11-14-2010, 08:48 AM
#41
I've done similar studies with my Reese 600 lb bars and Draw-Tite 800 lb bars. In my study I used deadweight loads on the bars and calculated deflection in lbs/inch.
Here are the summarized results:
Bar dimensions (mean of two bars):
Reese 600 lb bars:
thickness at head end 1.136"
thickness at taper end 0.599"
taper 0.0302"/inch
Draw-tite 800 lb bars:
thickness at head end 1.132"
thickness at taper end 0.645"
taper 0.0271"/inch
The spring rates for single bars are:
Reese 600 lb bars: 179 lbs/inch
Draw-Tite 800 lb bars: 195 lbs/inch
It's pretty easy to calculate the centering force using these rates and the dimensions of the cam follower on the Reese Dual Cam set-up, along with the angle between the tow vehicle and the trailer.
There doesn't appear to be that much difference between the bars. I think this is probably due to manufacturing variations. It's possible that if I checked another set of bars the ratings would be 10% higher or lower.
11-14-2010, 08:57 AM
#42
1955 22' Safari
Great Lake State
On your setup, what head angle did you use?...........toastie
11-14-2010, 09:05 AM
#43
In the study I did, the head angle is not a factor. I inverted the head so the bars were horizontal during the test. That eliminated any cosine errors. The bars were loaded with up to 420 lb of weight, and the deflection was measured directly. I did not use the setup shown in your post.
11-14-2010, 09:14 AM
#44
1955 22' Safari
Great Lake State
Markdoane, my question wasn't related to the study, I have the same setup as you have and trying to figure out what head angle I should start with..........toastie
11-14-2010, 10:41 AM
#45
1955 22' Safari
Great Lake State
tiger
This is the system that I went with: Strait-Line Weight Distribution w Sway Control - Trunnion Bar - 10,000 lbs GTW, 600 lbs TW
My TV is a 2008 Cheve Trailblazer, gross vehicle weight rating 5,550 lbs, curb weight 4,356 lbs. with max towing capacity is 5400 lbs. The trailer is a 1955 Safari approx weight is 2800 lbs tw approx 300 lbs. The bars are 600lb MAX load, so my 300lb TW is at a sweet spot.
I'm learning how to set it up now and here are a few sites that is helping me in that set up.
RV.Net Open Roads Forum: Towing: Travel Trailer Hitch Set-up Procedure
Google Image Result for http://i23.photobucket.com/albums/b378/JBarca/Hitch%20Setup/Reesetopview-shimed.jpg
toastie
11-14-2010, 12:15 PM
#46
I would start in the middle of the range and adjust accordingly. We have different trailers, tow vehicle, ball height and tongue weight.
I think I am just a tooth or two tilted back.
11-14-2010, 12:22 PM
#47
1955 22' Safari
Great Lake State
thanks
11-14-2010, 01:27 PM
#48
Common Sense
Originally Posted by r carl
Take it easy Steve, Andy has forgotten more than you and I together know about airstreams.....
About Airsteams, no doubt.
About WD hitches, well not so much....Andy has proven to me he knows a little about one manufacturer's one model of hitch.
Regards,
Steve
11-14-2010, 02:51 PM
#49
1955 22' Safari
Great Lake State
I bought my system about 2 weeks ago based on Andy's recommendation, very happy with the purchase, thanks Andy............
toastie
11-14-2010, 02:52 PM
#50
Corona
toastie
Your more than welcome.
01-15-2011, 12:35 PM
#51
2005 34' Classic
N Smithfield
, Rhode Island
Hello,
I just bought a Curt # 15524 Class V hitch to replace my OEM hitch for my 2004 Yukon Denali. The 7 Pin connection bracket is actually welded to my old hitch. Of course the new hitch has no such item pre attached. I do not have any welding tools- I would appreciate any comments on how do I find a way to have a permanent attachment for the electrical connection.
Many Thanks.
Titu
Titu & Gail
2005 34' Classic-Mercury (Goddess of Travel)
2016 GMC Sierra Denali 2500HD Diesel
BRN-2905
NEAC of Region 1
01-15-2011, 01:29 PM
#52
You're kinda stuck cutting the old 7way mounting bezel off with a hacksaw and drill and tap into the new hitch with some 1/4 or 5/16 screws. You might need to fabricate a bracket with some angle iron.
Won't be beautiful but it will work.
01-15-2011, 03:41 PM
#53
1999 34' Excella
Joshua
Originally Posted by AirHog
Hello,
Many Thanks.
Titu
I had the same problem when I bought my Curt. I cut the one off the GM hitch and mounted it upside down to the Curt hitch....works just fine.
If it wasn't raining, I would post a photo....
History doesn't repeat itself, people do!
01-15-2011, 04:03 PM
#54
2005 34' Classic
N Smithfield
, Rhode Island
A picture would be very much appreciated, if you get a chance. I am in no rush. 10 degree outside and as cold in the garage.
Titu & Gail
BRN-2905
NEAC of Region 1
01-15-2011, 05:03 PM
#55
1999 34' Excella
Joshua
I posted the photos at "My Photos"....
01-15-2011, 06:04 PM
#56
2005 34' Classic
N Smithfield
, Rhode Island
Looks great. Thank you very much. I will do the same. Best to you my friend.
Titu
Titu & Gail
BRN-2905
NEAC of Region 1
01-15-2011, 06:05 PM
#57
1999 34' Excella
Joshua
I tried posting the photos to the thread, but wasn't able to....
01-15-2011, 06:14 PM
#58
1999 34' Excella
Joshua
[IMG]file:///Users/dwightpurvis/Desktop/Curt1.JPG[/IMG][IMG]file:///Users/dwightpurvis/Library/Caches/TemporaryItems/moz-screenshot-2.png[/IMG][IMG]file:///Users/dwightpurvis/Library/Caches/TemporaryItems/moz-screenshot-3.png[/IMG]
01-15-2011, 08:21 PM
#59
Corona
If you can, turn the connector 180 degrees, so that the bootom of it will be at the top.
You will get far less dirt in it that way.
01-15-2011, 08:42 PM
#60
Retired.
, At Large
Hello,
Many Thanks.
Titu
That bracket is available separately. I'd just run to the parts store and buy a new one and screw it on for the little amount it costs (less than $5).
