Old 03-28-2011, 05:03 PM   #1
R n B
King O D Road's Avatar
1965 17' Caravel
1961 24' Tradewind
Ephrata , Washington
Where to store your equalizer bars?
I got tired of cleaning the grease out of the back of the suburban from placing the equalizer bars inside and no room in the trunk of the coupe and did not like to clean the dirt out of the grease from laying them on the ground, so decided on a place to store them when not is use.
ID:	125590   Click image for larger version
King O D Road is offline   Reply With Quote
Old 03-28-2011, 05:55 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I'm going to make you feel very stupid...
The holes in the knobbed (removable) end of the bars go into the posts sticking up from the snap up brackets for storage at the campsite. They don't take up as much room that way, they don't interfere witht he LP tanks, and nobody gets grease on them or their tow vehicle.
Old 03-28-2011, 05:56 PM   #3
RichardT's Avatar
That is cool
They actually have a hole in the end that fits onto the bracket to store them while parked.
RichardT is offline   Reply With Quote
Old 03-28-2011, 07:07 PM   #4
R n B
1965 17' Caravel
1961 24' Tradewind
Wow! Overlander63, I suppose that information was in the instruction manual I have never read. I appreciate your reply and would not have gone to all the trouble if I had Known that before making the stands. Tried it out and it works fine. Thanks again, Roger
Old 03-28-2011, 07:18 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
If you saw Roger's rig you would be amazed at what he's done with/for it...all the customization and just plain cool stuff. It is truly a gem... We were truly inspired. I'm sure the bar stands will get lots of attention from fellow admirers!
We have Equal-i-zer bars and there's no good place to put them. So Greg made bright yellow vinyl sleeves for them...so we can store them in the truck bed or underneath the trailer without getting them dirty or everything else greasy...and he put a flap the length of the sleeves with grommets along them so we can also use them doggie tie-downs...they are so heavy that we can clip the pups to them and they really keep them where we want them. We also use them to put at the edge of the rug if it's windy...keep it from rolling up in the breeze (that's why they are bright yellow)...
TB & Greg and Abbey Schnauzer
#3954
Old 03-28-2011, 10:30 PM   #6
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I have a draw-tite wd hitch and there is a tubular metal bracket on either side of the A frame that the spring bar slides into. The chain ends are near the coupler and I lock them together with the safety chains to prevent theft.
4RXLA is offline   Reply With Quote
Old 03-29-2011, 08:15 AM   #7
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
Sorry for the crappy looking photo, but the only one I have of ours is the original pics we took when we bought the Airstream (now it's all painted and restored). At any rate I believe this would be what dougsale is referring to (as we do the exact same thing with ours -- lock them up front).
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): http://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: http://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 03-29-2011, 08:43 AM   #8
2010 27' FB Classic
N/A , Texas
I'm trying to picture this in my head but, no use. Now I feel really, really stupid.
Do you have a picture you can post of how you use the snap up bracket to aid in the storage of the bars?
Old 03-29-2011, 08:50 AM   #9
There is a hole in the trunion end of the torsion bar. The trunion end is the part that goes into the ball mount.
That hole accepts the very top of the "snap up" bracket, which is the part the sticks up in the air, that you use with a small pipe to load the torsion bars.
Old 03-29-2011, 08:55 AM   #10
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Grease? Who uses grease? Isn't the idea of the bars is to create friction?
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 03-29-2011, 09:04 AM   #11
The idea in the case of Reese torsion bars, is to create "torsion", not friction.
Hence the name, torsion.
Old 03-29-2011, 09:16 AM   #12
2010 27' FB Classic
N/A , Texas
Thanks Andy, now I understand.
Old 03-29-2011, 09:29 AM   #13
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
Wow, I never knew this. Can someone post a picture? ... I'm not near my AS and unable to envision this.
UAPachyderm is offline   Reply With Quote
Old 03-29-2011, 09:30 AM   #14
HCR
HCR's Avatar
Livingston , Full time traveler
Exactly what parts are intended to be "greased" on the equalizer hitch?
Airstream of Consciousness
HCR is offline   Reply With Quote
Survey: Where and how do you store? Jammer Winterizing, Storage, Carports & Covers 54 10-12-2011 03:56 PM
Newbie looking for airstream to convert to retail store Cowdeevas Dollars & Cents 1 03-25-2011 07:57 AM
Lets talk Hensley 1400lb spring bars and grease fittings mikeb9550 Hitches, Couplers & Balls 0 03-20-2011 10:18 AM
Tundra w/ Equalizer Hitch Booger12 Hitches, Couplers & Balls 11 03-01-2011 11:42 AM
1200# bars too much for my set-up? Camp Hitches, Couplers & Balls 17 02-01-2011 02:13 PM
