Old 11-29-2011, 04:08 PM   #1
star kitty's Avatar
1967 20' Globetrotter
denver , Colorado
Weight Distribution Question
I have a 67' GT that has a dry weight of 2640 lbs and a TW of around 400 lbs. I tow with a half ton SUV. I was sold a 10,000 lb./1000 lb bar weight distribution hitch locally.
Is this set up too stiff for my trailer? Will this larger capacity hitch perform poorly or does it even matter which size you buy?
Thank you!
star kitty is offline   Reply With Quote
Old 11-29-2011, 04:25 PM   #2
dznf0g's Avatar
Oswego , Illinois
IMHO, yes. 600lb bars are even overkill a little, but I don't think you can get less, Unless you go with a complete replacement and get one of those single bar WDs. Someone else will have to chime in on that model.
What brand did the dealer sell you?
-Rich-
Old 11-29-2011, 04:26 PM   #3
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
Sounds like a beefy hitch for the TT weights quoted. Lots of posts here indicating such a set-up would be very stiff resulting in stress cracking in the TT over time. What make/modle hitch is it?
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 11-29-2011, 04:33 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
A hitch designed to manage 1000 lb tongue weight is probably not the right hitch for a trailer with a 400 lb tongue. It sounds like the way Equal-I-zer specs theirs (that's just a guess on my part) so to stick with the same brand, they have a 4000/400 setup and a 6000/600 setup that would be a better choice.
If it's another brand, I'm sure they also have a setup designed for a trailer closer to the weight of your GT. The local shop sold you what they had in stock, figuring it's better to sell you the wrong product than to risk you finding another vendor while they ordered the right hitch for your setup.
David
Old 11-29-2011, 04:34 PM   #5
star kitty's Avatar
denver , Colorado
I purchased a Buyers set up at a very reputable hitch dealer here in town. They never asked the weight of my unit or the TW.
Over the course of time on these forums, I have learned this unit is too much for my trailer.
How will this change the performance? Will it be rough on the trailer during travel?
Old 11-29-2011, 04:36 PM   #6
star kitty's Avatar
denver , Colorado
You are right, it is all they had in stock. I questioned the size when I bought it and it's all he had.
Old 11-29-2011, 04:43 PM   #7
Thank you!
Your hitch bars should not be more than 600 pounds.
There are 2 other things that cause a rough ride for an Airstream.
The first is the running gear, which should always be balanced as an assembly, or install automatic balancers.
The second is the condition of the rubber rods in the axle. No torsion axle lasts forever.
The Dura-Torque Axle
Old 11-29-2011, 05:00 PM   #8
dznf0g's Avatar
Oswego , Illinois
I would take it back. It is too much hitch and I believe it will cause damage.
-Rich-
Old 11-29-2011, 05:14 PM   #9
DKB_SATX's Avatar
1976 Argosy 28
It it's been too long to return it, they have a no-returns policy, etc. remember that you can sell the hitch for at least some of what you paid for it. After all, someone somewhere needs a hitch for 1000-lb tongue weight.
David
Old 11-29-2011, 05:31 PM   #10
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings star kitty!
The situation that you describe is far more common than you might believe, and was even more prevalent before the Internet made information more available. When I purchased my '64 Overlander in 1995, I knew very little about the hitching requirements for an Airstream so I trusted the local hitch shop. When I told them that I was towing with a 1995 Chevrolet K1500 Club Cab Silverado and that I would be towing a '64 Airstream tandem axle 26-foot, their immediate response was a Reese 1,000/10,000 pound hitch. For three years, I was oblivious to any issues with this setup.
When I towed my Overlander to the WBCCI International Rally in Boise, Idaho, a stress crack developed over the entrance door. While at the Rally, I was introduced to a Reese hitch expert who was very familiar with Airstreams and he immediately insisted that I down-size to 600 pound weight distribution bars. I followed his recommendation and am continuing to use that setup today -- tow vehicle is the same as well -- 1999 GMC K2500 Suburban.
The stress crack above the door was identified as being directly linked to the over-hitching. In addition, while it was not identified as the primary factor, the over-hitching also was said to have likely made the rear end separation worse (the second owner had mounted the spare tire on the rear bumper where it rode for 15 years). I learned my lesson after more than $3,000 in repairs that over-hitching does have potential costs involved.
Something else that I learned was that the factory dry weight figures for Airstreams of the 1960s may be a little on the light side if my '64 Overlander is any example. Its dry weight was a little over 500 pounds more than the factory literature suggests. Through having the ready-to-travel weight checked, I learned that the coach runs very close to 6,000 pounds with a hitch weight slightly in excess of 725 pounds.
Good luck with your research and investigation!
Kevin
Kevin D. Allen
AIR #827
Old 11-29-2011, 05:41 PM   #11
star kitty's Avatar
denver , Colorado
I have a call into the owner and I will try to return it. Upon my initial conversation today, they stated they have never heard of my complaint before.
Thank you all for your help.
Old 11-29-2011, 05:47 PM   #12
dznf0g's Avatar
Oswego , Illinois
Stick to your guns.
Based on what Overlander says his running weight is, I'd go with a Reese dual cam with 600lb bars.
Once you get all your gear and groceries, etc., in it, run it over the scales to ensure where you're at and verify proper wd setup.
-Rich-
Old 11-29-2011, 06:03 PM   #13
SteveH's Avatar
Common Sense , Texas
I have one of the single bar hitches rated for 400 lb tongue weight I use with a smaller trailer, and it works good. I would think it a very good hitch for a trailer of 400 lbs tongue weight, and a 1/2 ton tow vehicle.
Regards,
Steve
Old 11-29-2011, 06:39 PM   #14
dznf0g's Avatar
Oswego , Illinois
That's why I mentioned it, but I think she's on the ragged edge between the 400lb single bar and the 600 lb Reese after she gets in all her stuff.
What kind of trailer are you using it on?
-Rich-
Tongue weight danlehosky Hitches, Couplers & Balls 7 10-29-2011 04:16 PM
Lightest weight usable oven/stove? HHaase Stoves, Ovens & Microwaves 4 10-02-2011 10:56 AM
Weight distribution bars Mrs. Bale Hitches, Couplers & Balls 6 07-19-2011 06:11 AM
Axle weights limits vs. combined weight - What am I missing? Section8 Towing, Tow Vehicles & Hitches 25 02-15-2011 07:46 PM
31' Classic weight question pappy19 Tow Vehicles 11 02-06-2011 09:55 AM
