Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches
Old 10-18-2003, 06:31 PM   #15
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Talking Re: Hitches and controller
Originally posted by Mike B
Mopar7,
Look up Reese Strait Line hitches on your search engine and you will get all the info. Mike B
Good advice, by George!
Sorry, couldn't resist.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 10-19-2003, 08:02 AM   #16
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
My advice if you go dual cam from Reese is to consider the new HP dual-cam unit. I have the dual-cam which works great. Dependent upon the trailer, you may have to mount the U bolts in the area of the gas bottles. In my '01 Safari this required the bolts to be under the gas bottles.
The new HP dual-cam eliminates these U bolts. BTW, I am very happy with the dual-cam unit. I also join the ranks of those who recommend it. Here is a link to a page where you can compare the standard and the new HP models.
http://www.reese-hitches.com/sway_controls.htm#Dual Cam
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 10-19-2003, 08:46 AM   #17
Mike B's Avatar
Profile:  1977 23' Safari
1976 31' Sovereign
Robbins , California
hitches and contollers
The new Reese Strait Line Hitch assembly uses the hi performance dual cam setup so you do not need the U bolts.
Mike B
Mike B is offline   Reply With Quote
Old 10-19-2003, 01:20 PM   #18
mopar7's Avatar
Profile:
Where is the best place to get the new Reese Strait Line Hitch assembly? Best price.
mopar7 is offline   Reply With Quote
Old 10-19-2003, 10:08 PM   #19
jcanavera's Avatar
Fenton , Missouri
Images: 143
First I would check with the dealer where you bought your trailer from. Secondly I would check with any local outlets that specialize in hitch installations. If you feel comfortable installing yourself, surf the Internet.
I bought my dual-cam with my SOB trailer about 6 years ago. I negotiated a purchase at dealer's cost. With my Airstream's I have added installation of my dual-cam for no cost as part of my order.
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Pingbacks are On
Hensley Brake Controller $427 New markjoandall Brakes & Brake Controllers 2 11-19-2003 06:47 AM
Electrial surge charge controller WayWard Wind 1999 - 2004 Bambi 0 05-05-2003 08:28 PM
Brake Controller Hook-Up Dimick Brakes & Brake Controllers 6 03-09-2003 01:44 PM
Magnetic Brake Controller MattyBoy Brakes & Brake Controllers 3 01-04-2003 01:29 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
SEO by vBSEO 3.1.0
