old 07-02-2008, 05:19 PM   #7
_
pull with an Excursion what do you use?...
hi kfrere...
as i recall, bambi's bandit here is towing with an excursion AND a haha...
at least until the 2008 superduty is ready!
he made several suspension mods to the ex' but unrelated to the hitch.
search his posts or pm him...
and u can read about the orange blob from users here...
http://www.airforums.com/forums/f464...ide-26279.html
even with auto leveling or airbags the haha will work...
since the w/d is totally independent of sway control, it can be dialed way back as needed.
the ONLY situation i can imagine, where the haha wouldn't work with an excursion is...
IF the ex' has been LIFTED higher than available drop bars that fit either the haha OR the propride...
cheers
2air'
Old 07-02-2008, 05:49 PM   #8
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
Originally Posted by 2airishuman View Post
hi kfrere...
cheers
2air'
Hi kfrere,
2Air is correct, I have a 2005 Excursion 4x4 as well, and have used both an Equal-i-zer and Hensley.
I will say that the Hensley, by design, is far superior to the Equal-i-zer. The only drawback to the Excursion is the softer springs that Ford puts in, as compared to a F250 pickup. Its softer and therefore weight distribution is really important or you will be white knuckling it coming down a mountain pass at highways speeds with a light steering feel. The Equalizer never could get dialed in perfectly, probably because of the Excursion's huge 44 Gallon diesel tank. Full with diesel both the truck and trailer would act differently than with 1/2 tank.
I overcame the above with rear Airbags (set at 15 psi at all times) E rated tires @ 65 psi, aftermarket shocks (Rancho) and a Hensley. Perfect setup for me.
Also be aware that the rear sway bar is optional on 2005 Excursion unless you get the 4x4 trailer tow group, which will include Power heated manual telescoping mirrors and rear stabilizer bar. This makes a huge difference as well. If you don't have one, you can get a nice (31mm I think) from Hellwig, or take one off at a junkyard, or order a new one from Ford. If you do order one or take one from a junkyard, get one from an F250 or F350, as the stock one used on the Excursion was much smaller in diameter and less effective than the larger diameter ones. Hellwig is a nice good diameter product superior than the factory.
Here's a list of the mods I did on the Excursion:
Going back to your original question, yes you can use the Hensley with the Excursion. You don't need to go as far as I did, but just make sure you have the Excursion set right, and most any hitch will work.
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 07-02-2008, 06:07 PM   #9
TinLoaf's Avatar
2016 30' Classic
Trenton , Illinois
Images: 22
My Excursion towed a 31 foot Keystone for many many miles with the Reese Dual Cams and the setup worked admirably. When I got the Airstream the seller included an Equal-i-zer and it works equally well. It makes a little more noise but is a little easier to hitch up. Either would work just fine. I doubt you need to spend the big bucks for the Hensley.
I don't have any modifications to the Excursion. And you can't beat 14 mpg.
Steve
Steve
TinLoaf is offline   Reply With Quote
Old 07-02-2008, 06:12 PM   #10
kfrere's Avatar
2008 31' Classic
Wow! This is more information in a short time than I was able to find after hours surfing the net. Thank you! My Excursion does have the tow package because we bought it originally to tow a 25' boat, which it did nicely. Of course, that only weighed 5,000 - 6,000 pounds. We also have not lifted it in any way.
Next novice question: Is this Hensley hitch going to provide both weight distribution and anti-sway in the one device?
kfrere
Old 07-02-2008, 06:24 PM   #11
2015 30' Classic
Bluffton , South Carolina
Send a message via AIM to millcreek08
kfrere
I also have a similar 2005 Excursion diesel and I agree with Keystone. I tow a 25' Classic ( about 2000 lbs less than the 31 I think) with the Reese Dual cam hitch with no problems. I did upgrade the shocks with high performance after market which likely stiffens the ride a little but otherwise stock. Although I haven't completed any mountain descents. this rigs hauls great! Good luck and happy trails!
millcreek08 is offline   Reply With Quote
Old 07-02-2008, 06:34 PM   #12
Pull a 28' slide with our Ex diesel and use Hensley Arrow... love it and wouldn't use anything else.
Tom
Tom and Frank
Evanston, Illinois
2004 Safari 28 ft Slideout "Lucy" 4 HI CAMP
2004 Ford Excursion 6.0 PSD PWRSTRK,
and Brittany, the Nova Scotia Duck Tolling Retriever
PWRSTRK is offline   Reply With Quote
Old 07-02-2008, 06:43 PM   #13
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
'03 Excursion with Reese DC. Once properly adjusted tows great. Installed Hellwig rear sway bar and ditched the junk stock shocks for Ranchos.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 07-02-2008, 07:01 PM   #14
Holly , MI
The ProPride 3P will have up to a 12" offset available within two weeks.
I will also have it available for the haha but the over-center-latches will have to be changed to a shorter latch due to the wedges being closer to the hitch bar tabs. This will also move the effective pivot point more forward for the haha like it is with the ProPride 3P.
ProPride Hitch
Holly, MI
Tu ne cede malis
Old 07-02-2008, 07:23 PM   #15
Retired.
. , At Large
kfrere
Yes, both Hensley and Pro-Pride have WD and anti-sway in a single assembly.
Old 07-02-2008, 07:26 PM   #16
kfrere's Avatar
2008 31' Classic
I've been able to find some prices for the Reese, but not the Hensley or the ProPride. The people selling Hensleys seem to want me to call to get the price. I see the comments about the Hensley costing a lot more - what are we talking about exactly? Twice the cost as the others; three times the cost?
Old 07-02-2008, 07:31 PM   #17
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I tow a 27' Overlander with a F350 Crew/SW/7.3 liter Diesel . I have an older version of the Reese Dual Cam Straight Line. I use mostly two lanes roads when ever possible. With the hitch set up to balance the weight,between Steering,Drive,Trailer,I get no sway when meeting trucks of all configurations. I have also ran the Interstates with no sway problems. I have purposely drop the right wheels off the pavement and then back on without Sway.
I have seen the HAHA .not yet the Pro Pride which is the same configuration. While they are fine equipment I am sure .I have to stick with what works for me. Beside the several thousand dollar price tag is beyond my budget.
Follow what your budget can stand.
Roger
Mikethefixit is offline   Reply With Quote
Old 07-02-2008, 08:31 PM   #18
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Here is a thread you need to read thoroughly before buying a hitch for your Ex:
http://www.airforums.com/forums/f238...ion-36898.html
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
Old 07-02-2008, 08:32 PM   #19
DesertStream's Avatar
2018 33' Classic
Montrose , Colorado
We have a 2006 Excursion and use a Hensley. It works great!
-Virgil and Sheila
It is not down in any map; true places never are. ~Herman Melville
DesertStream is offline   Reply With Quote
Old 07-02-2008, 08:46 PM   #20
_
I will also have it available for the haha...
wow great info sean...
AND cross compatible too, THAT's cool....
-so what happen to the lame excuse offered (by the orange guy) that the RECEIVER would fail...
with a longer drop?
and will ALL the stingers ship at 12 or is this a new/extra option for users?
i ask because IF you need a really short drop (like 2 inches) why carry the extra mass from a longer chuck of iron....
...Next novice question:...
no offense intended kf', and you've gotten some very useful replies....
kevin and roger and i have also provided some valuable links to review...
with LOTS of the basic and advanced info u might want...
there are also good threads here on the reese, equal-eye-zer, and draw'em-up-tight-2-pull-rite brands....
the haha owner's manual can be downloaded and reviewed for insights as well, it is IN the user's guide....
the haha folks regularly have pricing discounts, so direct contact is the best way to find today's price...
or you can find a lightly used orange thing at discount on d'bay...
http://www.airforums.com/forums/f464...bay-32736.html
cheers
2air'
New (to me) '05 Excursion TV panabax Tow Vehicles 2 05-27-2007 12:47 PM
Mirrors for Excursion? Tom Randall Tow Vehicles 10 01-13-2007 02:11 PM
Excursion advice nilesrob Tow Vehicles 9 01-09-2007 09:23 PM
Help! Diesel Excursion + 28' Safari + Equal-i-zer hitch = rear sag? Bambi_Bandit Tow Vehicles 9 10-03-2005 10:14 AM
Hitch and brake controller recommendations for Excursion/28' Safari PWRSTRK Hitches, Couplers & Balls 15 08-17-2004 08:45 PM
