Old 03-13-2016, 05:04 PM   #29
2005 31' Classic
Gretna , Nebraska
Love my Blue Ox. Better than the previous other brand I had which creaked a lot.
16595 is offline   Reply With Quote
Old 03-13-2016, 07:00 PM   #30
westphalia's Avatar
2016 28' International
Rochester , Michigan
Thank you everyone. We appreciate it, disregard my double post. We are new to this.
westphalia is offline   Reply With Quote
Old 03-13-2016, 07:29 PM   #31
Brawny's Avatar
2004 30' Classic
London , Ontario
Originally Posted by MrUKToad View Post
Andy Thompson set us up with a very basic Eaz-Lift hitch, as he generally does for his customers, even though he sells Hensleys, too.
Can Am is setting us up this spring, and we'll be getting the Eaz-Lift hitch as well. I wondered about a Hensley or ProPride, but was advised that the Eaz-Lift would work fine for us. Glad to hear that it works well for you, MrUKToad, as our set up will be similar.
Brawny is offline   Reply With Quote
Old 03-14-2016, 07:44 AM   #32
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by Tom_T View Post
As I said - many posters who probably have never had a Hensley or PP, posting BS which adds nothing to the discussion but negativity, & does nothing to help the OP nor other readers coming along later looking for guidance.
This type of post is useless!
Try instead to add a useful & helpful comment which explains something - preferably what you have yourself, it's pro's & cons, & what you like about your choice, it's own weight & cost, etc.!
In fact - so long as your TV's hitch rating is what's actually on the tongue of the trailer - or less than the max., it really doesn't matter what the weight of the hitch is, & the WD function distributes that amongst all axles of the TV & Trailer anyway.
The weight of the hitch unit itself - & anything else on the A-frame & at the front half of the trailer (both as built & loading) - is/are only a valid limiting factor if they all combined + the trailer's loading puts one over your allowed hitch weight, & Lucy was able to do that with her rocks in the trailer anyway!
Otherwise, one could make the same lame "too heavy" comment about going for double 40# LP tanks!
PS - what "looks too heavy" is nonsense, but The Hensley & PP are actually quite simple - despite frank's "looks" comment, & the jacks are far more simple to operate than any of the other means of tensioning the spring bars - you just wind the nut at the top of the jacks up o down until you get the desired WD setting as determined with any WD hitch at the TV wheels being level as per unladen with the trailer/hitch, & wind them all the way down when unhitching.
If one finds that too complicated & has difficulty using a simple ratchet wrench (provided with the hitch BTW), winder wrench as used for the stabilizer jacks on many trailers, or a cordless drill with the socket to wind the jacks, then perhaps they need a different hobby than trailering!?
Cheers!
Tom
Rather harsh and judgemental of the opinions and mechanical abilities of others.
MICHAEL
Old 03-14-2016, 07:59 AM   #33
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
What hitch to purchase?
Here is my opinion, if a person never tows over 60 mph, any sway control or even no sway control will do fine.
If a person is going to tow at posted speed limits nothing currently available will touch the stability of a Hensley designed hitch. They not only stop sway absolutely, they make towing a pleasure. It makes my trailer tow like it is on a fifth wheel. It totally impressed me.
Is the hitch heavy? Yep!
Does the weight matter? Not really. The heavy part stays on the trailer. The stinger is all a person handles in daily use, and it isn't that heavy.
This November my son borrowed a trailer that had a Blue Ox on it. The November before he used my Hensley equipped trailer.
He said there is no comparison.
Talis gentium ceciderunt.
Old 03-14-2016, 06:30 PM   #34
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
There is no comparison. I've been towing since 1973 and family had this trailer type going back ten years before that. Dual Cam was the thing until the mid 90s when the Hensley came along.
It's easy to crack the whip with any other hitch and have the trailer get sideways. Can't do it with a Hensley. I tried. 55-mph violent swerves from shoulder to median and back, multiple times, throttle on, after I had one installed. Might as well try to lose your shadow. That's with a one ton and a 35' trailer.
Follow another rig with a conventional hitch and the trailer is always moving around. With a Hensley, it can't.
The bigger the rig, the more beneficial it is.
Money shouldn't be a consideration. If one can afford an RV and afford to travel, then . . . .
Old 03-15-2016, 08:54 AM   #35
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I figure if the Airstream is marketed as the best of the travel trailers, I would put the best hitch I could find on the trailer. All my reading here on the forum pointed to the Hensley Arrow starting in September 2012.
When we traded the 2013 25FB in on a 2014 31'Classic, the conversation was extolling the virtues of the second generation Jim Hensley design called the ProPride and it was less expensive than my Hensley Arrow.
So, I still use both systems and they do the job for us. The original Hensley Arrow is now attached to the 2015 23D and the ProPride is on the Classic.
Old 03-15-2016, 07:04 PM   #36
westphalia's Avatar
Think I am going to get a ProPride. Talked to Shawn at ProPride so heading up there this week.
Old 03-15-2016, 07:27 PM   #37
2007 22' International CCD
You will find that he stands behind his product, and will answer phone calls with questions personally.
The customer service and attention is one of many reasons I bought a ProPride.
KE4GNK/AE
Old 03-15-2016, 07:34 PM   #38
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
If I had bought new I would have bought a ProPride.
Old 03-15-2016, 07:40 PM   #39
2015 27' FB International
San Jose , California
You'll run the decision back and forth for hours, if not days..
They're all great hitching systems. I have a Blue Ox and am very happy with it.
theflash44 is offline   Reply With Quote
Old 03-16-2016, 05:18 AM   #40
switz's Avatar
2014 31' Classic
Images: 8
Sean can stand behind his quality product, whereas John Deere typically does not stand behind their manure spreaders.
Old 03-16-2016, 05:36 AM   #41
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
I have tried a few different hitches and am now using a Pro Pride. It works much better for my setup than anything else I tried. The main reason I like it is because it makes they whole rig very stable at interstate speeds.
Echelon73 is offline   Reply With Quote
Old 03-16-2016, 08:47 AM   #42
Where is the 'like' button. 😄
Yep. I love my ProPride as well.
KE4GNK/AE
3P hitch - about to purchase! Gsmblue Towing, Tow Vehicles & Hitches 60 03-01-2016 07:34 PM
First Airstream purchase... need purchase tips, please. movin-in Buyer Guidelines 8 06-03-2010 05:09 PM
Possible purchase need purchase/deposit/title forms LiLNomad Dollars & Cents 5 05-28-2010 12:59 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
