09-24-2010, 04:28 PM
#21
_
fine idea, but NOT a canadian invention.
Originally Posted by wbrownrr
... using a 1/2" bolt "pushed through two overlapping links" to gain 1/3 of a link adjustment...
the bolt goes IN the space where the 2 links touch/overlap/connect.
there is NO gap there since the links touch tightly under tension,
but sticking a bolt into that area MAKES 4 a gap.
so while the links are SLACK a bolt can be inserted in the INTERspace where they overlap.
now when tensioned/stretched the 2 links (and total chain) are 'shorter' by whatever was stuck in the space.
so the 1/3rd adjustment 'gain' is actually a 1/3 SHORTER chain link.
cheers
2air'
09-24-2010, 04:30 PM
#22
2002 22' International CCD
San Luis Obispo
REDNAX... Right, I understand what he is trying to accomplish, I just don't understand how the bolt is used in the link. Also, can't intermediate adjustments be made by slightly increasing the rear-ward tilt of the hitch ball? Thanks for thinking this through with me, I'm trying to dial-in my hitch adjustment.
Wayne
2002 22' CCD
2008 Dodge Ram 1500 5.7L Hemi
09-24-2010, 04:38 PM
#23
St. Catharines
, South Western Ontario
Fine tuning bar tension
A picture is worth a 1,000 words.
This is a great way to fine tune the bar tension. Thnxs Can Am for the great idea.
09-24-2010, 04:50 PM
#24
San Luis Obispo
Ah ha! That's what I was looking for. Thanks, Road Ruler.
Wayne
2002 22' CCD
#25
Vintage Kin
Fort Worth
Sorry, he did state it and I repeated it. A bolt with washers and locking nut to take up "space" within the link. Should start own thread, or, better, IMO, go to this thread and post with numbers & photos:
http://www.airforums.com/forums/f238...-in-17984.html
Another quote (attribution lost; BryanL?):
Adjust the hitch ball height to 'level' the trailer.
Adjust the weight distributing bars to 'level' the tow
vehicle.
Adjust the hitch head angle to 'level' the bars.
Comes prior to "hair-fine" adjustments such as bolt-in-link, IMO. I see these things as being points of departure for thinking and experimenting. The numbers are the ONLY real thing (past measurements of height before & after hitching).
The further point, as with -- again -- the OP's question, is that it is the accumulation of numbers over time (trips) and experience with continued adjustments. TV's, TT's all tend to gain weight. The driver accumulates knowledge of how his rig handles (we hope), and it is through weight scale numbers and numbers alone that we can hope to perfect STATIC conditions as the predictor of dynamic conditions. ("Predictor" is too strong a word; it is that we hope to more perfectly fit the recommendations for our TT's & TV's manufacturer guidelines for towing).
Setting up a WDH the first time, correctly, is a PITA because it's new to us. But continued use of a certified scale ought to be second nature after awhile. Only then do we know what changes in the rigging really work. It's easy enough to whip through the scale on the way to the fuel island. And cheap for the benefits.
Think, "body of knowledge".
09-24-2010, 04:55 PM
#26
San Luis Obispo
Thanks to all of you for the clarification. As usualy, the forum comes through.
Wayne
2002 22' CCD
09-24-2010, 04:58 PM
#27
2001 25' Safari
London
, Ontario
A one-tonne dually's stiff suspension could easily damage a lighter weight AS by shaking it to pieces. That combo is not good idea IMO.
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD • Hensley • DirecLink • McKesh
Set-up by Can-Am RV
09-24-2010, 05:21 PM
#28
Salem
, Oregon
Originally Posted by Bluto
1 ton dually TV
27' FB 2010 Classic
Old Reese trunion WD bars rated at 1000 lbs.
Airsafe Hitch class V
Class V receiver hitch
Loaded for travel, both truck and trailer hitched and wd bars in use w/ Airsafe hitch at 60 psi:
Hi, this is why he has the Airsafe Hitch.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
09-25-2010, 08:17 AM
#29
2001 25' Safari
London
, Ontario
Ah-ha ! Thanks Robert....missed that.
Gary & Debbie
2001 Safari 25 SS
Set-up by Can-Am RV
10-02-2010, 07:23 AM
#30
2010 27' FB Classic
N/A
OK, I finally have the tongue weight to add to my numbers of my 27. Ready for travel it weighs in at 950#. Next, I have to get the weight of the truck loaded for travel and I'll have the complete set of numbers to work with.
At that tongue weight the 1000# wd bars and the old style Reese cam sway control work well. As far as the ride of the trailer and truck, the Airsafe hitch pulls the whole thing together and provides a great ride for both. It's the "woopie cushion effect", and it's all good.
10-03-2010, 09:41 AM
#31
1996 34' Excella
Elberta
, Alabama
Larry,
Isn't it great when a plan comes together?
10-03-2010, 10:59 AM
#32
2010 27' FB Classic
N/A
Originally Posted by Larry C
Larry,
Yes, and I blame you for it!
Without your thread about AirSafe I'd still be fooling around with different size bars trying to make the trailer ride as it should. It made all the difference in the world when the AirSafe Hitch became part of the set up.
10-05-2010, 08:45 PM
#33
2007 27' Safari FB SE
Springfield
, Virginia
Very good to learn others are having great success with the AirSafe hitch. I just received mine last week. I bought one after reading about possible damage heavy duty trucks can do to the Airstream. I bought my F-350 DRW prior to reading the posts about the HD trucks. I had to acquire another TV after my dad wrecked my Expedition.
10-05-2010, 09:43 PM
#34
2019 22' Sport
High River
, Alberta
Don't worry about washers and locking nut. A 1/2" bolt and nut, finger tight, is quite sufficient. I towed about 6,000 miles that way, until my new hitch bars wore in and I realized I needed another half link of tension and took the bolts out.
10-05-2010, 10:00 PM
#35
2010 27' FB Classic
N/A
There are quite a few on this site who have them, and from what I see, everybody that tries the AirSafe likes the results.
