Old 08-01-2012, 04:29 PM   #29
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
http://www.airforums.com/forums/f464...ml#post1158509
Here is a post I made on another thread. It is pics of my Hensley failure. Understand, the hitch was old. Good one but they do fail with age.
I bought another hitch and am very happy with it.
Joe
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 08-01-2012, 04:40 PM   #30
SteveH's Avatar
Common Sense , Texas
Here is a picture of the same plate under the bar tubes that failed on cahalan1526's Hensley, but on my ProPride, and I think if you look back and compare, the ProPride has lots more metal in that area that failed on the Hensley.
Old 08-01-2012, 04:43 PM   #31
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Thanks Steve - that stud and nut on the bottom plate - is it holding in place the same type of internal sleeve that the Hensley has?
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 08-01-2012, 04:45 PM   #32
SteveH's Avatar
Jay
I've not actually worked on a Hensley, but from the pictures I've seen on here, yes I believe it is the same type of setup.
Old 08-01-2012, 05:20 PM   #33
RangerJay's Avatar
2002 19' Bambi
Images: 44
Thanks again Steve - the ProPride does seem to look beefier in this area.
Given all the discussions around hitches (on this and other forums) - the level of interest - the critical importance of safe towing - and the level of emotion around brand loyalty - it would be really great to have an organization like Consumer Reports do an objective, in-depth comparison of hitch types and hitch brands.
Jay
(Oscar Wilde)
Old 08-01-2012, 05:24 PM   #34
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Great thread, Pat! Sorry for the trouble, obviously, but a valuable addition to information on this hitch (which I also own).
In line with some other questions above, I am also wondering about the loads on the hitch. What weight of TT & TV, and how well did the hitch transfer TW across all axles . . any scale tickets available? Miles is not enough of a statement by which to consider wear to be excessive (there are other owners with greater miles), nor does the approximate rig combination (TV & TT size/weight) by itself seem much more "informative" (again, "big rigs" with more miles).
On the other hand I tried in vain to transfer TW on my rig. Quit, in fact (though not because I wanted to). The PRO PRIDE advantage is also in available head tilt which an H/A doesn't have. A long wheelbase truck with a deep drop stinger isn't going to move much (if any) I've learned. Doesn't affect anti-sway properties as we know, but isn't the best set-up either.
I bring this up because I have also tried running the roads with maximum leverage and this tends to wear the hitch parts faster in elongating holes, etc.
As with the above I also wonder if [1] a heavy TV-TT combo [2] over tough roads [3] with high or very high leverage cranked in might be contributory.
Your thoughts appreciated.
Old 08-01-2012, 08:12 PM   #35
Usually lost
Cally's Avatar
2007 27' Safari FB SE
Maricopa , Arizona
I'll try to answer some of the questions. The guys from Hensley suspect hitting a stump or large rock, neither of which is the case. I have bottomed out on a steep driveway, but it was years ago and I've had the hitch apart several time since then for maintenance. I've replaced the pins and brackets on the spring bars and the holes show minimal wear. My TV is a 3/4 ton Dodge and I do have a stinger with a big drop and raise the spring bars to the middle hashmark. I haven't gone to a scale with it. On this trip I did end up on a road in ND that was very rough (I was at 25MPH or less for 65 miles). I should be home tomorrow and will take the whole thing apart, clean and inspect. Then I can discuss at length with Hensley what I find. They have been very good to work with. If anyone is interested I'll have it at Alumafandango in a few weeks.
Pat, Babs & Riley
Cally is offline   Reply With Quote
Old 08-01-2012, 09:42 PM   #36
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I offer this as background:
I also have a 3/4T Dodge, and a vintage kin TT with an 8k GVWR. My attempts at getting proper WD are here, posts 41-55. In the 5,000-miles covered in calendar year '07 I was unable to "restore" FA and transfer adequate weight to the TT axles. While I don't mean to derail your thread, the question of how well the hitch "distributes" weight may come up in your discussions with Hensley, and seeing as how our rigs are similar it was not enough to repeat the comment from elsewhere that, (roughly)
" . . it may be that long-wheelbase 3/4 & 1T pickup trucks will not "restore" the FA weight as easily as shorter wheelbase, less stiffly sprung tow vehicles"
I was, at the time, using the dealer-installed Class IV hitch receiver (bolt on copy of the factory welded-on receiver), and I replaced it (a temporary upgrade) with a CURT Class V (the low cost, probable low quality brand) when I this year found un-repairable damage to that.
The "best" replacement would be the more robust, better designed TITAN
45299 with user reports on several Dodge forums as well as comparisons on design, etc.
While it has also been noted that even with some torsional twist by the hitch receiver that WD should be distributed given proper leverage on/by WD hitch adjustments, I want to take this weak link out of contention (also to pull other trailers the factory piece is too light to withstand).
I have also tried several stinger heights. An adjustable stinger (tilt) would give the leverage needed, I believe, even when the needed drop is five-inches, not six or four (the only ones on offer from H/A).
One can see some home-built pieces on the H/A Users Thread, and Sean Woodruff (Pro Pride) may be able to make one up if requested. This is still a possibility for me, but I am in favor of another hitch without this built-in shortcoming (among others).
Braking & steering are not as effective as when solo/laden when the nearly full TW is still resting on the RA when hitched and adjusted. I find this unacceptable.
Cranking the H/A to full leverage does not work when the stinger height, truck wheelbase/springs, and the need for a level trailer are in conflict at several points for some rigs. A great deal of unnecessary force is present on the RA due to this . . . would it have a contributory effect on the hitch head in question (is, again, the reason for this FYI as offered).
Old 08-03-2012, 11:36 AM   #37
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
The spring bar bushings on the ProPride are two independent bushings. They each bolt into the main unit separately. The bushing weld breaking on the Arrow bushing is the reason behind the change in the 3P.
As Steve noted we have also extended the bottom plate to beef up that area. There is A LOT of stress in that area when you distribute tongue weight.
Finally, nothing is indestructible. Someone above posted something about these hitches being guaranteed for something like this to not happen. That isn't quite accurate. The hitch has a LiFETIME warranty. If nothing was ever going to break or wear out it wouldn't need a warranty. One thing we can all count on when something has a lifetime warranty is that the company does not expect many things to go wrong that needs to be covered by the warranty. Companies would not stay in business very long covering too many lifetime warranty claims.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 08-04-2012, 06:47 AM   #38
dznf0g's Avatar
Oswego , Illinois
Nice, objective experienced opinion, Sean. Thanks for staying "above the fray".
-Rich-
Old 08-04-2012, 07:52 AM   #39
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Something that will help a lot, no matter whether you use a Hensley or Propride, is to lube the area the bars slide up into regularly. By "regularly", I mean about once every 500 or so miles. This means use a grease gun, and pump grease into those fittings.
Old 08-06-2012, 08:13 AM   #40
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Right, Terry. Aaron at Hensley reinforced that to me during a phone call some time ago. I went through a cheap grease gun and then got a good one. We pump the two fittings each morning on an extended trip, just until the squeeze-out is noticed. Makes a mess of the safety chains over time, but well worth the peace of mind. Thanks for the reminder.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 12-01-2013, 08:56 PM   #41
2006 30' Classic
Milton , Florida
Hensley Hitch Failures
A friend sent me the following link to another forum. The other forum has a thread on Hensley hitch failures. I thought that all of us Hensley hitch owners might benefit from reading this link.
http://forums.woodalls.com/index.cfm/fuseaction/thread/tid/27386075.cfm
These hitches are subject to a lot of stress, and a periodic inspection of the hitch is a prudent policy.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 12-02-2013, 08:01 AM   #42
Glen Gardner , New Jersey
I came to this forum to research this exact thing. I had my hensley break Saturday night in the same place except mine was worse and I never knew it until it was too late and it cracked far enough for the upper and lower heads to jam together, and rotate, breaking a shear pin and bending the other strut rod as well as egging out the hole in where the strut rod attaches to the upper unit. Luckily this happened as I turned onto my street and was only 3 houses away from mine.
njdrt-rdr is offline   Reply With Quote
