Old 09-16-2009, 08:43 AM   #15
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Just a little note here. If you only weigh indiviual axles you will quickly make your self nuts. The weight of each individual component will not add up the total weight of the whole rig. You need the whole rig on the scale to get a true weight of the whole rig. Adios, John
Diesel1 is offline   Reply With Quote
Old 09-16-2009, 08:46 AM   #16
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
[QUOTE=RLS;748270]Thanks for the link to the Sherline Tongue Scale! I just ordered the 2,000 lbs. one. I will be making some kind of drive on ramps to get each weight of the wheels. Both Airstream and TV. No more CAT Scales!!!
Bob[/QUOTE
It is a hydraulic pressure scale with a 2k limit I wouldn't attempt using it
to weigh anything but the tongue. The instructions that come with the scale will outline it's limits.
The CAT scales were pretty intimidating the first time we went to weigh our first AS. Like anything Airstream the more you do it the easier it gets.
Whenever I'm not sure that I'm loaded properly I stop, usually takes less than 20min. It's really the best and easiest way To balance your rig.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-16-2009, 08:48 AM   #17
Bob[/QUOTE
Whenever I'm not sure that I'm loaded properly I stop, usually takes less than 20min. It's really the best and easiest way to balance your rig.
PFC
RLC
scale model Airstreams thunderbird Off Topic Forum 9 08-30-2016 07:20 PM
Slide Outs donemerson General Interior Topics 18 04-25-2009 02:36 PM
Blow outs handn Tires 35 08-28-2008 01:07 PM
Slide outs FireFighter Airstream Trailer Forums 1 05-14-2004 04:22 PM
Problems with Slide Outs? flyfisher Our Community 8 01-19-2004 01:10 PM
