Old 08-23-2010, 04:16 PM   #1
2006 16' International CCD
Minneapolis , Minnesota
weight distributions system or not for a 16' bambi with jeep liberty v6
Hello -
Any thoughts on if I need a weight distribution system for my 3500lb 16' bambi with my 04 jeep liberty v6 sport?
right now, I do not have one..but will be driving from msp to seattle - down the coast and back.
any thought appreciated!
F
firenze is offline   Reply With Quote
Old 08-23-2010, 04:19 PM   #2
r carl's Avatar
Lin , Ne
I would put on a reese twincam with #600 or #800 bars on it.
Old 08-23-2010, 04:21 PM   #3
thanks for your advice...what difference in the way it tows now versus with that system? Will I notice the diff? I don't go over 65 mph currently. is it bad for my towing vehicle if I don't do the dist. system?
Old 08-23-2010, 04:23 PM   #4
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
I would never back out of the driveway without one! Have you towed it long or will this be your first trip? I have a Reese WD hitch and anti sway and it works great. When I only had the WD I hated the sway and wouldnt go on long trips until I got it. Do yourself a favor and buy both the WD and anti sway kit. On that long of a trip you will be glad you did. Have a great trip!
blmitch5 is offline   Reply With Quote
Old 08-23-2010, 04:27 PM   #5
hi - well, I've been at this for over 2 years... I picked it up in NY and drove it thru Penn. i guess i haven't been too worried until now and your message. i guess i wanted to avoid spending more money for this trip.
Old 08-23-2010, 04:34 PM   #6
blmitch5's Avatar
Olathe , Kansas
Well the big rigs used to push mine all over the place and being a single axel I have noticed a big improvement. Most on here would never just drop it on the ball and take off. I would at least do the WD hitch but the anti sway makes it much smoother etc. I didnt mean to scare you, I'm a newbe here but Im really glad I added the anti sway before I went to Colorado. I bought mine in Williamsburg VA and drove it home with just the WD bars and didnt have a problem but there wasnt any wind either. Just my 2 cents.
Old 08-23-2010, 04:34 PM   #7
It has NEVER been an issue of "spending more money".
It has ALWAYS been an issue of safety for you and your uninformed passengers, who are not aware that their life is more than likely in jeopardy, the very instant you lose control of your rig.
Statistics SAY "it will happen".
Old 08-23-2010, 05:46 PM   #8
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
DITTO on What Carl said. Look around in the local paper and Craigs list and find a old REESE TwinCam with 5 to 800 lbs bars like Carl said. That will take away any sway from passing rigs and give you just the rite amount of WD. without breakin the bank. I do recommend that after finding and installing that hitch that you make a trip to the scales(Cat or any State Certified scales) and find out where the weight is before and after applying the WD.
GOOD LUCK
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 08-23-2010, 05:59 PM   #9
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Reese is not the only company making WD hitches. I have an Equal-i-zer and it works fine and you can back up with it.
Learning how to set up hitches is difficult, but do-able. Some dealers don't take the time to do it right.
Gene
Old 08-23-2010, 07:29 PM   #10
Thanks for the tip and recommendations. I will be setting up my appt at the dealer. If I am going do it...I want it done right.
Old 08-23-2010, 07:59 PM   #11
blmitch5's Avatar
Olathe , Kansas
You can order from etrailer.com and do it yourself. Follow the directions and you will be fine. Maybe save enough for antisway. Good luck and happy towing.
Old 08-23-2010, 09:03 PM   #12
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Sashaying Along Down The Road
Hello -
F
I had a Jeep Liberty and traded it for a wider stance vehicle. Even so the first thing I optioned for was weight distribution and then added the dual cam setup Reese has. I merrily have gone 3,000 miles with the twinkie without any twitches except for being buffetted behind a car carrier and with another rig passing me at 70+ . The dual cam sway was momentary and disappeared as soon as I instinctively let up on the gas. BY the way, so far I have not seen a trailer tire that says over 65 is ok.
arcamedies is offline   Reply With Quote
Old 08-23-2010, 10:43 PM   #13
r carl's Avatar
Lin , Ne
I would buy and install yourself to save some money. Take your time and do a thorough job. This link will tell you how to adjust it.
http://www.airforums.com/forums/f464...ams-52579.html
Old 08-23-2010, 11:22 PM   #14
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have only seen one Airstream trailer swaying on the road, and it was a Bambi, being towed with a small SUV on the ball only. I thought he was going to lose it on the freeway.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Towing a 27' Overlander with a Jeep Liberty Silver Threads Tow Vehicles 14 04-25-2013 05:38 AM
Jeep Liberty Diesel as TV fab_fourd Tow Vehicles 5 11-19-2008 08:46 AM
Jeep Liberty towing question.. safari05-25 Tow Vehicles 20 07-22-2006 08:20 PM
Diesel Jeep Liberty and `61 Tradewind henrydahm Tow Vehicles 14 07-17-2006 05:56 AM
16' ccd Bambi drainage system question. gbrentsmith Waste Systems, Tanks & Totes 12 10-17-2005 09:08 PM
