Old 10-21-2010, 08:25 PM   #1
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
weight distribution hitch
My 74 - 28" argosy did not come with a WD. I think it's about 500lbs TW. Which hitch do I buy. Is 600 ok or 800. Is 800 or 1000 over kill?
GeocamperAS is offline   Reply With Quote
Old 10-21-2010, 09:20 PM   #2
Hitch bar ratings are dictated not only by the tongue weight, but also by the type of tow vehicle.
What exact tow vehicle will you be using?
Old 10-21-2010, 09:54 PM   #3
1974 Argosy 28
Images: 37
08 Tundra
Old 10-22-2010, 10:54 AM   #4
08 Tundra
600 pounds is still plenty, but that's also the lowest rating avaiable.
The 600 is what I feel you should use.
Old 11-11-2010, 06:56 PM   #5
1974 Argosy 28
Images: 37
Which is better, round bar or trunnion?
Old 11-12-2010, 06:46 AM   #6
1974 Argosy 28
Images: 37
Is there one brand better then others?
Old 11-12-2010, 07:18 AM   #7
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Reese Twin Cam is the most commonly used in the club.
Old 11-12-2010, 02:39 PM   #8
1974 Argosy 28
Images: 37
Did not see 'twin cam' on the reese website.
Old 11-12-2010, 02:41 PM   #9
Dual cam, twin cam, straight line, are all the same.
I personally prefer the square bars, because if they take a set, you can invert them. That cannot be done with the round bars.
Old 11-12-2010, 03:01 PM   #10
r carl's Avatar
Lin , Ne
Best bang for the buck.
Old 11-12-2010, 03:02 PM   #11
r carl's Avatar
Lin , Ne
Here is info for you.
Common Weight Distribution and Sway Control Questions | etrailer.com
Old 11-12-2010, 03:47 PM   #12
SteveH's Avatar
Common Sense , Texas
Round bar are more flexible, so ride smoother, and don't take a "set".
Regards,
Steve
Old 11-12-2010, 05:42 PM   #13
1978 31' Excella 500
Tuttle , Oklahoma
I don't mean to hijack your thread but I have a question.
Are the WD bars available separately for the EZ Lift hitches?
I have 1000# bars and need to get 600#.
Will the 600# bars work on the 1000# hitch?
1bbboomer is offline   Reply With Quote
Old 11-12-2010, 06:15 PM   #14
Any spring steel, can and often does, take a set.
Square, round, triangular, oval or rectangular, all the same.
touareg, bambi and weight distribution hitch ericwarren Hitches, Couplers & Balls 2 10-02-2008 09:19 PM
Bambi Weight Distribution Hitch Recommendations gorrissen Hitches, Couplers & Balls 9 05-02-2006 12:35 PM
Which Weight Distribution Hitch to buy? Navigator Hitches, Couplers & Balls 7 11-19-2003 07:56 AM
how works a weight distribution hitch remcolent Hitches, Couplers & Balls 5 11-10-2003 06:24 PM
Recommendation on weight distribution hitch davidlaxson Hitches, Couplers & Balls 30 08-31-2003 09:38 PM
