Old 03-29-2011, 10:04 AM   #15
Originally Posted by HCR View Post
Exactly what parts are intended to be "greased" on the equalizer hitch?
In the case of the Reese torsion bars, you can lube the top and bottom of the 'trunnion" which is the part that goes into the ball mount. You can also lightly lube the saddle of the dual cam sway control.
Old 03-29-2011, 10:21 AM   #16
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I have what Exthemius has.
4RXLA is offline   Reply With Quote
Old 03-29-2011, 10:28 AM   #17
casa3805's Avatar
Corpus Christi , Texas
Images: 41
I read this and yes I felt a little silly. Part of being new to this with an older trailer and no manuals I guess. But I immediately walked outside to the shed, grabbed the bars and sure enough they stand right up on there just like Andy said. I am trying to attach pics but no guarantees there....
ID:	125668   Click image for larger version
Name:	connection point.jpg
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 03-29-2011, 10:40 AM   #18
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
With the Equalizer you grease the end that goes into the hitch head. That end is locked in place, but does make a lot of noise and will wear faster without grease.
To store the bars I took 4" PVC, cut to length, glued cap on one end, and have a cap that can fit on the other. I don't bother with the removable one because it's hard to get on and off and the bars don't slide out. In fact, I have to grab one with a Channel Locks to get it out, the other comes out easily. To keep the pipe from rolling around the back of the truck, I made a small wooden box to put the Channel Locks, hitch head and any other hitch parts. I used large pipe clamps to secure the box to the pipe. I'm sure a better solution could be created, but this works for us.
This helps with the grease problem, but grease does love to migrate to my hands and clothes anyway.
Gene
Old 03-29-2011, 12:18 PM   #19
Ottawa , ON
Originally Posted by Antique Pedaler View Post
Grease? Who uses grease? Isn't the idea of the bars is to create friction?
Greasy friction = torsion.
Old 03-29-2011, 12:20 PM   #20
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
Well, I learned something new today!
UAPachyderm is offline   Reply With Quote
Old 03-29-2011, 12:34 PM   #21
casa3805's Avatar
Images: 41
I know, right. I was just laying them on the ground under the tongue or laying them in the bed of the truck. Neither was a satisfying option. Gotta luv the forum....I see the pics made it so I may have learned something else too...how to post pictures.
Chuck & Skye
WBCCI 3805
Old 03-29-2011, 01:20 PM   #22
I didn't have a clue! For years have been putting them in the back of my Yukon or on the ground under the front of the trailer.
Old 03-29-2011, 01:30 PM   #23
Ottawa , ON
Me needer! You learn something new every day. I've just been carefully tossing them under the A-from or front of the trailer!
Old 03-29-2011, 01:34 PM   #24
2010 27' FB Classic
N/A , Texas
The pix turned out fine.
Were the bars pretty stable mounted that way?
I wouldn't want them to fall and crease the stream.
It looks pretty stable from the pix.
I'm glad Overlander63 brought this to our attention.
Old 03-29-2011, 01:54 PM   #25
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
I just plain love the bar holders the original poster made...tell me more about how you made em will you please?
Rollerboy is offline   Reply With Quote
Old 03-31-2011, 07:21 PM   #26
casa3805's Avatar
Images: 41
Bluto,
Yes they are very stable. They do move a bit but I think if the two chains were pulled together and linked with a small clip they would not move at all. Pretty clever storage technique actually.
Chuck & Skye
WBCCI 3805
Old 03-31-2011, 07:28 PM   #27
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I never knew what that hole in the end of the trunion bar was for .... pretty neat! but I think I'll still keep putting the bars in the back of my pickup. They're lots less likely to wander off when they're out of sight and locked up, methinks.
AirsDream is offline   Reply With Quote
Old 03-31-2011, 08:36 PM   #28
Klatawa (to travel)
Klatawa's Avatar
1965 24' Tradewind
Bremerton , Washington
Roger-
You got me thinking about where to store our bars (we have an Easy Lift). One more of your great ideas to borrow/steal and a new project for Dave. Got to keep the guy busy.
Klatawa
(Dave & Debbie)
1965 24' Tradewind
1965 Chev Carryall
http://s1237.photobucket.com/albums/...ind%20Rebuild/
Klatawa is offline   Reply With Quote
Survey: Where and how do you store? Jammer Winterizing, Storage, Carports & Covers 54 10-12-2011 03:56 PM
Newbie looking for airstream to convert to retail store Cowdeevas Dollars & Cents 1 03-25-2011 07:57 AM
Lets talk Hensley 1400lb spring bars and grease fittings mikeb9550 Hitches, Couplers & Balls 0 03-20-2011 10:18 AM
Tundra w/ Equalizer Hitch Booger12 Hitches, Couplers & Balls 11 03-01-2011 11:42 AM
1200# bars too much for my set-up? Camp Hitches, Couplers & Balls 17 02-01-2011 02:13 PM
