Old 09-20-2010, 09:27 AM   #1
1970 27' Overlander
Amarillo , Texas
Red face what size hitch do i need
I am pulling a 71 land yacht with a 2001 chevy sub.. what size hitch do i need? We bought a 1000 lb. but the thing is so heavy i have to drag it.
thanks for your help, Teai
momszoo2 is offline   Reply With Quote
Old 09-20-2010, 09:28 AM   #2
1970 27' Overlander
Amarillo , Texas
it is a 1970 sorry
Old 09-20-2010, 09:36 AM   #3
What brand hitch did you purchase?
Old 09-20-2010, 09:41 AM   #4
r carl's Avatar
Lin , Ne
A hitch like this can be carried in pieces.
Old 09-20-2010, 09:46 AM   #5
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Here is the dry weights listed for the 1970 Overlander model. The first number (ex. 4515) is the dry weight of the Airstream. The second number (ex. 450) is tongue weight also a dry weight. The third number (ex. 19) is the ball height.
1970 OVERLANDER DELUXE LY 27 TWIN 4515 450 19
1970 OVERLANDER DELUXE LY 27 DOUBLE 4565 460 19
1970 OVERLANDER INTERNATIONAL LY 27 TWIN 4525 455 19
1970 OVERLANDER INTERNATIONAL LY 27 DOUBLE 4575 465 19
Based on what I see and not knowing the size of your Suburban, 750lbs. would be a better fit. Airstreams like a soft ride
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 09-20-2010, 09:53 AM   #6
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Yeah I would go with a lighter one too. I have #500 on my 68' and it's plenty.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-20-2010, 09:59 AM   #7
Ball heights
Published ball heights are only valid, when the trailer comes off the production line.
Airstream's are equipped with "torsion" axles, which contain rubber rods for the "cushion".
As time goes on, those rubber rods slowly deteriorate, which lowers the trailer.
Additionally, any give Airstream, will have a different ball height, depending on it's "pay load".
It is possible, assuming good axles, to lower the ball height about 1 1/2 inches from no load to a full load or overload.
Each owner should measure "their" trailer, to determine the "true" ball height that they will be dealing with.
Again, advertized or published ball heights,"are useless", when the trailer is equipped with a "torsion type" axle.
Old 09-20-2010, 10:11 AM   #8
_
Originally Posted by silverleeper View Post
...Based on what I see and not knowing the size of your Suburban, 750lbs. would be a better fit. Airstreams like a soft ride
it's truly SAD 2 see folks repeating this INCREDIBLY BRAINLESS mantra...
especially when u cannot define 'soft ride'
or provide ANY supporting info that links 'soft ride to w/d bar rating'...
the reliable evidence suggests HITCHES have nothing to do with soft/hard...
this is blindly repeating gibberish.
it's a carney workers bark designed to get u into the freak show tent.
_______
not only do you NOT know the 'size of the burb,
u don't know the CONDITION of the airstream
or ANY relevant info required to properly recommend a hitch.
a 40 year old trailer probably needs axles,
this is the SINGLE most important factor affecting 'ride quality' for the stream...
next would be tires, then LOADING, tongue weight and general condition of the trailer.
the trailer may have been mod'd and WILL have 40 years of issues to consider.
________
more over the ISSUE mentioned by the op is "heaviness" lifting/carrying the actual hitch.
suggesting different w/d bars only affect WEIGHT of the hitch a few lbs.
monday morning drivel is still drivel.
_______
there are 2 reasonable replies 4 the op...
1. provide a LOT more info about the rig and include some pics...
2. see a competent hitch/towing tech or experience streamer who can LOOK and HELP in person.
cheers
2air'
Old 09-20-2010, 10:15 AM   #9
1970 27' Overlander
Amarillo , Texas
This is the trailer I have. 1970 OVERLANDER INTERNATIONAL LY 27 DOUBLE
4575 465 19
My sub is 2 wheel drive
Old 09-20-2010, 10:23 AM   #10
1967 22' Safari
1960 Caravel
Images: 8
especially when u cannot define 'soft ride' or provide supporting info that links 'soft ride to w/d bar rating'...
_______
________
_______
cheers
2air'
Yep! What I have just posted is probably "INCREDIBLY BRAINLESS mantra...". Thanks for pointing that out.
momszoo2, This is an open forum and take all advice with a grain of salt.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 09-20-2010, 10:50 AM   #11
1970 27' Overlander
Amarillo , Texas
my axles are are good, shocks are new, tires are new, brakes are new the condition of the trailer is barn kept so it is good, The only mods are new seat covers,light laminate floor (i could carry both boxes) and formica counter tops, My sub is 5.3 liter with tow package,tongue is 500lbs and the trailer load is 5000lbs. Do I need a sway bar also.
Old 09-20-2010, 10:55 AM   #12
_
well that's ALL good info, and perhaps a little bit TOO tidy...
IF the tongue is really 500 lbs many would suggest NO w/d is needed.
this is approximately the weight range (500 lbs) where w/d STARTs to become useful or necessary...
depending on the tow vehicle and it's set up (overhang, tires, suspension, gear/loading)
sway control is useful regardless of w/d and sway control can be had withOUT w/d...
here are a couple of related threads...
http://www.airforums.com/forums/f464...-ii-21000.html
http://www.airforums.com/forums/f464...rol-17986.html
there are a LOT of useful threads here on if/when/how/what is needed for w/d OR sway control...
1. post pics
2. take the rig to a scale and get axle loads, and trailer weights.
cheers
2air'
Old 09-20-2010, 10:58 AM   #13
1970 27' Overlander
Amarillo , Texas
sorry what is w/d
Old 09-20-2010, 11:01 AM   #14
_
w/d = wd = weight distribution...
read the linked threads.
cheers
2air'
Hitch size Jim Sease Hitches, Couplers & Balls 16 10-12-2010 10:04 AM
changing hitch size bwaysteve Hitches, Couplers & Balls 3 11-24-2009 10:43 PM
Right size WD hitch????????? purman Hitches, Couplers & Balls 4 10-24-2008 09:41 AM
Hitch ball size Argosy27 Hitches, Couplers & Balls 1 05-23-2006 05:53 PM
Hitch Ball Size mopar7 2003 Safari 1 01-22-2004 04:56 PM
