Old 03-31-2016, 01:13 PM   #1
2018 25' Flying Cloud
Hillsboro , Oregon
which ball for BX Sway Pro @ rvupgradestore?
Hello,
I am going to order a Blue Ox Sway Pro 750 from RV Upgrade Store. Which ball should I order with it?
https://www.rvupgradestore.com/Hitch...show=28&page=1
Jason
Roguegaston is offline   Reply With Quote
Old 04-01-2016, 10:56 AM   #2
Hillsboro , Oregon
This is for a 2016 Flying Cloud 19C Bunk.
Jason
Old 04-01-2016, 12:35 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
2 5/16
MICHAEL
Old 04-01-2016, 03:30 PM   #4
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Interesting question. Seems simple enough, but .....
Go to the Blue Ox site - http://blueox.com/trailer-towing/swaypro/
The balls listed are
P# BX88213 2-5/16 x 1-1/4 x 2-1/4 x 1 ris (assume this is rise)
P# BX88214 2-5/16 x 1-1/4 x 2-1/4 x 2 ris (assume this is rise)
P# BX88234 2-5/16 x 1-1/4 x 2-1/4 x 1 ris 25K (Assume this is a 25,000 lb capacity
Interesting from several issues.
Do 2-5/15 balls come with a different size shank than 1-1/4 x 2-1/4?
What is the capacity of the standard BO Ball? Have to check that.
What rise did the dealer install on the BOSP for us? (edit - std-0 rise)
Will an alternate rise help us level the trailer? At least it's an alternative to check.
Really like the idea of a 25K ball - talk about belt and suspenders. Wow!
Every day is a learning experience. Travel safe. Pat
PKI is online now   Reply With Quote
Old 04-01-2016, 03:36 PM   #5
Hillsboro , Oregon
Thanks for the info.
I am now considering a Eaz-lift Camco Recurve R6 (600lb). It comes with a ball and looks even easier to work with.
Thanks again,
Jason
Old 04-01-2016, 03:44 PM   #6
PKI
PKI's Avatar
Thanks again,
Jason
Believe that is the same or similar to what CanAm suggested. Does that unit require the addition of a friction brake sway device or does the recurve model control sway with the spring bars like the BOSP? Pat
Old 04-01-2016, 03:51 PM   #7
Hillsboro , Oregon
It looks like the Recurve R3 control sway with a friction collar on the rotating head unit. It looks like the Recurve R6 controls sway with two springs/balls/sockets that work to center the rotating head unit.
Jason
Old 04-02-2016, 01:24 PM   #8
PecanMan5's Avatar
2015 25' Flying Cloud
Hahira , Georgia
If you have the small shank, the BluOx kit has a spacer. You have to the socket for it though. As for as up or down type, ask BluOx.
From my Pecan Tree
PecanMan5 is offline   Reply With Quote
Old 04-02-2016, 05:31 PM   #9
Longboard6's Avatar
Sacramento , California
I'll be selling my BO set up (1000 #bars) dealer installed for our 2015 23' FC, hardly used.
"Cheap ain't good in hand grenades or parachutes."
Longboard6 is offline   Reply With Quote
Old 04-02-2016, 06:25 PM   #10
Frederica , Delaware
Yes the 2 5\16" does come in 1" and 1 1\4" shanks. The different diameters have a good difference in capacities. Is there a standard, no it varies among manufacturer. I know 2" balls have different threaded lengths. I don't recall seeing that in the 2 5\16".
Overloaded is offline   Reply With Quote
Blue Ox Sway Pro W/D System Ganglin Towing, Tow Vehicles & Hitches 46 01-07-2017 08:17 PM
Which is better? A sway control hitch or a vehicle with sway-control? Lucky Strike Tow Vehicles 27 08-13-2015 05:34 AM
Equal-i-zer Sway Control Hitch vs Blue Ox Sway Pro airstreampek Hitches, Couplers & Balls 31 06-18-2014 10:56 PM
Reese Pro Series SC WD/Sway control tetstream Hitches, Couplers & Balls 3 06-28-2011 09:20 PM
