Good to see your weight comparison. It is often stated here the ProPride/Hensley adds up to 200 lbs to the tow vehicle load, when it actually adds nothing.
Also, if you now distribute 20% of that 700 lbs to the trailer axles with the w.d. bars, your travel trailer will add only 560 lbs to the tow vehicle load on its axles.
Our fully loaded FC 25 (835 lbs factory spec hitch weight unloaded Airstream) adds 800 lbs to our truck when the w.d. bars are set, including our ProPride hitch and two oversized Lifeline AGM batteries in the battery box. Verified several times at CAT scales.
Doug and Cheryl
