Old 06-07-2013, 08:39 PM   #1
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
What causes a bouncy ride
I'm pulling a 2011 23fb with a 2011 Toyota Sequoia. I use a basic WD hitch (forget the brand at the moment) with spring bars and my sequoia sits pretty level. This is my only towing experience so I can't compare to anything else. My only issue with this setup is on some sections of concrete paved interstate I get a lot of bounce in the back of the sequoia. It doesn't feel too bad in the front seat but if i look in my mirrors i see my kids are bouncing up and down what seems like a couple times a second. I have overloaded the bed of pickup before which caused some big or long bounces which leads me to believe that isn't the cause of this fast bounce. I've wondered if I need to add airbags in my suspension.......
Thanks in advance for any thoughts or experiences
Landrum is offline   Reply With Quote
Old 06-07-2013, 08:56 PM   #2
1986 31' Sovereign
Miami , Florida
You are not alone. Basically, on some sections of concrete highway, the expansion joints are spaced in such a manner that it sets up a fugoid cycle due to the length of your rig and the way that the weight distribution bars work where the bouncing is self-reinforcing.
Sometimes slowing helps, sometimes speeding up helps but mostly it won't go away until you get off that section of road or the road surface changes.
The Anderson Hitch apparently addresses this problem very effectively but, judging by the raging battles about the Anderson on this Forum, there seem to be some "teething problems" in its present form.
Avoid I-10 between Lafayette, La and Baton Rouge...
Mike
Old 06-07-2013, 08:58 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
If it's the highway, it's called "porpoising" and it pretty much describes what's going on between your trailer & your tow vehicle! :-D
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 06-07-2013, 09:02 PM   #4
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Try to avoid I-20 through Bossier City and Shreveport.
Old 06-08-2013, 05:10 AM   #5
"Cloudsplitter"
Thumbs up
I usually back down those highways.
As far as air bag additions go, I doubt if they would do anything to stop the bounce, may even make it more like a jolt, and do nothing for weight transfer or payload.
They do go up and down though.
Old 06-08-2013, 05:19 AM   #6
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 13
Smile
Avoid Louisiana completely. Next time go by way of Omaha.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 06-08-2013, 06:30 AM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
An Air Safe hitch would help
Old 06-08-2013, 06:34 AM   #8
Retired.
. , At Large
I-40 Westbound from Little Rock to the state line has to be the bounciest, roughest stretch of Interstate I've ever towed on. It was so bad, the toilet detached from its mount, and ended up by the front door.
Old 06-08-2013, 07:00 AM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
This ^^^ and try changing speed. The interstates seem to have a set distance between expansion joints, when they get worn it causes a frequency bounce. I drive a lot of I-95 with different vehicles and each one behaves differently on the same stretch of road. There is one stretch in SC where I can drive 70+ with my sedan, my dually I have to slow down to about 63 with my wife's truck and the Airstream in tow we get off on old 301.
Aaron
WBCCI #XXXX AIR #2495
Old 06-08-2013, 07:41 AM   #10
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I would have to search the forum but I believe that I read the AirSafe hitches addresses this problems. Pricey hitches however.
TinCan
graysailor is offline   Reply With Quote
Old 06-08-2013, 08:11 AM   #11
wxbuoy's Avatar
Wildwood , Florida
Send a message via Skype™ to wxbuoy
That is one of the reasons we went with the Airsafe hitch. If you are feeling it, your trailer is definitely feeling it. The condition is compounded by larger vehicles with heavy spring. We love ours and it has taken a lot of unpleasantness out of towing!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 06-08-2013, 08:32 AM   #12
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
In my opinion the Andersen WD system does an excelant job of controlling bounce on Louisiana's crappy highways. At least as much as any other system at much less cost. With my trailer/TV combination the differance with and without is night and day.
MICHAEL
Old 06-08-2013, 08:57 AM   #13
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I'll mention it, although it sounds like you already have it set up correctly - if your hitch is of the style that uses lifter bars (Reese, for example), and you don't have the lifter bars pulling enough weight, you'll get porpoising. I had one pretty bad situation with it, but adjusting the bars by reducing the number of chain links between the bar and the bracket cleaned it up.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 06-08-2013, 11:56 AM   #14
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Make sure your shocks are up to the job. Sometimes changing to a different weight will help - the shocks that come with a SUV are not meant for heavy tow loads with weight distribution hitches. It will not eliminate the bounce but help to reduce it.
Silver Hawk is offline   Reply With Quote
Old 06-08-2013, 12:19 PM   #15
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I'm still learning, have used the Equal-I-Zer, Andersen, and now ProPride with 1400# bars. My recommendation is to get a hitch with enough weight distribution capability to properly distribute the tongue weight of your trailer.
The first two hitches were too stiff a connection, the Andersen showed signs of damaging the trailer (elongated bracket mounting holes in the frame and a front banana wrap torn loose from its rivet). The new one with 1400# bars distributes the weight I need and still have very good flexibility with my trailer tongue weight.
With 2,000 miles on the 1400# tapered hitch bars, the ride is very good without the stiff connection.
doug k
Old 06-09-2013, 06:41 AM   #16
m.hony's Avatar
2013 30' Classic
In your Chevy with peace signs, mag wheels, and four on the floor...
Old 06-09-2013, 07:22 AM   #17
2003 25' Safari
Riverside , California
I have changed my rear springs to a progressive design and have King 3" custom valved shocks.I have no porpoising while towing and a very comfortable ride on our less than optimum road surfaces here in California.
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
