Old 04-19-2011, 12:05 PM   #1
qc1500's Avatar
rozenburg , netherlands
What is missing? weight reducing.
I am trying to figure out what i am missing? It is eaz lift. But i am trying to figure out what i am missing so i can really use it.
1974 31ft sovereign international
1976 SMV 520
towed by 2005 Dodge ram SRT-10
qc1500 is offline   Reply With Quote
Old 04-19-2011, 12:14 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I do not see the lifting bar. It will be a bar about a ft long that goes in through the larger hole in the bracket and has a small pin on one end that goes into the smaller hole. That bar is used to lift the bracket into the loaded position.
Before you go much further consider the tongue jack as it will have to be moved to clear the driver side bar.
That is a weight distributing system ONLY. It has no sway control function.
The trailer looks nice enough to warrant a new system with sway control.
2004 Excursion 4x4
Old 04-19-2011, 12:18 PM   #3
qc1500's Avatar
The weight reducing system is complete new to me. If i buy new what kind i would need?
1976 SMV 520
Old 04-19-2011, 12:39 PM   #4
Ottawa , ON
Something like:
Weight Distribution - Reese
or even this, if you want to go "top of the line":
Trailer Sway Control Hitch Guaranteed to Eliminate Trailer Sway - ProPride 3P
But isn't there some special hitching system that is needed (or required) in Europe?
Old 04-19-2011, 12:56 PM   #5
x
XXXX , XXXX
None of those systems will work with that side mounted tongue jack. Replace the tongue jack with the proper one that mounts in the hole in the center of the A frame.
wasagachris is offline   Reply With Quote
Old 04-19-2011, 01:16 PM   #6
qc1500's Avatar
I have to have this one to get MOT on this trailer in our country, the original is still in place. So the side mounted tongue jack will go as soon as the MOT is on the trailer.
1976 SMV 520
Missing Persons Melody Ranch Off Topic Forum 3 04-04-2011 10:45 PM
Hitch sway or weight or both!!!! Luc_DK Hitches, Couplers & Balls 5 03-29-2011 08:22 AM
'73 Tradewind missing trim at wheel constructor Clearcoat, Exterior Paint & Trim 3 03-10-2011 08:49 PM
Axle weights limits vs. combined weight - What am I missing? Section8 Towing, Tow Vehicles & Hitches 25 02-15-2011 07:46 PM
31' Classic weight question pappy19 Tow Vehicles 11 02-06-2011 09:55 AM
