Old 12-28-2008, 07:24 PM   #43
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Hello Roger,
Thanks. Thats what is left on my list of things to do. I have to plan to get to the scales. Now that the ride is correct and everything is level i think it is what it is but it will be interesting to see what the numbers say. I guess you could say that im backing into the therory. I will post the numbers once i get it weighed.
Glad to hear yours is perfect. Im a bit jealous you have it all handled.
Thanks Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 05-17-2009, 07:29 PM   #44
Cracker's Avatar
Pittsfield , Maine
This topic has been dormant for awhile but I just wanted to bring it back to life and report that I'm yet another convert to the "light" (600 lb) equalizer bars! Like others, I had already modified the dually by switching to an alternate set of rear springs - basically eliminating the overload springs - but I was still stubborn enough to keep the 1,000 lb bars. When the opportunity came to purchase a set of 600 lb bars, at a reasonable cost, I decided to give the idea a try. I only had to make a slight adjustment to the Reese head after my first road test and the "softer" ride became immediately apparent! The adjustment accomplished two things; it aligned the bars parallel to the trailer tongue and it reduced the stress on the bars a bit. Initially, it was somewhat obvious that the bars were overstressed. The difference in hooking up between the old 1,000 lb bars and the new 600 lb bars is that I now find it necessary to use the tongue jack when hooking up due to the additional flex of the 600 lb bars - whereas with the 1,000 lb bars they flexed so little that they could easily be stressed within the operating range of the chain support mechanism - while the full weight of the trailer was resting on the hitch. I hope that explanation makes sense! For the record, the last time I weighed the tongue load with my Sherline scale it was right at 940 lbs. Transferring weight back to the front axle of the dually has never been a factor - as it hardly "unloads" when hitched up. The task has always been to provide a more comfortable ride for the trailer while assisting the load-carrying capabilities of the TV hitch somewhat.
Cracker
Cracker is offline   Reply With Quote
Old 05-17-2009, 08:12 PM   #45
Soft ride
Another soft ride owner conversion, who is happier.
Must be a lot of truth to those Physics.
Hopefully, others will also listen and make the "switch."
Airstream's love and must have a soft ride, if not, early expensive repairs for some "strange" reason, appears?????
Soft rides contribute to safety as well.
Old 05-18-2009, 03:08 PM   #46
1972 Travelux Princess 25
Cobourg , Ontario
Originally Posted by Action View Post
On an Airstream the body is the support. Similar to a Unibody car. The frame will not take all the stress the body and rivits will take that.
>>>>>>>>>>>>>Action
You take me too literally. Naturally if the frame is stressed the body will be stressed, as the body supports the frame and vice versa.
I was trying to paint a word picture that would help visualize what happens when a trailer is towed over bumps, up and down hills, or in any situation where vertical bending movement occurs at the hitch ball. There must be some "give" at this point or the trailer will be stressed.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 05-18-2009, 04:24 PM   #47
Airstream stresses
The following takes place, when a load equalizing hitch is used to tow an Airstream.
The tow vehicle must provide a reasonable soft ride.
The hitch bar rating must be correct for the job intended.
Depending on the tow vehicle, hitch bar ratings must decease as the tow vehicle rigidity increase.
Of course everything must be installed and adjusted correctly.
When hitting bumps, some of that shock from the tow vehicle is transfered to the A-frame, through the ball and hitch bars.
In turn, as the A-frame flexes, the shell will also flex which in turn causes the frame to flex with it.
Additional flexing problems are caused when the running gear is not properly balanced, as well as having bad axles.
When everything is at it's best, the shell does an outstanding job, controlling what the frame does.
The key is to learn your limits and those of the Airstream. You must build in safety margins for both.
tv and tt weight distribution SKEETER Tow Vehicles 7 06-18-2008 09:46 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
Weight Distribution Question Randy Johnson Hitches, Couplers & Balls 63 07-21-2003 10:57 AM
Weight Distribution newae On The Road... 9 07-18-2003 10:08 PM
weight distribution Craig Hitches, Couplers & Balls 2 04-14-2003 06:57 PM
