Old 01-11-2011, 09:42 AM   #1
dmcummins's Avatar
St. Charles County , Missouri
What do you do with your Hensley during the winter?
I bought a used Hensley this summer and have left it on the trailer at all times. Now I'm wondering if it would be better to take it off and store it inside. Of coarse it is freezing outside and its snowing. I do have the front part covered with plastic. But that's it. Is there any harm in leaving it hooked up at all time's? Or should I store it when not in use?
dmcummins is offline   Reply With Quote
Old 01-11-2011, 09:50 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
I keep the whole trailer inside but realize that won't work for everyone.
The pivots are pretty well sealed and I wouldn't worry too much about leaving it out.
Old 01-11-2011, 10:35 AM   #3
Garfield's Avatar
2001 25' Safari
London , Ontario
Images: 24
Mine stays on my trailer all the time, which is stored outside. I do bungie a BBQ cover over the Hensley, propane tanks and battery...partly to hide it from prying eyes and partly to protect the paint from premature fading. Otherwise there's no need to remove it, except for lubing the hitch ball periodically.
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD • Hensley • DirecLink • McKesh
Set-up by Can-Am RV
Garfield is offline   Reply With Quote
Old 01-11-2011, 10:38 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
And if you're feeling brave, you can install a small grease fitting on the coupler of the trailer. All you would have to do then is pump a couple of squirts of grease in periodically, and take the Hensley down occasionally to inspect the ball.
Old 01-11-2011, 11:21 AM   #5
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Mine stays on all the time, but I live in California and use my trailer all year. I was covering the hitch with a BBQ cover during the rainy season but stopped as moisture would get in and be retained inside the cover. I found it better to just leave it out in the elements.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 01-11-2011, 12:03 PM   #6
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I take the hitch off and store it in the garage.
I purchased a used HAHA a few years ago. When I disassembled the hitch for a rebuild/repaint there was a lot of moisture in the grease and pitted bearings other wise the hitch looked like it would have performed just fine.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 01-11-2011, 05:14 PM   #7
Michigan , Michigan
I do the same. I built a self for all my hitch stuff. and store it in a cabinet in the garage. Just used some scrap sq tube they were tossing in the trash at work. Leave the frame brackets on the trailer but put some oil on them.
Mine also had moisture in it. Im guessing its from condensation but not sure. I also sealed around the grease caps with a little clear caulking. Summer, I have been just leaving it. I was covering it but it caused more bad than good. Might end up doing some kind of hard cover but probably just leave it out.
mikeb9550 is offline   Reply With Quote
Old 01-11-2011, 06:12 PM   #8
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Taking it off every fall for winter storage is the only time it and all its components get a real dose of TLC - stripped, degreased, checked, cleaned, waxed and polished - gave it a complete facelift two years ago - now its fire engine red and polishes up just great.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
How cold is it then with You? cruiser54 Winter Living 192 02-12-2011 06:16 PM
Need new LP heat source for short bursts of winter use pyrenees Winter Living 12 01-04-2011 08:41 PM
