Old 04-20-2019, 01:22 PM   #1
2007 25' Safari SS SE
Poulsbo , WA
What it's this and is it useful?
It's a 1" ball mounted on the side of the frame. I'm guessing it was added by the previous owners and used as anti sway at some point? I'm restoring the front and plan on removing it unless it has some value that I'm unaware of...Click image for larger version
wandered is offline   Reply With Quote
Old 04-20-2019, 01:24 PM   #2
Poulsbo , WA
Auto correct is my grammar nemesis.
"What IS this and is it useful?"
Old 04-20-2019, 01:47 PM   #3
Hiwheel Joe's Avatar
1984 27' Sovereign
Oklahoma City , Oklahoma
Yes. Old friction sway control. If not using one remove it. I removed mine and just put a dab of sealer on the screws and put them back in the holes and painted over.
Hiwheel Joe is offline   Reply With Quote
Old 04-20-2019, 01:57 PM   #4
Poulsbo , WA
Excellent - will do and thanks!
Old 04-20-2019, 02:44 PM   #5
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Originally Posted by wandered View Post
It's a 1" ball mounted on the side of the frame. I'm guessing it was added by the previous owners and used as anti sway at some point? I'm restoring the front and plan on removing it unless it has some value that I'm unaware of...Attachment 338641
read this
http://www.airforums.com/forums/f464...le-193779.html
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 04-20-2019, 02:52 PM   #6
Poulsbo , WA
Originally Posted by AlinCal View Post
Great thread; I will definitely save -- thanks!
Old 04-21-2019, 10:52 AM   #7
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
I had one and changed hitches. I just guessed that 6 holes drilled that close together could cause weakness. Get it? guessed. So I took plate steel the same dimensions of the sway control and bolted it in place and painted it. It looks fine and it remains strong.
jimfa440 is offline   Reply With Quote
Old 04-25-2019, 11:51 PM   #8
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I concur
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
https://www.facebook.com/groups/2284022111820203/
cazual6 is offline   Reply With Quote
Plumbing Vents - Useful Info lebolewis 1974 - 1979 Sovereign 0 07-07-2006 06:22 PM
Oven useful or not? '70 Overlander blackboat Stoves, Ovens & Microwaves 20 06-17-2006 03:56 AM
N.A.D.A. value: Useful or bogus? tphan Trailer Values 10 05-13-2005 12:12 PM
Non-obvious but useful AS tips hohne On The Road... 3 05-24-2004 05:35 PM
