Old 09-02-2012, 03:51 PM   #1
Haoleman's Avatar
1972 Argosy 20
Lanesboro , Minnesota
Images: 20
Which Hitch Arrangement
I have an Argosy single axle 20'. I have a Ford F 250 Superduty diesel to tow it.
Do I need a stabilizer hitch or just a sway control? The tongue weight is only around 500 lbs and the truck is rated much higher.
Haoleman is offline   Reply With Quote
Old 09-02-2012, 03:59 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I would suggest that you check out the Andersen WD sway control system. Might just be what you need.
MICHAEL
Old 09-02-2012, 04:12 PM   #3
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
You probably don't "need" either. Although I would think the previously mentioned Andersen hitch would suit you well. Even a small trailer like yours can generate some sway in certain conditions. So sway control would make for a better driving experience. The problem with some of the combined antisway/weight distribution hitches is that they require a certain amound of WD to be in effect in order to generate the friction needed for sway control. That is not the case with the Andersen.
Ken
Old 09-04-2012, 10:36 AM   #4
You might need this site:
Largo, FL Trailer Hitch - 5th Wheel Hitch - Trailer Parts
john121 is offline   Reply With Quote
Old 09-04-2012, 11:44 AM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I have no idea what you "need". I am pretty sure a Reese St Line with 600 lb bars will pull it fine though. As will most hitches. And I would set them resonably loose, to just put a little weight back on the front axle.
