07-29-2012, 12:32 PM
Usually lost
2007 27' Safari FB SE
Maricopa
Weld broke on Hensley
Went to hitch up this morning to head back to AZ. When I was greasing up the Hensley I noticed that the weld around the W/D bar connection was cracked. Further inspection shows about a 4" crack (can see through it). Will be spending at least another day in Rapid City to get it welded. Lucky I found it before I left, but I wonder when it cracked. Didn't notice it the last time I hitched.
Pat, Babs & Riley
07-29-2012, 12:46 PM
2008 30' Classic S/O
Dearborn
, Michigan
Pix, please!
07-29-2012, 01:02 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Thanks for this important information. I have a Hensley that is six years old (#8332) that has almost 100,000 miles of towing on it. I will be giving it a thorough inspection. Pictures of your broken weld would be great.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
07-29-2012, 02:28 PM
2002 25' Safari
Dewey
Pat, we found a good welder in Union, Nebraska a week ago. I know when my hitch cracked because I did it. ;-(
We will be headed out of Gunnison tomorrow, headed home after 2 months on the road. Travel safe and we will see you soon!
Richard
07-29-2012, 03:33 PM
Usually lost
Maricopa
Pictures
Here are a couple pics. You can see the light coming through. There is no load on it at this point. I don't know if it would separate further under load.
Pat, Babs & Riley
07-29-2012, 03:50 PM
mapleton
, Utah
dont know what caused the crack but from the paint flaking it looks like you may have stretched or separated more of the weld running back under the hitch body. Have your welder take a good look while he's there.
tim
07-29-2012, 03:58 PM
Usually lost
Maricopa
Thanks, I'll have him check it out. The paint came off when I was cleaning the crack and picking at it to see the damage.
Pat, Babs & Riley
07-29-2012, 04:29 PM
Santa Rosa Beach
Thank you so much for the pictures. I'll be all over Lucy's Hensley as soon as possible.
Brian
07-29-2012, 04:31 PM
2021 25' Globetrotter
Jamestown
, Rhode Island
Aren't these hitches guaranteed for life against this kind of failure?????
I'd be scared $&!#-less to just weld it back togeather and continue using it!
What caused that failure? I would certainly be on the phone to Hensley looking for advise....
Bruce
07-29-2012, 04:51 PM
2002 19' Bambi
Lafayette
I, too, think you should check with Hensley.
Tim
07-29-2012, 05:00 PM
Lin
, Ne
Yes it has a lifetime warranty and I would send it back to them for a replacement. I would call them in the morning before you get it welded though.
07-29-2012, 05:22 PM
1968 17' Caravel
2005 30' Safari
Somewhere
, roaming America
I had the same crack on mine. Hensley replaced the head under the Lifetime Warranty. You don't have to pay to have it welded unless you're in a hurry or don't want to incur shipping costs.
All hitch owners should inspect their gear including tow vehicle receiver, regularly. No brand is immune to wear and tear!
07-29-2012, 05:24 PM
Port Orchard
I am not trying to start an argument.
I am not trying to suggest a cause.
I am simply curious.
Would this be a point of stress if a turn was made that was tighter than the hitch design would allow?
Ken
07-29-2012, 05:37 PM
Usually lost
Maricopa
I've already emailed Hensley and will call first thing in the morning. They do have a lifetime warranty and have always treated me well on the few minor issues I've had. I do have to get home for some prior commitments, plus with Sturgis coming up the campgrounds are full. As to the stress point question, my understanding is that the shear bolts on the a-frame are supposed to give when it is turned too tight. Thanks for the advice and I'll keep you posted.
Pat, Babs & Riley
07-29-2012, 06:10 PM
Master of Universe
2008 25' Safari FB SE
Grand Junction
The other side should be looked at too and maybe spot welded when the crack is repaired in case that side is weakened. A good welder should be able to make it plenty strong (note the adjective "good" before welder).
If shear bolts don't shear, something is wrong. The crack happened before the shear bolt design failure point and my guess is the broken area has a design defect or contaminated metal. On a short thread, there are already one and maybe two posts about the same thing.
Gene
07-30-2012, 07:59 AM
Dearborn
, Michigan
Wow. I thought these things were pretty much bulletproof.
I'm surprised the torsion bar doesn't drop out.
How old/approximate mileage on that?
I used to ratchet up the struts to max, with no holes showing... after talking with Aaron, he said the reason they don't recommend doing that is possibility of the torsion bar bracket hooking onto the strut bar bracket underside... but I'm wondering if this is another reason not to?
07-30-2012, 09:33 AM
1968 28' Ambassador
Cedaredge
Sounds like its time for a new Andersen WD. Have none of those type problems with mine, and it's light as a feather . No, this hitch probably works great for you, but something isn't working right if that crack happened you need to talk to them and figure it out, or it will probably happen again.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
07-30-2012, 10:50 AM
2011 31' Classic
Nellysford
, Virginia
Well, THAT got me up off the desk chair in a hurry. Glad to report all is well on ours, but THANKS for making me look. Hensley replaced our Orange Part this year at no charge after the hitch ball weld separated a bit. That's the next thing to look at when you nice and level and can un-hitch easily.
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | Life Mbr ACI 1927 - Spirit of Virginia Club | AIR 53869
07-30-2012, 10:04 PM
Usually lost
Maricopa
Talked to Terry at Hensley before the welder came this morning and sent him pictures. He said that having somebody else do the repair won't affect the warranty. Discovered that the bushings where the spring bars attach was broken too, but on opposite side from the weld break? Hensley will send me new bushings. On the road home and so far no further problems. The bushings look pretty worn to me. About 40K of towing on the hitch.
Pat, Babs & Riley
07-30-2012, 10:20 PM
Port Orchard
That sounds like of bunch of towing miles. Over what time span was that? I guess we don't use our trailer enough.
Is the eccentric shape of the inside of bushings wear or are they designed that way?
Ken
