Old 01-02-2009, 08:20 AM   #15
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Wow- thanks for all the good ideas! I wonder if the DT Max Security is somewhat invulnerable to bolt-cutters? Or, if Mexray's idea would work with our cat? And if the Guardian G-37 accomodates the big, rolled flange of these '70's couplers? Kinda looks like it might. Will also check out the ones Utee94 posted pics of. PM me if anyone has a flat-flange coupler that my Gorilla would work on, it's $30 plus postage. Otherwise I'm returning it.
tphan is offline   Reply With Quote
Old 01-02-2009, 11:33 AM   #16
reddogfox's Avatar
2008 20' Safari SE
Thumb Area , Michigan
I am using the Master Lock Universal Trailer Coupler Lock Model 379DAT on my 2008 Safari SE. It was the only hitch lock the Dealer stocked that would fit over the big rolled flange on the Airstream couplers.
http://www.etrailer.com/pc-CL~379DAT.htm?utm_source=dealtime&utm_medium=ppc&A ffiliate=deal
I also secure the coupler latch with a Commercial grade long shackle pad lock.
http://www.masterlock.com/apps/catal...ubId=HSL_1_2_3
Richard from MI
20' 2008 Safari SE, Dill TPMS Silver Dog House
2007 GMC 1/2 ton Sierra ARE Cap
AIR # 10494
reddogfox is offline   Reply With Quote
Old 01-03-2009, 10:44 AM   #17
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
So are these pretty much the choices for a durable coupler lock?
Old 01-03-2009, 11:59 AM   #18
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Man I will say it again. I'm glad I live where i live. You could always jack it up and take the tires off. That would stop them from towing it away...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 01-10-2009, 09:18 AM   #19
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
OK- decided to give the DT Max. Security a try- seem to be popular, widely available, and they fit the wide, rolled flange couplers. Thanks for all the advice!!
Old 01-15-2013, 02:21 AM   #20
1972 31' Excella 500
Mount Vernon , Is For Lovers
Updated link for Gardian G-37
http://www.guardianhitch.com/order.htm
Sylver Slypr is offline   Reply With Quote
Old 01-15-2013, 02:05 PM   #21
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I have been thinking of a chain and padlock through the wheels but I also have a pair of the chocks that lock between the wheels and can be secured with a padlock. Does anyone use these and feel that they are secure ?????
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 01-17-2013, 11:13 AM   #22
Denis4x4's Avatar
Durango , Colorado
You're using logic and good sense here! Try the chain/lock combo available at most Harley dealers. You can pull an AS with a hitch lock on to a roll back faster than I can type this response. Try that with the wheels chained. Too, the chain can be used to secure bikes, generators, etc. Sometimes, people over think these issues.
Denis4x4 is offline   Reply With Quote
Old 01-17-2013, 12:31 PM   #23
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Ditto the chain & lock. Let some air out of the tires and you can kick the locked wheel chocks free...
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 01-17-2013, 01:07 PM   #24
retired USA/USAF
2001 30' Excella
Thanks Mojo. Hadn't thought about that one. I have some stainless chain so I 'll check to see if it's long enough. I have a shorter piece that I secure the generator in the back of my truck. I do trust people and have never ever had a problem in the camping area's we have chosen but WHY ask for trouble by making it to inviting.
See ya'll on the road sometime
Roger in NJ
TAC - NJ 18
Old 01-17-2013, 09:13 PM   #25
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by Sylver Slypr View Post
Hi, I had to remove the "Angel face" for your link to work.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-18-2013, 05:03 AM   #26
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I had those chocks before. Once I forgot to remove them and drove a few yards before I remember. They had twisted out and were laying on the ground where the trailer sat originally.
Alan
Old 01-21-2013, 07:24 AM   #27
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The lock for the chocks is more about the chocks not being stolen than the TT.
And, thanks for the link to the GUARDIAN, above.
Old 02-11-2013, 04:17 PM   #28
Originally Posted by ROBERTSUNRUS View Post
Hi, I like the Guardian G-37 best. But I did make, and glue in place, a "U" shaped piece of tire side wall to make it fit tightly without damaging the paint on the coupler. The latch lock is a Smith & Wesson. [same as Gorilla, but different name stamped into it] Also make sure your receiver lock [not pictured] is 5/8" diameter solid shaft, not sleeved.
When did you get yours? I just tried to get one and my check was returned in an envelope marked OUT OF BUSINESS 2/6/13
AS Security. Hitch lock or More man7sell Hitches, Couplers & Balls 27 12-22-2008 12:36 PM
Hitch Lock SilverCabin Hitches, Couplers & Balls 14 09-02-2008 08:59 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
Help with lock please? centennialman Doors & Locks 10 07-06-2006 05:45 AM
Does anyone use this lock? azflycaster Buyer Guidelines 12 11-24-2005 09:20 AM
