Old 09-20-2010, 12:39 PM   #15
r carl's Avatar
Lin , Ne
Just get a weight distributing anti sway hitch with a 600# to 800# tongue weight rating.
Old 09-20-2010, 01:23 PM   #16
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
what size hitch do i need
Greetings momszoo2!
Welcome to the Forums and the world of Vintage Overlander ownership!
Originally Posted by momszoo2 View Post
This is the trailer I have. 1970 OVERLANDER INTERNATIONAL LY 27 DOUBLE
4575 465 19
My sub is 2 wheel drive
My coach, while 8 years older, is quite similar to yours with a factory stated dry weight of 3,940 pounds with an empty hitch weight of 405 pounds. In reality, my coach which was heavily optioned by the original owners had an, as delivered, empty weight of 4,440 pounds with a tongue weight of 550 pounds. When loaded for an extended vacation, the weight of the coach varies between 6,000 and 6,100 pounds and the hitch weight stays fairly constant at 725 to 750 pounds. I do have twin 40 pound Worthington Aluminum LP cylinders on the hitch rather than the more typical 30 pound cylinders.
My usual tow vehicle is a 1999 K2500 Suburban (3/4-ton with automatic four wheel drive). From 1995 when I towed with a 1995 K-1500 Z71 Club Cab pickup with 5.7 liter, until my first long trip with the Suburban in 1998 I towed with 1,000 pound weight distribution bars. During the prior 31 years, the coach had been used extensively and didn't have any popped rivets nor any cracks in the skin (had always been towed by a full-size Mercury or Oldsmobile coupe). Upon my arrival in Boise, Idaho for the WBCCI International Rally, I had a crack in the aluminum over the entry door; and upon further examination found close to two dozen popped rivets on the interior. A knowledgable Airstream hitch installer inspected my hitch and immediately suggested that I go with 600 pound weight distribution bars due to my firmly sprung tow vehicle. After making those repairs, the crack stopped growing and popped rivets became an infrequent experience. The axles on my coach are original, and still have a down angle on the torsion bars but are very near the point where they will have to be replaced.
Particularly if you choose to use a Reese Strait-Line hitch, I would suggest considering 600 pound weight distribution bars. If you aren't familiar with the Resse Strait-Line hitch, the photo below shows the setup on my Argosy Minuet 6.0 Metre when it is towed with my '75 Cadillac Eldorado.
The weight distribution bars in the photo above are the 500 pound bars that the original owner used to tow the Minuet with his 1978 Ford LTD sedan.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 09-21-2010, 03:15 AM   #17
Originally Posted by overlander64 View Post
Greetings momszoo2!
Kevin
Kevin.
If your rig in the photo is in a straight line, then the sway control arms are way out of adjustment.
The cams should be perfectly seated on the saddles, when the rig is in a straight line.
Perhaps the photo is misleading?
Old 09-21-2010, 03:20 AM   #18
sorry what is w/d
Using a "weight distributing hitch" with a "torsion type" sway control is superior to the "friction type sway control".
The former has a brain, the latter does not.
Old 09-21-2010, 06:43 AM   #19
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Andy!
Originally Posted by Inland RV Center, In View Post
Kevin.
No, the tow vehicle and trailer are not in a straight line as there isn't sufficient length on my short driveway to straighten the two out after making a left turn from the highway.
Kevin
Kevin D. Allen
AIR #827
Hitch size Jim Sease Hitches, Couplers & Balls 16 10-12-2010 10:04 AM
changing hitch size bwaysteve Hitches, Couplers & Balls 3 11-24-2009 10:43 PM
Right size WD hitch????????? purman Hitches, Couplers & Balls 4 10-24-2008 09:41 AM
Hitch ball size Argosy27 Hitches, Couplers & Balls 1 05-23-2006 05:53 PM
Hitch Ball Size mopar7 2003 Safari 1 01-22-2004 04:56 PM
