Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 10-21-2010, 08:25 PM   #1
GeocamperAS's Avatar
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
weight distribution hitch
My 74 - 28" argosy did not come with a WD. I think it's about 500lbs TW. Which hitch do I buy. Is 600 ok or 800. Is 800 or 1000 over kill?
GeocamperAS is offline   Reply With Quote
Old 10-21-2010, 09:20 PM   #2
Hitch bar ratings are dictated not only by the tongue weight, but also by the type of tow vehicle.
What exact tow vehicle will you be using?
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-21-2010, 09:54 PM   #3
08 Tundra
Old 10-22-2010, 10:54 AM   #4
08 Tundra
600 pounds is still plenty, but that's also the lowest rating avaiable.
The 600 is what I feel you should use.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-11-2010, 06:56 PM   #5
Which is better, round bar or trunnion?
Old 11-12-2010, 06:46 AM   #6
Is there one brand better then others?
Old 11-12-2010, 07:18 AM   #7
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Reese Twin Cam is the most commonly used in the club.
Old 11-12-2010, 02:39 PM   #8
Did not see 'twin cam' on the reese website.
Old 11-12-2010, 02:41 PM   #9
Dual cam, twin cam, straight line, are all the same.
I personally prefer the square bars, because if they take a set, you can invert them. That cannot be done with the round bars.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-12-2010, 03:01 PM   #10
r carl's Avatar
Lin , Ne
Best bang for the buck.
Old 11-12-2010, 03:02 PM   #11
r carl's Avatar
Lin , Ne
Here is info for you.
Common Weight Distribution and Sway Control Questions | etrailer.com
Old 11-12-2010, 03:47 PM   #12
SteveH's Avatar
Common Sense , Texas
Round bar are more flexible, so ride smoother, and don't take a "set".
Regards,
Steve
Old 11-12-2010, 05:42 PM   #13
1978 31' Excella 500
Tuttle , Oklahoma
I don't mean to hijack your thread but I have a question.
Are the WD bars available separately for the EZ Lift hitches?
I have 1000# bars and need to get 600#.
Will the 600# bars work on the 1000# hitch?
1bbboomer is offline   Reply With Quote
Old 11-12-2010, 06:15 PM   #14
Any spring steel, can and often does, take a set.
Square, round, triangular, oval or rectangular, all the same.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-12-2010, 07:04 PM   #15
SteveH's Avatar
Late model square bars cannot be inverted because the cam is built into the bar.
Regards,
Steve
Old 11-12-2010, 10:00 PM   #16
2016 30' Classic
Sammamish , Washington
To determine the proper size of the Reese weight distribution bars look on page 28 of the Reese Heavy Duty Towing & Trailering Accessories catalog:
http://www.reeseprod.com/content/dow...ng_Catalog.pdf
PJohnson is offline   Reply With Quote
Old 11-13-2010, 07:28 AM   #17
SteveH's Avatar
Trunion (square) bars are not very flexible, and therefore are more prone to take a "set".
Round bars are more tapered, more flexible, and therefore are very much less prone to take a "set".
Then, if you put 1000 pounds of load on 500 pound trunion bars, they will DEFINATELY take a "set".
Regards,
Steve
Old 11-13-2010, 08:28 AM   #18
Bar flexing
Testing Reese round and square bars, show no difference in the amount of bend, for a given load.
That may be different for other manufacturers.
Bars when overloaded, can take on a set. As an example, instead of the trailer and tow vehicle being level with each other, they form more of a "V" shape, such as boarding a ferry boat.
Facts are facts.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-13-2010, 10:44 AM   #19
Ag&Au's Avatar
Port Orchard , Washington
Where do we find the formula or chart that tell us how much to adjust the hitch manufacturer's ratings based on what tow vehicle we use?
Ken
Old 11-13-2010, 10:53 AM   #20
SteveH's Avatar
Andy,
If you really had the "experience" you claim, and I mean experience using all types of these hitches and not just selling them, you would know your statement above is not true.
Regards,
Steve
touareg, bambi and weight distribution hitch ericwarren Hitches, Couplers & Balls 2 10-02-2008 09:19 PM
Bambi Weight Distribution Hitch Recommendations gorrissen Hitches, Couplers & Balls 9 05-02-2006 12:35 PM
Which Weight Distribution Hitch to buy? Navigator Hitches, Couplers & Balls 7 11-19-2003 07:56 AM
how works a weight distribution hitch remcolent Hitches, Couplers & Balls 5 11-10-2003 06:24 PM
Recommendation on weight distribution hitch davidlaxson Hitches, Couplers & Balls 30 08-31-2003 09:38 PM
