Old 12-14-2019, 08:18 PM   #1
1979 25' Tradewind
York , Pennsylvania
Weight distribution hitch match to trailer
Hello everyone I am new to the forums. Itís always been a dream to own such an amazing trailer and now we are acquiring one next week. Empty the 1979 Tradewind is 4200 lbs with a max of 5800. The tongue weight is 650. If I got a weight distribution hitch that has a 6000-8000 lbs tow and 600-800 tongue would this be sufficient? I understand that the tongue weight of the hitch has to be close to close to the tongue weight of the trailer.
Airpocket is offline   Reply With Quote
Old 12-14-2019, 08:50 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Welcome to the AirForums!
The sum of the weight of the trailer tongue and additionally all added cargo behind the tow vehicle's axle need to be matched to the hitch's torsion bar rating.
The hitch's towing capacity needs to be matched to the gross weight of the trailer and actual tongue weight loaded, not empty.
My guess, based on my experience with my 25', loaded tongue weight is ~ 150 to 200 lbs more than empty tongue weight (balance depends on how you place load inside the trailer)
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 12-15-2019, 05:46 AM   #3
1979 25' Tradewind
York , Pennsylvania
Yes this certainly makes sense so with the weight distribution system Iím looking at of 6000-8000 lbs haul and 600-800 lbs tongue put me nicely in the neighborhood. Even though I would never go past 6000 lbs the tongue weight would increase up to 800.
Old 12-15-2019, 08:12 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I had a 75 TradeWind and the numbers you quoted were similar to the published numbers from Airstream. At a maintenance rally in Colorado a few years back we had the hitch weight measured and it was just over 900 pounds. I used a Blue Ox with 1,000 pound bars.
Richard
Old 12-15-2019, 08:29 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
As noted above, even the empty weights on some older trailers can be off by a bit. Load them up and they can be off even further. It's a pretty good bet that you want a hitch / tow vehicle that will handle 1,000 pounds.
Old 12-15-2019, 10:17 AM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by Airpocket View Post
Yes this certainly makes sense so with the weight distribution system I’m looking at of 6000-8000 lbs haul and 600-800 lbs tongue put me nicely in the neighborhood. Even though I would never go past 6000 lbs the tongue weight would increase up to 800.
Considering the weight of the hitch/ball/bars (all added cargo behind the tow vehicle axel) and the possibility of carrying a generator, you might want to go with 1000 lb bars.
Though the 800 lb. bars would flex more to give a smoother ride, they might not have the ability to transfer enough weight off of the rear TV axle.
ps:
You did not tell us about the tow vehicle you are using. If you are towing with a vehicle with adequate capacity to easily carry the load, the 800 lb bars might be an OK choice. If you are towing with a vehicle that the rear sags a lot when loaded, you might need the 1,000 lb bars.
Alan
Old 12-15-2019, 10:58 AM   #7
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
What is your tow vehicle? If it's big enough you don't even need a weight distribution hitch.
out of sight is online now   Reply With Quote
Old 12-15-2019, 11:16 AM   #8
2018 25' International
Slidell , Louisiana
Just as most people are suggesting, I agree 1000 lb. Capacity is the way to go. To add to the other justifications, another is the strength and heft of the unit. Durability, longevity and ability to handle higher dynamic load should not be underestimated.
Now if 800 is good and 1000 is better, how about even more? No because at some point the torsion preload displacements becomes insufficient and the unit will go loose (zero tension) and cause slack when you hit a large bump at speed. It can jar apart or snap a fastener on recovery (energy = force x distance, so movement of the hitches static components is not good) You don't want that to happen.
Brian
Old 12-15-2019, 11:29 AM   #9
Slidell , Louisiana
Even for oversized tow vehicles like mine with plenty of capacity vs. my trailer size (a Ram 2500 4x4 Diesel) a weight distribution hitch should be used in my opinion. The vehicle suspension geometry shifts enough to influence steering and suspension stability with as little as 300-400 lbs of tongue weight and also most of the better designed distribution hitches provide some anti-sway feedback to various degrees do to the geometry and dynamic load characteristics.
Brian
Old 12-15-2019, 11:56 AM   #10
rideair's Avatar
I've always looked at it this way, it's a combo of tow-rig and tongue weight.
For my 1962 Galaxie or 1968 Travelall, I need 1,000-1,200 pound bars and a greater head pitch to lift the back-end up when towing my 1966 Overlander. When towing the same trailer with my Excursion, I use 600-800 pound bars with little head pitch.
Seen many of folks take a 1-ton truck, use 1,000-1,200 pound bars to then pop rivets and even bend the front A-frame on an old trailer with little tongue weight.
Andy at InlandRV preached this over and over. The connection needs to flex, not be stiff.
Do a search on his recommendations and you won't go wrong.
Enjoy,
Paul Waddell
rideair is online now   Reply With Quote
Old 12-15-2019, 12:07 PM   #11
2014 22' FB Sport
Davie , FL
I too have a RAM 2500 diesel. Unloaded it is not properly balanced because it has a 1000 lb engine over the front axle. When I put a 1000 lb tongue load on the hitch ball it evens things out. I have a 52/48 rear/front weight ratio which is much better for steering than the 40/60 unloaded ratio. Also, if you take weight off the rear axle with a WD hitch it will make your truck more prone to jackknife in a hard brake and swerve emergency.
I tow a 28 FC on the ball and it doesn't sway at all even at high speeds.
Old 12-15-2019, 01:34 PM   #12
Slidell , Louisiana
One of the difficulties with this forum and really life in general is that trailers, towing and life are not so simple as short answers allow.
I suppose I should have said it depends on many factors, because it does. You didn't say if your truck is 2 or 4 wheel drive and even that makes a difference. While for neutral steering around a circular trajectory, 50/50 may well be ideal, and traction/acceleration/breaking favors weight in the rear, but in real life varied situations, the ideal depends more on suspension tuning. On the 4X4 diesel it favors a bit more weight up front 45-47 rear according to my automotive engineer friends primarily due to suspension and steering geometry trade offs.
Now I didn't say, but we carry wood, supplies, generator, furniture, bikes, gasoline, extra propane, full diesel tank and 10 gallons more in a container in the bed and no end of other stuff when we travel and on its own adds 1000 lbs to the rear axle and 300 to the front depending on how we load the bed so we are about 45/55 without the trailer. I figure everyone loads up their tow vehicle to some extent.
So I suppose the best answer is "It depends" I would even give you that an empty 2500 Diesel theoretically benefits from no distribution hitch, but I still stand by earlier statement that all travelers should consider the benefits of weight distribution hitch for trailers with any appreciable tongue weight.
Brian
Old 12-16-2019, 05:29 AM   #13
1979 25' Tradewind
York , Pennsylvania
Thanks everyone! A lot of great info and things to think about. Iím towing with a Ram 1500 with 10,000 lbs towing cap.
Modifying Dometic Air Distribution Box to match 1975 Argosy curved ceiling Atx2001 Furnaces, Heaters, Fireplaces & Air Conditioning 2 12-15-2017 12:19 PM
"Weight Carrying" vs "Weight Distribution" PasoArt Towing, Tow Vehicles & Hitches 2 01-11-2016 09:04 PM
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 11:28 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 01:11 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 09:13 PM
