Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 10-17-2003, 06:59 PM   #1
mopar7's Avatar
Profile:
Question What Hitche/Brake Controller?
We just orderd a 25'B Safari. We have a 2002 Chevy Tahoe 4x4 Z71 with the Vortec 5300 and 3.73 rear axle. What hitche and brake controller should we get for this trailer? Will the Tahoe have any problems towing this trailer?
mopar7 is offline   Reply With Quote
Old 10-17-2003, 07:13 PM   #2
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
controller
I just got the Tekonsha (sp?) Prodigy and am happy with it.
Tin Hut is offline   Reply With Quote
Old 10-17-2003, 07:53 PM   #3
Profile:
Check the previous threads on this subject. One of them is four months long!
The discussions usually end with either the top line Tekonsha Prodigy or the Jordan Ultimae. Installation of the Jordan is a little more difficult due to a wire cable pull to the brake pedal vs. the Tekonsha being strictly inertia based.
Prices are about the same , $140 list. Probably pays to check around on controller + installation price as wholesale on my controller through a relative was about $95.
There is a wiring kit that cost $15 which will plug into your wiring harness under the dash.
wingfoot is offline   Reply With Quote
Old 10-17-2003, 10:35 PM   #4
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I picked up a new Jordan Ultima from a dealer off of Ebay for about $110. The wire install to the brake pedal was extremely easy. I've used a few brake controllers in my life but this one is the smoothest I have ever used hands down. I won't ever go back to an inertial after using this one.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 10-18-2003, 06:23 AM   #5
mopar7's Avatar
Profile:
Question Hitch
How about a hitch. Witch one should we get? Also will we have any trouble with the Tahoe towing this TT?
Old 10-18-2003, 08:59 AM   #6
Profile:
Reese, Husky, Draw-Tite, Hidden Hitch, Valley. They are all good and come in various ratings. I would go with a class III or IV.
Greg
1976 Soveriegn 31'
F250 Turbo 7.3L Diesel
WBCCI # 3516
Fun-Lovin is offline   Reply With Quote
Old 10-18-2003, 09:15 AM   #7
Cartoon Character
Porky Pig's Avatar
Profile:  2004 34' Classic
On The Road , U.S.A.
Re: Hitch
The GVWR of the Safari is 5,862 pounds.
Your Tahoe is rated to tow up to 6,700 pounds.
On the surface that looks OK. However, you need to dig a little deeper to make sure you are not overloading the Tahoe.
If you load the Safari to the max .. your ideal tongue weight will be about 11% of the GVWR .. which is 645 pounds.
This is 645 pounds will be carried by your Tahoe. So you will have to find out how much your Tahoe weighs with a full tank of gas, you and all passengers and all of your gear ... then add the 645 pounds to that figure. Are you exceeding the GVWR of the Tahoe?
Load up your Tahoe with fuel, passengers and your gear ... and go to the scales and weigh it. Now combine the weight of the Tahoe with the 6,700 pounds of the Safari. Are you exceeding the GCWR of the Tahoe?
If you can answer No to both questions, you should be OK with a good WD hitch and a brake controller.
Porky
TrailerGypsies.com
WBCCI #3405 — Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 10-18-2003, 09:56 AM   #8
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
hitched
Mopar,
Does your Tahoe have a factory towing package??
If so, then you will have a very easy time with the brake controller/trailer wiring/hitch setup.
If not, then you will have to do some additional setup work:
Transmission cooler, trailer wiring to the car end plug, brake controller wiring, tow hitch installation, etc.
I use a standard weight distributing hitch, eaz-lift, with a single sway control.
It does the job of leveling my Suburban and trailer, and feels alright while towing.
It's not great, and there is occasional sway, but overall it's ok.
Forum members seem to like the dual cam by Reese alot, as wella s the Hensley Arrow. I imagine that the closer you get to the limits of your tow vehicle, the more the investment of the Hensley makes sense. www.hensleymanufacturing.com
You will be at the limit of your Tahoe's performance on hills, but in my opinion, it should pull a Safari 25 just fine. This is providing you set up the tow system just right. You should find out first if your Tahoe has the factory tow package.
I own a Tekonsha prodigy, and it's vastly superior to the Voyager I used to use. I have not tried the Jordan, but have heard nothing but good things about it.
Good Luck!
Uwe
Old 10-18-2003, 11:25 AM   #9
mopar7's Avatar
Profile:
Yes the Tahoe has the trailer package.
Old 10-18-2003, 12:05 PM   #10
frozen chosen's Avatar
Profile:
Re: what hitch to get, do a dearch and read up on the Equal-i-zer hitch. I am going to go with this, and have heard nothing but very good reports.
frozen chosen is offline   Reply With Quote
Old 10-18-2003, 02:36 PM   #11
mopar7's Avatar
Profile:
Hensley $3000.00
Dual Cam Reese $400.00
Equal-I-zer $555.00
$3000 sounds like a lot of money and hard to hook and unhook.
I know we spent a lot on the TT but do I need the Hensley?
Old 10-18-2003, 02:54 PM   #12
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
In my opinion ...
Hensley $3000.00
Equal-I-zer $555.00
Absolutely not.
I just bought a new 2500HD truck and a 25' Classic Airstream. Since I need both new equalizer bars (1000# vs my present 550#) and a new, longer, shank because of the height of the new truck, I have decided to switch to a Reese Dual-Cam. The discount hitch place will fit me with a Dual-Cam setup complete for not much more than the replacement bars and shank cost for my old hitch.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 10-18-2003, 05:21 PM   #13
mopar7's Avatar
Profile:
OK if I go with the Reese do I need the high performance trunnion weight distributing Kit and the dual cam kit?
Old 10-18-2003, 06:26 PM   #14
Mike B's Avatar
Profile:  1977 23' Safari
1976 31' Sovereign
Robbins , California
Hitches and controller
Mopar7,
Look up Reese Strait Line hitches on your search engine and you will get all the info. It is a complete system except for the right height shank and ball for your vehicle. You will probably need the one with the 800# bars. I had a friend who just bought one for his SOB toybox on my suggestion,and is thrilled with how well it works. I myself use the Jordan controller and am very happy with it.
Mike B
Mike B is offline   Reply With Quote
Pingbacks are On
Hensley Brake Controller $427 New markjoandall Brakes & Brake Controllers 2 11-19-2003 06:47 AM
Electrial surge charge controller WayWard Wind 1999 - 2004 Bambi 0 05-05-2003 08:28 PM
Brake Controller Hook-Up Dimick Brakes & Brake Controllers 6 03-09-2003 01:44 PM
Magnetic Brake Controller MattyBoy Brakes & Brake Controllers 3 01-04-2003 01:29 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
SEO by vBSEO 3.1.0
