Old 11-04-2010, 10:37 AM   #1
1967 22' Safari
1978 25' Tradewind
NEW LENOX , Illinois
What kind of WD hitch is this? and is it any good?
So, I am seriously considering buying a 1978 TradeWind that has this kind of weight distribution hitch. Is this weight distribution only or sway control as well?
John Hejmanowski
johnhh is offline   Reply With Quote
Old 11-04-2010, 12:37 PM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
That is a Reese WD hitch w/ dual-cam sway control.
and yes, its good!
They have manuals on their website for installation and configuration.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 11-04-2010, 12:48 PM   #3
1967 22' Safari
1978 25' Tradewind
I was hoping that's what it was. When I looked at the Reese site the 'dual cam' was threaded and adjustable length. Perhaps this is an earlier version?
Thanks. I'll check out the install manual.
John H
Old 11-04-2010, 12:58 PM   #4
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
It looks like the 70's version Reese dual cam. There are lots of them still out there doing the job! I use the same one my grandfather had installed in the 70's. I did have to buy a new longer drop draw bar because the truck is much higher that the 78 Caddy Fleetwood he used to tow with. You may look into finding out how heavy the bars are and if they will work for you tow vehicle.
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 11-04-2010, 01:00 PM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yep. earlier version. you just don't have the flexibility in positioning the cams and snap-up brackets with the old version.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 11-04-2010, 01:13 PM   #6
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Yup, all answers are correct. I've towed many thousands of miles with one of these rigs (a 23' Safari). It's not a Hensley, but in my personal view, it's WAY enough control for that small a trailer - at least with my 3/4 ton tow vehicle.
Search the threads and you will find some information from Andy from Inland RV on the weight ratings of the weight distribution bars ... they come in four or five different thicknesses, and as they get thicker, they are capable of distributing more load. The consensus on this board seems to be that you will need at most 750# bars. That is what I have, and as I say, I've encountered NO sway. I also don't latch them down very tight, so as to keep the trailer ride pretty soft.
AirsDream is offline   Reply With Quote
Old 11-04-2010, 09:18 PM   #7
Ottawa , ON
I have the same hitch, and agree that it gets the job done.
The one thing that caught my attention is the length of your draw-bar. Mine is (IIRC) about half that length.
The closer to the vehicle the more stability you will have.
What are you going to tow with?
Old 11-04-2010, 09:41 PM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Some information for you on that setup:
Tuning a Reese Hitch
Old 11-08-2010, 08:42 AM   #9
1967 22' Safari
1978 25' Tradewind
Thanks everyone. I bought the 78 Trade Wind and towed it back from New Jersey to New Lenox (Illinois). Used the Reese WD that came with the trailer. Luckily the original owner had recorded all the install positions as set up by Airstream when he purchsed the trailer in '78. It worked great! (after I re-set the ball height)
I towed with a 2005 Tacoma V6. Did fine thru the hills of Pennsylvania and of course okay in the flat lands of Ohio and Indiana.
This 78 Trade Wind is a very cool trailer.....
Old 11-08-2010, 08:50 AM   #10
Gary.
Can you post who wrote that very nice article?
There are some updates available that could be easily added.
Old 11-08-2010, 09:20 AM   #11
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Those spring bars look way to heavy for a TradeWind
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 11-08-2010, 10:00 AM   #12
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Originally Posted by Inland RV Center, In View Post
Gary.
Andy,
I'm unclear on who the original author was but I'll keep digging around to see if we can find out. I ran across this a few years back and it was a big help in better understanding this setup, at least for me. I'd say if there are valuable updates to add - stick some on it as a footnote - it could only help.
Old 11-08-2010, 10:08 AM   #13
1967 22' Safari
1978 25' Tradewind
Bruce, using Gary's article, I am going to measure the bars and go thru the set up again using the original Reese kit instructions.
What size spring bars should I be using?
thanks,
John H
Old 11-08-2010, 11:21 AM   #14
thanks,
John H
With your tow vehicle, I would suggest the smallest rating that you can buy.
Or, as close to 600 pounds as you can.
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 05:40 PM
Anyone Know Kind W-D Hitch? catruckn Hitches, Couplers & Balls 10 10-25-2009 09:51 AM
Valley Hitches: good hitch but cheap bolts page.crow Hitches, Couplers & Balls 3 05-04-2009 07:57 AM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 12:48 PM
